GB:RE-A Style GT Wing
Old Nov 18, 2008 | 01:42 PM
JKL Racing Engineering's Avatar
GB Status: Closed
Product Status: In Stock & Ready To Ship
Retail Pricing: $750 (FRP) & $1000(CF) [Click N' Order]
Now offering RX7Club limited time exclusive discount: 10% off MSRP [PM us for details!!!]
This is the official GB interest thread for a possible production of RE style GT-II wing. The materials offered are to be determined by actual demand. Possible material choices are FRP and CF. The specific constructions can also vary from adding reinforcement tubing to using honeycomb cores. So please express your interest and we require minimum of 5 committed buyers to start this GB. (meaning 5 deposits must be received before we can start the production)
The adjustable mounting brackets will also be custom fabricated as well as all the necessary hardware. Other than drilling couple holes, this wing will be a direct bolt on for all FD.
We welcome all suggestions and ideas so please feel free to post your suggestions here.
Actual prices will vary depending on the number of orders we receive. Possible prices are as following: (All prices do not include shipping cost)
FRP $600-700
CF $800-900
Required Deposit: $300
All Payments should be sent to sales@jklre.com
Current GB List:
1. jknapik (CF, FD)
2. Mr. Stock(CF, FD)
3. RacerJason (FRP, FC)
4. integlspwr (FRP, FD)
5. jimmacsrx7 (FRP)
6. Mahjik (FRP, FD) - deposit received
7. wum (CF, FD)
8. viciousNY (FRP, FC) - deposit received
9. racerxrx7 (CF, FD) - deposit received
10. afgmoto1978 (FRP, FD) - Prefer support spacing of 1210 mm for custom made supports. Want the wing only.
11. OppositionTim (CF, FD) - deposit received
12. jimmacsrx7 (CF, FD) - deposit received
Old Nov 18, 2008 | 03:35 PM
jknapik's Avatar
MMR SpeedFactory
im diligent enought to say im IN what is the deposit??
also what is difference between dry n wet carbon?
Old Nov 18, 2008 | 05:03 PM
Oun's Avatar
Oun
I can confirm.
what are the specs? height and width in mm please.
Old Nov 18, 2008 | 07:32 PM
jimmacsrx7's Avatar
wing
Hi, I am in the market for a wing for my new track car. I would be up for this.
FRP for me.
Also is the wing adjustable?and is there any info on actual downforce provided at different speeds?
Any chance of a squared off wing, aka not pretty and curved, with a slit for a gurney lip like on the Grand Am SpeedSource RX8?
For me this will be track only.
Thanks for making parts for our great cars.
Jim
Old Nov 18, 2008 | 08:05 PM
AzEKnightz's Avatar
FRP for me.
Jim
Was also wondering if it is adjustable? FRP for me too =D. Let me know, thanks in advance.
-AzEKnightz
Old Nov 19, 2008 | 09:34 AM
RacerJason's Avatar
Coming to a track near u!
The plane/angle of the wing would be adjustable from where it connects to the upright mounts I imagine. And that bump in the middle is there for a reason. Creating a wing with a channel to accept various size gurneys would put the cost of the project out of reach for many. You will achieve the range of downforce you need with the adjustability it will have just fine.
Old Nov 19, 2008 | 09:59 AM
jknapik's Avatar
MMR SpeedFactory
1 more to go CMON lets get something here going, any1 else??? and what is deposit amount?
Old Nov 19, 2008 | 12:17 PM
twomucboost4u's Avatar
Always Under Construction
Just to confirm it is adjustable where the wing meets the top of the mout I believe there are five different positions.... I dont get over to my car very offen anymore but I will do my do diligence to make it over there and get some measurments for you guys...
Chris
Old Nov 19, 2008 | 04:33 PM
burtoncr's Avatar
I want it so bad, but it would look so dumb without a kit. aHHH the temptation is killing me. I want to stay with my 99spec lip and OEM sideskirts so I dont worry about hitting stuff.
Does anyone have pics of this on a relatively stock car with flush wheels and slammed? I know there was a red one with pics on a track, but I cant find it.
Old Nov 20, 2008 | 09:14 AM
Gaijin samurai's Avatar
How does this fit to the car?
I run an FRP boot on my car so bolting a GT wing onto this wouldnt be too good. My plan is to bolt it down to the car and cut away the boot around the wing. Like thet did with the Trial RX7
Old Nov 20, 2008 | 10:54 AM
jknapik's Avatar
MMR SpeedFactory
here are some pictures of the mounts i was talking about. i believe they are a bit shorter than originals.
other pictures of a FRP wing
and my favorite the full CF one
Old Nov 20, 2008 | 12:18 PM
The deposit required is $300
The difference between the dry and wet carbon constructions would be the weight, strength, and price.
Chris can provide the measurements of his wing when he has the time. Anyone else has the wing could help to provide us some measurements?
As many people have already explained, the top of the mounting bracket where it connects to the wing has an adjustable plate to change the angle of the wing.
