What 17x9 wheel for F+R?
Old Jul 15, 2002 | 03:41 PM
turbojeff's Avatar
Do it right, do it once
I'm looking for a relatively cheap lightweight wheel 17x9" that will fit my FD front and rear (45mm offset?) with Eibach springs.
I've got a set of SSR Integrals, 17x8 and 17x9" currently for street rubber. I want to upgrade to 17" wheels with the same size rubber all the way around. My problem is I have 3 17x9" wheels (one spare) but Tire Rack says the 9" Integral is discontinued.
Jeff
Old Jul 15, 2002 | 09:06 PM
SleepR1's Avatar
Jeff,
I'm not aware of any other wheels that will fit properly...the 9 x 17, 45-mm offset SSR Integral A2 is perfect with a 255/40-17, and is the only one-piece cast wheel that came in that size and offset...
I'm sure that the SSR GT-1s come in 9 x 17, 45-mm offsets, but they're slightly heavier, and much more expensive at $375 each...(I think from Tire Rack?)...
I'm glad I bought five SSR Integral A2s in 9 x 17, 45-mm offset when I did. I just knew that $289 each for a forged wheel in that size and offset was just perfect and the money was right too
I guess you're just looking for one SSR Integral A2 in 9 x 17, 45-mm offset aren't you?
Old Jul 15, 2002 | 10:34 PM
turbojeff's Avatar
Yep, I'm looking for one 17x9" A2 Integral. Wanna sell your spare?
I meant to mention that I'm going to be putting R-compound rubber on these wheels, 255/40/17 Kuhmo V700s to replace stock wheels with 245/45/16 Kuhmos.
Jeff
Old Jul 16, 2002 | 10:19 AM
SleepR1's Avatar
Enticing, but I mass pass I like to rotate the "spare" into service...it allows me to get extra mileage out of the AVS Intermediates
Old Jul 18, 2002 | 08:40 PM
Taz's Avatar
Taz
SE37k's w/ 245/40 Hoosiers.
Old Jul 18, 2002 | 09:52 PM
voodooracing's Avatar
the new CE28N is very light too....
Old Jul 19, 2002 | 02:22 PM
ARD T2's Avatar
For something inexpensive I would suggest the Enkei NT03. The Enkei wheel RE-A used on one of their FD's. I have these in 17,9 +43 which will work with a 245/40 front and rear.
The whole set can be had for about $700.00 shipped with hardware.
http://discounttiredirect.com/produc...ct.s.large.jpg
This picture does not do it justice whatsoever.
Thanks, Rishie
This is a Enkei Tuning wheel meaning it's lightweight, made for race application, and made in Japan.
Old Jul 19, 2002 | 02:55 PM
SleepR1's Avatar
How much do the Enkeis weigh Rishie?
Old Jul 19, 2002 | 03:48 PM
ARD T2's Avatar
They are 19 lbs ea. And very strong for a cast wheel.
Rishie
Old Jul 19, 2002 | 09:55 PM
SleepR1's Avatar
Yeah, my 9 x 17 SSR Integral A2s in 9 x 17, 45-mm offset, weigh about that much...That's a good deal on the Enkeis...may consider them for another set of track wheels
Rishie
Old Jul 20, 2002 | 05:12 PM
SleepR1's Avatar
Enkei NT03 in Super Street
Super Street featured a white RE Amemiya Rx7 with polished (chrome?) Enkei NT03 wheels in 9 (fr) // 10 (rr) x 17 with 255/40-17 Yokohama A048 tires all the way around. Check it out...
Thanks, Rishie
Old Jul 24, 2003 | 07:44 PM
SleepR1's Avatar
Thanks, Rishie
Rishie, what deals can be had with the updated NT03+M Enkeis? They now come in 9.5 x 17, 44 mm offset. Weight is 20 lbs each. This is light for a wheel this wide, and on par with Forgeline RSes in the same size except 50 mm offset. I'd considering buying a set of FIVE NT03+Ms (in F1 Silver) with 255/40-17 Pirelli P-Zero Asymmetrics (OE Porsche fitment N1s)
http://www.enkei.com/highperformance/nt03+m.htm
Old Jul 25, 2003 | 10:57 AM
tgriesel's Avatar
Jeff: Take a look at the 5Zigen, FN01R
http://www.5zigenusa.com/wheels.html Tom
Old Jul 25, 2003 | 06:09 PM
Flyweight's Avatar
FD3S
What about Enkei RPF1s? Enkei's site has them listed in 17x9 +45. Check out http://www.enkei.co.jp/pro-mat/p-f.html and click on the RPf1s. These are pretty incredible wheels for the price tag. Not to mention they are very light as well.
