engine transplant no workie !
Old May 11, 2003 | 08:17 PM
seventhgear's Avatar
boost on the way(GTU II)
i have good compression...
spark/air/fuel/oil.....
i had to splice an injector wire into my car's harness because it was soo brittle and broke off....
it was the injector on the primary fuel rail that is closest to the thermostat housing... it is also taped up with the thermostat housing conector..... welll...
my harness's wire colors did not match up with the spliced injector connector and also the thermostat housing connector....
wires were close in color but not the same... so i guess i winged it and connected them together thinking they were the right wires to splice together.......
well i get to the point that i can turn the engine over....
well... all it does is crank over and over and over and over..
nothing else....
could a crossed spliced wire be the culprit of the constant crank and no fire up?
please help i am in need of an engine guys
thanks alot
jack
Old May 11, 2003 | 10:41 PM
CAN NE ONE GIVE THEIR .02 cents ?
i am desperate for this thing to get running i need to go looking for a job... and NOW
.. it suckz that i cant have her on the road ya know?
well hook me up with n e info u can
thanks
jack
Old May 11, 2003 | 10:43 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
have you tried a pull/push start?
Old May 11, 2003 | 10:45 PM
SonicRaT's Avatar
Super Raterhater
Are you sure it was the right connector that you used? Sure you didn't just put the water temp sensor on the injector? If that doesn't work, double check for MAJOR vac leaks, or the CAS is unhooked, AFM hooked up, timing is correct, etc.
Old May 11, 2003 | 11:09 PM
afm hooked.... cas is hooked....
im not good with timing on rotary engines... one thing im shitty about...i have the cas in the dead center of its turning radius....
i am leaning towards flip flopping the spliced wires u know? i think i may have messed up seeing that the colors didnt match too well...
imma try the wiring in the morn.... but is there n e thing i may be looking over???
thanks sonicrat
jack
Old May 11, 2003 | 11:15 PM
SonicRaT's Avatar
Super Raterhater
Well, the wires for the injectors don't matter, they pulse and it opens (or at least I believe, could be wrong :-D) Double check it against the FSM, if it doesn't match, well then you're using the wrong plug!
Old May 11, 2003 | 11:28 PM
I HAVENT TRIED THAT ...(the push or pull start)
dont know why i didnt... i always resort to that n e ways.... damnit... but i dont wanna do that this time... i dont know whatz up though bro and its really getting to me...im no master rotary mechanic u know?? and i have exactly $0.00 thanks guys n e one got another idea or their .02
thanks again
jack
Old May 11, 2003 | 11:35 PM
OK... ILL GO CHECK IT TOMORROW MORN AGAINST MY FSM ... THANKS SONICRAT... IF THATZ NOT THE DEAl then i guess i will be posting up tomorrow too
thanks again sonicrat
peace
jack
Old May 11, 2003 | 11:49 PM
Juan's Avatar
Im a tall midget.
My friend just went thru the same thing. His engine had good compression, timming was perferct and everything was hooked up right. The engine would just turn over and over and wouldnt start. To make a long story short, we discovered that the injectors werent getting any power to them. My friend ran new wires from the ECU to the injectors and the car fired right up.
Alot of people may hate this idea BUT get some starting fluid and have someone spray it into the intake while cranking the engine over. If it starts up, youre not getting fuel. If that doesnt work, then something else may be wrong.
Old May 12, 2003 | 03:58 AM
RexRyder's Avatar
this may sound stupid but i am also doing a swap an notice the brake fluid line and fuel line look exact, check that to make sure.
Old May 12, 2003 | 10:35 AM
lol i noticed that too.... lol but i had it right and i am getting fuel and spark and tried starting fluid already....
thanks guys
Old May 12, 2003 | 12:41 PM
Old May 12, 2003 | 12:46 PM
SonicRaT's Avatar
Super Raterhater
PULL START IT!
Old May 12, 2003 | 12:58 PM
i took the intake manny off and checked the wiring of that injector... and it looks ok...colors are pretty exact...so i think its wired right.... so next step will be pull starting that bih i guess....... maybe my starter is not turning over fast enough....well ill keep yall posted
thanks
jack
Old May 12, 2003 | 02:45 PM
RexRyder's Avatar
if the starter not fast, hook up like hella batteries.
Old May 12, 2003 | 03:58 PM
VOLTMETER IS ONLY READING like 10 voltsmaybe 8 i forget but i know its not 12 or more...
Microtech
30
Apr 23, 2016 06:37 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
