Rad temp/level sensor?
I have been getting some leaking from this sensor on top of the Rad, so today I unscrew it and of course it broke the wire at the cap. I retaped the screw part of it and went to put it back in, when tightening it up, the top part broke off, leaving the inside part screwed in.
Will this cause me any problems until I can get the Rad replace in the next month or so?
I know the sensor will not work, I jsut dont want it blowing out causing it to overheat since its my daily driver.
thats just the level sensor, won't cause anything bad. But I do believe if you keep it like that it does leak out of it IIRC. You should be able to pull it out fairly easily and perhaps replace it with a bolt right now.
Trending Topics
Item Number Price Select
Coolant Level Sensor
ECH
FLS610
$16.29
http://www.napaonline.com/MasterPage...=15&SubCatId=3
ECH
FLS610
$16.29
That's not a bad price for the NAPA part Doc, thanks for the link. Couple that with one of those new $89 ACDELCO radiators Rock Auto has on clearance Rob and your cooling system should be good to go for another decade or two.
Doc, or anybody that coolant sensor on NAPA says its for a 84-85. Will it work on my 80? mazdatrix says 79-85 for a coolant level sensor. The store let me order it and said I could bring in my old one to make sure.
Thanks
Thanks
Yes; use an open end wrench and keep the wire up out of the way until you're done. They dont need to go in much more than hand tight, and will fracture if you tighten too much.
& don't lean on it when working on other stuff...
imitek
24
Dec 1, 2015 03:35 PM
imitek
Sep 22, 2015 11:29 PM
rotor_veux
Sep 19, 2015 07:13 PM
