*** 1st Gen 1/4 Mile Leader Board ***
Old May 14, 2007 | 11:07 PM
mannyvidal's Avatar
come get some.....
1.31 60' 6.809 in the 1/8th 10.89 @ 124.316 mph on street trim n/a 13b bridge port carburated on a stock manual tranny ford 9 " rear end 26x8.5 tires *** 1st Gen 1/4 Mile Leader Board ***-rx7011.jpg
*** 1st Gen 1/4 Mile Leader Board ***-quebonito008.jpg
Old May 15, 2007 | 12:05 AM
84stock's Avatar
Any video's??????
Originally Posted by mannyvidal
1.31 60' 6.809 in the 1/8th 10.89 @ 124.316 mph on street trim n/a 13b bridge port carburated on a stock manual tranny ford 9 " rear end 26x8.5 tires Attachment 237420
Attachment 237421
Old May 15, 2007 | 12:11 AM
Directfreak's Avatar
I am a Jeeper Now.
Attachment 237421
10.89 running N/A? At that MPH... I smell something...
Old May 15, 2007 | 01:30 AM
  #29
No_Rotor_RX7's Avatar
if he really cut a 1.3 60ft then maybe... how much does the car weigh???
Old May 15, 2007 | 05:50 AM
  #30
chava_rx7's Avatar
Ima try and get my 7 to the track this weekend if i get my lines from the oil cooler in time! I really wana c wat ill run with the mods i have i currently have a 84 GSL-SE with minor mods-
Cone Filter- Hard to find a cold air system for this model!
Pace setter headders- full 2 1/2 inch piping
DLIDFIS- 2 blaster coils and 2 GM ignitors
10.3mm wires for 2nd gen
cheap nopy muffler- im a budget racer muffler only $70
and a stage 3 six puck clutch
and i wanna test it out and c wat it makes but until i get the lines is just daydreaming about it till the weekend!!!
Old May 15, 2007 | 06:31 AM
  #31
ehhh... high 14's
Old May 15, 2007 | 07:43 AM
  #32
dbragg's Avatar
Say hello to Mr.Wankel
yeah, juice or BS.
15.2
specs:
82 GS, stock port 12a, RE full exhaust, weber 48 IDF, light flywheel, shitty tires, and in bad need of a tune.
Old May 15, 2007 | 01:42 PM
  #33
mannyvidal's Avatar
come get some.....
ok the car weighs 2290 lbs with me in it and it was built to run nhra sportcompact street stock class after the car was built nhra changed their rules and i was left out of the loop , ive ran idrc ,and boti events out here in california if you look @ the pics closelly you see no cage in it because it was it was never intended to run anything quicker than 11.00 . now the car has undergone mayor surgery to drop some weight its @ 2050 lbs the car is very consistent in the 1/8 th but my mayor cocern was the 60' we had issues on the top end for a bit due to the fact that the oe tranny gearing is so out of wack but we have figured that out.
my car is some what a replica of kilo's car" JESUS PADILLA " its just been perfected supension wise , ive known the man since all my life so we have allways work really close , i am also his marketing manager . for the ones who have heard about kilo you know the type of race cars he builds so sorry guys there is no bs or nos in my car just good old fashion puerto rican engienering ur goal in mar car is to run a 10.00 or 9.999 with a manual transmission @ legal nhra weight so this summer you might be hearing a bit more about the car till then wish us luck ,we have a heard task in front of us but not imposible i have some engine bay pics in the drag racing section of the forum i quater mile times ,let me know what u think thanx
Old May 15, 2007 | 04:18 PM
  #34
kuhlrx7's Avatar
Unconfirmed
11.9@126 not much in to drag though, happened about 6 years ago 12a/ turbo large port, 50mm mukini that never ran right. just out for fun one night
Old May 16, 2007 | 10:29 AM
  #35
drittens's Avatar
what does Directfreak run in the 1/4?
Old May 16, 2007 | 10:33 AM
  #36
KNONFS's Avatar
B O R I C U A
Attachment 237421
DAMN, those are some good #'s!
Old May 16, 2007 | 12:43 PM
  #37
chedda_j's Avatar
16.8 fairly stock @ 89 mph.....im like a turtle
Old May 16, 2007 | 02:09 PM
  #38
Chiron's Avatar
A Voice of Truth
Bone stock '85 GS N/A at a decent local raceway got 16.2 @ 93 mph. Surprisingly beat many of the "suped-up" Hondas from the high schools....
Old May 16, 2007 | 02:30 PM
  #39
ducktape's Avatar
Fast-Trash
I've seen stock-port 12A's run high-10's in the 1/8... The MPH is kind of... WTF
Old May 16, 2007 | 02:33 PM
  #40
dbragg's Avatar
^^ i thought he meant 10.89 in the quarter. if thats 1/8 then i can easily see that being possible. i think he says he ran a 6.8 in the 1/8.
Old May 16, 2007 | 04:05 PM
  #41
ducktape's Avatar
Fast-Trash
Guess I misread that.
