Megasquirt ms2 extra and 60-2?
Old Sep 3, 2008 | 09:54 PM
chango de naranjito's Avatar
ms2 extra and 60-2?
can I use a 60-2 wheel alone? and how I set everyting in ms2 extra for the ignition? thanks!!!
Old Sep 5, 2008 | 09:23 AM
muythaibxr's Avatar
MegaSquirt Mod
You can use a 60-2 wheel, but it'll most likely require some mods to the v3 VR conditioner if you want to go over 6000 rpms.
How you set the ignition settings depends on what engine, what coil setup, how you mount the wheel, etc...
Ken
Old Sep 5, 2008 | 10:19 PM
Ken
you know the mod for this? I whant the redline to be 9500rpms, my setup is a 13b cosmo semipheriferal engine ,gt45 turbo,and whant to use 4 coils,2 for leading in waste spark and 2 for trailing (just like the turbo2) maybe I will use 3 msd 6a for spark but not sure,I think that it, thanks for the help litle confuse with the wiring too I do not know how to wire the coils... thanks,Frank
Old Sep 5, 2008 | 10:50 PM
toplessFC3Sman's Avatar
yea, the mod would be to cut every other tooth off the wheel, so it would become a 30-1 :-)
Old Sep 7, 2008 | 09:05 AM
what if I use a 36-1? and the wiring? how I conect the coils? I not found that in any place thanks for your time,Frank
Old Sep 8, 2008 | 08:56 AM
muythaibxr's Avatar
MegaSquirt Mod
You've likely not found it anywhere b/c most people just use the stock CAS.
You probably won't have to modify the built-in conditioner with 36-1.
Ken
Old Sep 15, 2008 | 12:04 AM
elturbonitroso's Avatar
chango use a turbo 2 cas. if you need you let me know i would sell you 1 for a good prices.
Old Sep 17, 2008 | 09:21 PM
Ken
ok I got a cas from a turbo II, what I have to do to make it work?
Old Sep 18, 2008 | 08:41 AM
Aaron Cake's Avatar
Engine, Not Motor
Check the FAQ. It's well documented.
Captain Hook
13
Oct 4, 2015 06:35 PM
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
