Another "What's this" Thread: Oil Pan part (not oil level, the other one)
Old Nov 14, 2009 | 05:43 PM
chris_g's Avatar
Always Learning
While taking my oil pan off, I noticed there was a loose wire from one of the accessories on the oil pan.
It is not the oil level sensor, it is the one next to it that threads into the oil pan.
In this picture, it is the part with the red wire
Thanks!
Chris
Old Nov 14, 2009 | 08:43 PM
Rx-7Doctor's Avatar
Oil temperature sensor.
Old Nov 14, 2009 | 09:12 PM
j9fd3s's Avatar
Community Builder
used for the sub zero start system..
Old Nov 15, 2009 | 12:52 AM
chris_g's Avatar
Always Learning
Great, thanks! Its what I thought it was then.
I did not know it was for the sub-zero, so thanks for that, too!
Any idea on where to get a replacement or what to do now that the wire broke from the sensor itself?
Old Nov 15, 2009 | 11:50 AM
Sgt Fox's Avatar
Stigulus Moderatorai
You can try digging away the epoxy to expose enough wire to solder to.
Old Nov 18, 2009 | 12:43 PM
Crit's Avatar
No distributor? No thanks
Yeah man, the way the sub-zero works is kinda cool. When you turn your key to "start" it puts 12V to the tab on the starter that throws the bendix out. It ALSO puts 12V to the sub-zero start motor, every time. The ground side of the motor is then run to that switch in the pan, which only grounds if the oil pan is way, way, way below freezing. If you were to ground that wire, you could give yourself a little shot of seafoam or something every time you turned the key, if that's what you wanted to put in the cold-start reservoir.
At least you can't flood it with antifreeze, though, as the pump only runs when the starter is turning the engine over.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