Old May 16, 2007 | 06:49 PM
  #42
I am a Jeeper Now.
15.9 @ 89 mph.
Stock GSL-SE.
Old May 16, 2007 | 07:42 PM
  #43
mannyvidal's Avatar
come get some.....
gracias panin, eso es lo que pone a to esta gente nerviosa como no lo pueden hacer no lo creen
Old May 16, 2007 | 08:46 PM
  #44
I am a Jeeper Now.
hmm...still seems off...
Not really. Its not impossible to achieve what you are stating, just very unlikely.
I am just suprised that you are doing those times and mph with a Bridge-port, and not a Peripheral Port.
According to you:
Based on those times, ET, and weight:<-Click for yourself.)
- your car should be doing about 340-350 WHEEL HP. (If it weighed 2290)
- your car should be doing about 305-315 WHEEL HP. (If it weighed 2050)
You didn't specify what the weight was when you ran those times, so I
am just being thorough, and providing both calculations.
Although... in this post: https://www.rx7club.com/showpost.php?p=6876576&postcount=6
You state that the MPH was 121.156, at the exact same E.T, and that you..
just finished tearing down the whole car to drop some weight cause i aint going on no diet
After running that time.
So it appears you ran the 10.89 @ 121.156 at a weight of at 2290lbs, which means
- your car should be doing about 315-320 WHEEL HP. (If it weighed 2290)
I have not seen that kind of power on even 'one' Bridgeport with no power adders.
Running a carburator, 5-speed, 87 Octane, no methanol, etc... It becomes less and less realistic.
I am at a loss..
Are you running a semi-peripheral port? I know it can be hidden within the
intake on your car.
Anything is possible, right? But hey, what do I know.
I am no Jesus Padilla. He's my all-motor Hero.
Old May 16, 2007 | 09:25 PM
  #45
mannyvidal's Avatar
come get some.....
i am really glad to see you have been paying close attention to my post thats good real good , so just because you havent seen that out of a bridge port means it cant be done ,and just cause evrybody told us we would never see a 9.8 on a 13b kilo quit and we didnt do it ,dam right we did how many people back in the day use to say that bridgeports force induction didnt mix ? that didnt stop them from trying new things and it wont stop us, r/d papo thats what its all about..... and if you what ask kilo how many times he has put the car in the dyno .....not once and neather has mine , but if what you are trying to say i am full of **** its ok you can say it on the other hand if the numbers are as high as your calculator is saying thats great cause we belive we have some more left to milk out of it eso es si el todopoderoso nos deja
Old May 16, 2007 | 09:36 PM
  #46
I am a Jeeper Now.
You are 100% right. Good Luck, I hope to see you complete your quest for 9's soon. Hell, I wish I was running what your car is now..
Old May 16, 2007 | 10:41 PM
  #47
85rotarypower's Avatar
love the braaaap
DF, you should be running in that range with the engine you have right now. Sure its not an NA, but hey, if you can get traction I figure your car is good for low 10's at least. Unless of course you aren't running the same engine you had in the vids.
Old May 17, 2007 | 01:03 AM
  #48
I am a Jeeper Now.
My car is too heavy at the moment. It's 2750 without me in it. Full Cage, Full Interior,
and Heavy *** Ford 8.8. Between the A/C and some other misc junk, I can probably
drop another 50-75lbs, while remaining a true street car.
The MPH I have run has been good for mid 10's (129), and that was with a Rotor exhaust sleeve blocking flow to the turbo, and limiting my boost
(almost fell into the turbo!!) My ET's have been horrible as it's too much wheelspin for
my tiny drag radials, and 2.4+ 60ft times.
I am not too concerned about the ET's though, that will come with traction
and driver practice. As long as I can outrun 95% of the cars on the road - I am happy.
The look on a Porsche Turbo drivers face after you chew him up and spit him out: priceless.
Soon after I dial in the rear end, I am going to put some slicks on it and go for it,
just for braggin rights later this year.
The 'Other' Engine will be good for 9's.
Old May 17, 2007 | 01:56 AM
  #49
WAS:12A's Avatar
1) WAS:12A---------------------------11.45 @ 117.73mph (1/4Mile)------------1985 Series 3 SA22C,13BT, Highflowed, Microtech, etc etc
2) steve84GS TII ---------------------13.59- @ 106 ----------------------------- 84 GS, S4 13BT, S5 Turbo, Stock
3) estevan62274 ---------------------13.6-- @ 102 ----------------------------- 84 GSL-SE, S5 13BT, Stock
4) 84stock ---------------------------- 15.1-- @ ?? --------------------------------85 GSL-SE, 13B, Street, S/C
5) blown7 ----------------------------- 15.267 @ 89 ------------------------------ 85 GSL, 12A, 1/2 Bridge
Old May 17, 2007 | 06:46 AM
  #50
IanS's Avatar
Ricer
woohoo I am the slowest!!!
R/T - 0.972
60' - 2.405
330' - 6.646
1/8 - 10.188
MPH - 70.52
1000' - 13.274
1/4 - 15.887
MPH - 86.55
Mods in sig
