boost control location
Old Jun 22, 2007 | 10:09 AM
raphbo's Avatar
Hey is this the location you would put the boost controller in if you have a non-sequential setup? also what other things do you need to do to get the boost to be controlled from there?
Thanks,
Raphael
Old Jun 22, 2007 | 11:57 AM
911GT2's Avatar
The Power of 1.3
Check out the third gen FAQ: https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
Specifically the section on the non-seq setup:http://www.fd3s.net/non-sequential.html
Old Jun 22, 2007 | 11:44 PM
raphbo's Avatar
I installed the boost controller.....uh...???
I installed the boost controller as in the photo, do I need to open the boost controller before I start the engine? What else do I need to do? I capped off the bottom of the wastegate actuator valve. I started it while it was shut as such and it sounded really bad, I think something must be wrong, not sure what it is. any help would be really great.
Thanks,
Raph
Old Jun 23, 2007 | 03:52 AM
FD3S2005's Avatar
SideWayZ The Only Way
i would suggest getting an electric boost controller.. alot easyer to work with imo
Old Jun 23, 2007 | 03:10 PM
raphbo's Avatar
Sure if I had one, I am just asking about in my current setup with the manual boost T do I need to keep it open while the car is first started up? if so how many revolutions do I turn it?
Skeese
Adaptronic Engine Mgmt - AUS
65
Mar 28, 2017 03:30 PM
stickmantijuana
MoTeC
Sep 10, 2015 07:58 PM
