gsl-se Power Steering
Old Nov 15, 2009 | 09:47 PM
stobrien's Avatar
SE Lover
I am going to add power steering to my 85 GLS-SE. I have the pump and Steering box. Is there anything else that I need?
Old Nov 15, 2009 | 10:22 PM
Whisper's Avatar
Well, assuming you have all the piping and the P/S fluid cooling line, then you should be all set, unless the steering shaft you have right now isn't compatible with the P/S box. I think P/S shaft is the two-piece and uses a connector bushing, don't know about the regular steering shaft on GSL-SE.
Old Nov 15, 2009 | 10:31 PM
84stock's Avatar
The shaft and box are one unit. My suggestion is to set all the adjustments on the box up as per the fsm before installation.
Old Nov 16, 2009 | 02:07 AM
Rx-7Doctor's Avatar
Did your car come with A/c?
If not then you will need to get the proper mounting bracket for the P/S.
You also need the adjuster assembly.
Belt, pressure and return hoses.
Old Nov 16, 2009 | 02:24 AM
Whisper's Avatar
Wasn't on my car. The box has its own mini shaft that connects with the main shaft through a bushing.
LMBTG
Sep 2, 2015 07:01 PM
c0rpse
Aug 25, 2015 11:50 PM