I believe RE-Amemiya might have done the wind tunnel tests on the wing besides software simulation to determine its actual down force effects but it would be hard to find those tech data. As far as our research, it would be hard to offer wind tunnel tests on the wing since wind tunnel fees are outrageously expensive.
Yes, as racerjason has mentioned, the surface design of the gt wing is there for a purpose. You would always see the large middle section of the wing to be almost horizontally flat with a slight dent in the middle so that they do not create too much drag as compared to the down force while the car is traveling in a straight path. Drag would slow the car down as down force points perpendicular to the chord line of the wing. The two ends of the wing is slightly tilted more as compared to the middle section to always provide a slightly larger angle of attack for more down force applied onto the sides where the wheels are. The effects of this design can dramatically increase the down force generated as compared to a flat piece during high speed turns. And the end plates are there to guide air flow onto the end of the wing to maximize the down force generated at the wheels. So changing the angle of attack by adjusting the wing mounts can achieve a large difference in both drag and down force for different tracks.
burtoncr, the first two pictures we initially posted actually shows Chris' wing installed before he had our widebody kit on. Maybe Chris has more pictures to share with us?
Gaijin samurai, you are saying you have a FRP hatch? If you are worried about the strength of the hatch, you can also consider reinforcing the top and bottom of the hatch where the brackets goes with sheet metals. You will need to bolt the sheet metals down with extra bolts that way the stress created is spread out to a larger area on the hatch instead of concentrating on the holes where the brackets would bolt to. This method does require the hatch to be of decent quality and construction, otherwise, it will still break if the hatch was built too weak originally. This way, you do not have to cut away materials from the hatch and make it easier to go back to wingless, all you have to do is have a body shop fill those holes and repaint.
jknapik, thanks a lot for posting the pictures, the top three pictures showing the mounts are the original RE-A wings, so which bracket designs are you comparing them to?
Old Nov 20, 2008 | 01:00 PM
sub9lulu's Avatar
Cant u just make a mount for the FC ?
whta is the trade off to make another mount and double ur sale
Old Nov 20, 2008 | 03:36 PM
RacerJason's Avatar
He has suggested the possibility of making a copy of the FC mounts for 2nd gen owners if there was enough interest. If he doesn't then I'm prepared to purchase just the wing with the undermounts and make my own uprights.
Old Nov 20, 2008 | 04:26 PM
Yes, as long as someone can supply us with a FC mount, we will make the wing available for FC owners as well.
Old Nov 20, 2008 | 07:25 PM
jimmacsrx7's Avatar
I like it. This will help at Watkins Glen in the spring.
Put me on the list for FRP.
Thanks, Jim
Old Nov 20, 2008 | 08:48 PM
Mahjik's Avatar
Mr. Links
Interested in FRP.
Old Nov 21, 2008 | 10:08 AM
Thanks for the info. still not keen on having it bolted to the hatch, its decent quality (re-a original) but any downforce the wing may generate will go into flexing the hatch, not puching the back down. would rather bolt it direct to the car. Like the trial one (ill find a better pic) and the apexi one.
Old Nov 21, 2008 | 10:44 AM
Please add your name to the list so it's easier for us to keep a track of who is interested. It will be extremely difficult for us to look back at tons of posts to find who expressed interest.
Please remember to also state if you want FD or FC version.
List:
1. jknapik (CF, FD)
3. RacerJason (FRP, FD)
5. jimmacsrx7 (FRP)
6. Mahjik (FRP)
7.
8.
9.
Old Nov 21, 2008 | 10:52 AM
RacerJason's Avatar
1. jknapik (CF, FD)
5. jimmacsrx7 (FRP)
6. Mahjik (FRP)
7.
8.
9.
Old Nov 21, 2008 | 01:06 PM
jknapik's Avatar
MMR SpeedFactory
maybe it is a visual mirage but to me, it looks like these brackets are "shorter" than original ones. if im wrong then by all means lets get this started, but other than that everything seems like its going as planned. Il be submitting deposit ASAP just give me a bit of time, its sort of the drought season for me :S but im trying to manage things.
Keep up good work, cant wait to get all my hardware for the car
Old Nov 21, 2008 | 04:43 PM
Mahjik's Avatar
Mr. Links
1. jknapik (CF, FD)
5. jimmacsrx7 (FRP)
6. Mahjik (FRP, FD)
7.
8.
9.
Old Nov 22, 2008 | 02:47 PM
jimmacsrx7's Avatar
Thanks for putting me on the list.
Assuming we get 5 deposits what do you believe to be the rough timetable to be delivered to me/us.
My first track date is in April and if I can get it sometime in the winter to install it I will be 100% in.
Thanks for any info.
Jim
Old Nov 23, 2008 | 11:56 PM
It really depends on how fast we can get the deposits and what construction we will be using for the wings. I would say we should be able to get the first batch ready to ship before end of March if nothing major happens during the sample testing since we are planning to take some time off during the Christmas.
Old Nov 25, 2008 | 07:22 PM
RacerJason's Avatar
Although only moderately scientific the following video helps demonstrate the performance gains from this style wing:
http://ca.youtube.com/watch?v=u6_MUycoPPs
