GT42R Kit(any questions ask in here)
Old Sep 23, 2005 | 07:16 PM
Zero R's Avatar
Just in time to die
GT42R Kit
This kit includes
GT42R turbo 94 or 102mm
Stainless manifold 4" stainless DP
Wastegate 44,50,60mm
Stainless oil feed
oil drain
oil fittings
waterlines
water fittings
Blockoff plates
Gaskets
V-band connector for compressor outlet.
V-band connection for midpipe. *must be welded locally.
New thermostat housing.
*Manifold and DP are warrantied for as long as you own it.
This kit is great for those who want to make big power 500+whp, and Wow people with their huge turbo. It is not for a stock ported motor. This is for someone wanting a drag oriented setup. With that said it still spools rather quick. We have seen 1bar@3800rpms with a 1.15 turbine housing on a decent sized streetport. With all the right things in place 600whp can be had. This means race fuel,proper porting, ignition and tune.
-Sean
Old Sep 29, 2005 | 07:04 PM
kabooski's Avatar
Laying Down Rotary Law
what do you recommend is the best for a 13B
74 or 76 version?
Old Sep 29, 2005 | 07:10 PM
onefastrx7's Avatar
600whp on race gas? I thought they make 530-550whp on pump gas at 15psi?
Old Sep 29, 2005 | 07:14 PM
kabooski's Avatar
only if you build a setup like Marcos
or Ralph @ excessive
its all about the "setup"
not just the turbo kit
Old Sep 29, 2005 | 08:52 PM
onefastrx7's Avatar
what is so special on their setup? half bridge?
Old Sep 29, 2005 | 09:02 PM
BOOSTD 7's Avatar
Persona non grata
Tony up at Tri-State in New York is running on of these on his gorgeous burgundy 1st gen. That car has a 1/2 bridge, and makes well over 600 at the wheels ... I think like 630, and runs mid 9's (not back-halved). On his car there was VERY LITTLE lag, it came on hard and fast.
Old Sep 29, 2005 | 09:04 PM
cripsR6's Avatar
11.7@128
How much for a kit through the groupbuy? Also, how long of a wait would it be?
Old Sep 29, 2005 | 09:05 PM
BOOSTD 7's Avatar
Persona non grata
Ralph has made over 600 with his on a street port and pump gas. On race gas and high boost I think the best he did was like 730 at the wheels. There's also a guy from Denver with the Orange FD that ran last year on the NHRA Circuit. He also does around 730 on a street port and runs low 9's in a full-body IRS FD.
Old Sep 29, 2005 | 09:10 PM
kabooski's Avatar
all using T6 frame housings?
any benefit opting for a T4 foot print turbine housing ?
Old Sep 29, 2005 | 09:26 PM
ErnieT's Avatar
Living life 9 seconds at a time
I just got my A-Spec GT42R kit and must say its all thats advertised and more! Sean did an excellent job on the manifold. Very nice kit. My car should be completed within 2 weeks including dyno tuning at 30psi so stay tuned for more results. I highly recommend Sean. He will go out of his way to answer all and any of your questions and help in any way.
Old Sep 30, 2005 | 12:07 AM
onefastrx7's Avatar
630rwhp at what boost and what gas?
Old Sep 30, 2005 | 12:09 AM
onefastrx7's Avatar
Zero R,
can you , please, post any dynocharts with boost settings and ports?
Old Oct 3, 2005 | 12:40 PM
Zero R's Avatar
Just in time to die
74 or 76 version?
I think that would depend on what level of build your going for. But for the most part if you plot it out the smaller one is fine for a little more than 3bar with 9k rpm. And you don't have to worry about surge at lower RPM. If all is good and my math holds true that puts you way up in the 600whp range. I would leave the larger one for 20B's and Bridge ported or C-ported motors. With the 74 you will have 1bar by around 3600 rpms. On my car I have it set up with 2" primaries, T6, Full 5" exhaust running a 1.01 housing. I have no doubt it will be able to spool up quick.
Zero R,
I will be getting dyno charts and such up as they come. There will be a section here just for that purpose.
Old Oct 3, 2005 | 01:09 PM
Zero R's Avatar
Just in time to die
I try and stay away from group buys, I have a hard enough time keeping up with what I have on order and with Garrett somtimes not meeting demand. I would hate to have people mad at me more often.
all using T6 frame housings? any benefit opting for a T4 foot print turbine housing ?
I prefer the T6, I think Magnus prefers the T4. What I like with the T6 is it mates perfectly with 2" primaries no need to step it down. So when you run big exhaust ports it all mates up nice. Your only real restriction is then the turbine itself.
Old Oct 3, 2005 | 03:32 PM
cripsR6's Avatar
11.7@128
I totally understand about the chaos. I misunderstood this forum for being a groupbuy one, when its a Vendor/groupbuy forum.
Old Oct 4, 2005 | 05:30 PM
kabooski's Avatar
I held a T6 housing
this past weekend
a 1.15 A/R
and boy is that thing heavy
any manifold would have to braced real well
True! the T6 split inlet looks real NICE!
looks like it would flow and pretty much match the size of the exhaust ports/2" runners like you said
Old Oct 10, 2005 | 11:00 PM
CCarlisi's Avatar
Rebreaking things
Do you have any pictures that you can post of the 42R mounted in an FD engine bay aside from the small pics on your website? A turbo that big deserves more resolution!
Old Oct 11, 2005 | 09:57 AM
Zero R's Avatar
Just in time to die
Agreed! Will do just need to get some taken.
Old Oct 11, 2005 | 08:34 PM
sk8world's Avatar
Chasing numbers
CAn this 42r sit on a T4? Or is that too small? I guess I would have to sell my complete kit before I could buy the 42r kit. Pm me a price.. Mike
Old Oct 12, 2005 | 10:30 AM
Zero R's Avatar
Just in time to die
They can come with a T4 footprint. I don't like it much. I know it wont fit on the manifold your thinking of I will get a price together for you.
Old Oct 25, 2005 | 08:50 PM
Swolbynos's Avatar
Newb
pm sent
Old Oct 25, 2005 | 09:36 PM
blueskaterboy's Avatar
Olympic Muff Diver
i think my bearings in my twins are shot and im looking for a nice big turbo to use with my pettit street port and then when i go 20b use the turbo with that hopefully with little to no modification...? the reason is theres only 20k miles on my motor and i dont really want to rip it apart. i'll probably sell it when i have enough for the 20b project.
i was originally thinking about a t76
would this be good on a 20b? how much power should i expect on pump 91 or 93, and race gas. i'll probably try to get dee to do most of this for me.
Old Oct 26, 2005 | 06:44 PM
Zero R's Avatar
Just in time to die
42R's are fine on 20B's keep an eye on Paximus's car. He has one on his 20B should be dynoed soon.
-S-
Old Nov 21, 2005 | 09:58 PM
mr2foryou's Avatar
600+rwhp club member
Zero R, PM sent
Dee
Old Nov 22, 2005 | 10:29 AM
Zero R's Avatar
Just in time to die
Got ya!
