vacc lines on upperintake manafold
Old Nov 19, 2009 | 05:14 AM
Medic-droid's Avatar
A while back i had a friend help me with a leaking fuel pressure regulator, and we must of not reassembled it correctly because i recently took the upper intake manafold off and 1 of the vacc lines from the throttlebody were missing and i have no idea were its suppose to go. Its the 4th nipple down on the back of the throttle/ upper intake manafold body. anyone know were it goes.
Old Nov 19, 2009 | 09:34 AM
irishpilot's Avatar
I bet if you put up a pic you will get a responce
Old Nov 19, 2009 | 10:27 AM
arghx's Avatar
rotorhead
turbo or non turbo?
Old Nov 19, 2009 | 12:45 PM
HAILERS's Avatar
HAILERS
To one of the two nipples on the water thermo valve to the left of it.
Old Nov 23, 2009 | 08:21 AM
s4 turbo upperintake manafold
Old Nov 23, 2009 | 01:05 PM
barnett87rx7's Avatar
lite rotary = easy push
if its a turbo its a little vac hose with a green check valve that comes from the throttle body
Old Nov 24, 2009 | 08:09 AM
HAILERS's Avatar
HAILERS
AND the other end attaches to one of the two nipples on the water thermo valve. That is the only nipple of the four that is a vacuum source. The other three are fed from the Front of the throttle body i.e. no vacuum. Just FYI.
Old Nov 24, 2009 | 10:30 AM
R.E.wing_FC3s's Avatar
*reallly knowing the fc
explain how the air bleed sockets work without vacuum.
Old Nov 24, 2009 | 11:26 AM
HAILERS's Avatar
HAILERS
The rotor on its intake *stroke* sucks air thru the line connected to the rear of the manifold. The suction is not from the intake manifold but from the rotor on its intake stroke.
BLK 93
11
Sep 9, 2015 10:56 AM
Nosferatu
Sep 5, 2015 02:13 PM
rotor_veux
Sep 3, 2015 07:10 PM
