So Close.....
Old Apr 10, 2006 | 12:15 PM
Beater86's Avatar
So Close.....
still trying to get my 86 running...
tried the whole ATF in lower spark plug chambers, and it was soooooo ******* close to starting...
im going to check the compression on it, and then if its good ill probably take it in...any suggestions on things to check before i take it in?
backround info: the whole fuel pump and fuel tank was rusted to ****......
Old Apr 10, 2006 | 12:41 PM
royaltrex7's Avatar
have you checked for the important things spark fuel and air?
Old Apr 10, 2006 | 12:42 PM
Beater86's Avatar
spark...yes
fuel...yes
how do you check for air?
sorry im pretty new to the whole car world..
thanks
Old Apr 10, 2006 | 12:45 PM
SuperRotorMan's Avatar
Keep Your Stinky Pistons
check the basics. fuel spark air
Old Apr 10, 2006 | 12:46 PM
Beater86's Avatar
question...
if you have really old oil in it would it prevent it from starting somewhat?
i heard thick oil is bad for starting so would an oil change help at all giving it that extra kick it needs to get going?
Old Apr 10, 2006 | 12:51 PM
DREYKO's Avatar
I "lost" my emissions....
is your afm unplugged? its on the intake snorkle its the silver box. or is there a vacum hose that is unplugged?
Old Apr 10, 2006 | 01:00 PM
Beater86's Avatar
i dont know where or what your talking about..sorry
Old Apr 10, 2006 | 01:02 PM
royaltrex7's Avatar
give me 5 min and ill try and put some pictures up to show you what you need it will have to be in photobucket though
Old Apr 10, 2006 | 01:04 PM
Beater86's Avatar
alright thanks for the help
i appreciate it
Old Apr 10, 2006 | 01:13 PM
royaltrex7's Avatar
this might help
http://i66.photobucket.com/albums/h2.../enginebay.jpg
Old Apr 10, 2006 | 01:18 PM
Beater86's Avatar
thanks that helps alot...
whats number 15...its cut off?
Old Apr 10, 2006 | 05:32 PM
royaltrex7's Avatar
charcoal canister (carbon canister or vapor canister) same thing people just call them different things its part of emmissions that collects excess fuel vapor from the tank and stores it for use when starting the vehicle instead of venting it into the atmosphere
851stgen12a
6
Jan 7, 2003 03:31 PM
James Paventi
9
Dec 13, 2002 09:23 AM