Old Jul 26, 2003 | 08:12 AM
LT1-7's Avatar
John
Black Racing Pro N1..........$200 a wheel
Old Aug 5, 2003 | 06:56 AM
bkapold@aol.com's Avatar
I have RPF1's and there the finest-widest-lightest-wheel for the cash....
I have a 91 Turbo II w/ 17 x 9.5's (R) +38mm & 17 x 9 (F) + 35mm offsets. The 9.5's weigh 16.5lbs and have a 73mm enter bore.. From the factory there kinda polished out (not chrome) w/ clear coat, so thats pretty cool and easy to take care of
I spent about $305 per wheel and 21.00 for the center caps, which I'm ditching for some CCW flush aluminum caps....
Old Aug 5, 2003 | 08:33 AM
SleepR1's Avatar
Oh, that's news. I didn't know the 45-mm offset 9 x 17s were available!
Old Aug 5, 2003 | 08:51 AM
ptrhahn's Avatar
I'm not sure if thewy have that size in the states... looks like they even have 18" in Japan... heres the spec sheet from enkei USA:
http://www.enkei.com/HPSpecPAGES/rpf1Specs.html
Old Aug 5, 2003 | 08:59 AM
ptrhahn's Avatar
What sort of luck would one have running the 17x9.5 +38 all around... just on the track? Would that work up front?
I know whenever you look on japanese wheel sites, they always spec real low offsets like 35 for the front of FDs.
Old Aug 5, 2003 | 10:53 AM
SleepR1's Avatar
Yeah, the Japs love the wide track look with low offsets. Just roll the fender lips, and use 255/40-17s, you should be ok...(these will sit 0.24 inches more outward per side compared with a 44 mm offset, 9.5 wide x 17 Enkei NT03+M).
Old Aug 5, 2003 | 08:09 PM
you should be fine on the 9.5's on all 4 corners....Like I said I have 9's on the front of a 91 TII and the 9.5's on back... They have 17 x 10 in RPF1's too, and I tried one on my car and it fit (R)....however they only sent one from Enkei-TX and according to Enkei Japan it would be months before I saw the other one (long story) but I thought 9.5's w/ 275's would be fine.... my .02
Kevin Wyum has CCW 17 x 10's up front on his FD
( don't know offset) and 17x 11's on back with 315's and no flairs...nice! anyway, so you should be fine
Brad
Old Nov 4, 2003 | 01:07 PM
diyman25's Avatar
RE for life
ARD TII
since I cant pm u or e mail u so I had to post on the forum
CAN u do me favor please. I neeed the price on these ENKEI wheels ? enkei NT03 18x9.5 off set 40 , and wonder if they carry this in stock
thanks for ur time
jay
Old Dec 30, 2003 | 11:46 PM
SleepR1's Avatar
Re: What 17x9 wheel for F+R?
Jeff,
Do you still have your 3, 9 x 17, SSR Integrals in 45-mm offset? I might be interested in buying them, along with buying Peter's set of rear 9 x 17, 45-mm offset Integrals--giving me another set of 5, 9 x 17s to wrap 255/40-17 Pirelli P-Zero Corsas for track events. Email me with a price. Shipping will be to 46217 ZIP.
Jeff
Old Jan 4, 2004 | 09:14 PM
shawnk's Avatar
Perpetual Rebuilder
Sleep.
I just picked up a set of Integrals with 2 17x8 and 2 17x9 wheels. I am interested in trying to get 17x9 all the way around. If your plans to get two sets of 5 dont work out let me know if you want to sell 2. Drop me an email at shawn@3rdgenrx7.com if you want to contact me.
Thanks,
Shawn
Old Jan 7, 2004 | 08:09 PM
SleepR1's Avatar
Shawn,
Plans fell through. Peter traded his Integrals, and I have not seen a reply from Jeff. I guess I'll keep my set of five 9 x 17s, with 255/40-17 Pirellis (see my sig pic LOL )
Originally posted by shawnk
Sleep.
Thanks,
Shawn
