Make your own bead roller for $3
Old Apr 1, 2003 | 07:52 PM
setzep's Avatar
Here it is, should be self explanatory
Old Apr 2, 2003 | 01:43 AM
TonyTurboII's Avatar
Glock Lover
Explain.
Old Apr 2, 2003 | 08:46 AM
fastrotaries's Avatar
W. TX chirpin Monkey
So what do i do with that pipe?
Old Apr 2, 2003 | 09:16 AM
RacerXtreme7's Avatar
NASA geek
Nice, looks like vice grips with a groove and a male "hump" welded in to make nice beads for intercooler pipes to keep the silicon couplers from blowing off, NICE JOB, too bad it wont work on my aluminum piping
~Mike.....
Old Apr 2, 2003 | 06:02 PM
setzep's Avatar
~Mike.....
ding ding ding
Yeah for the aluminum tubing I'm going to weld a bead around it.
Old Apr 2, 2003 | 09:46 PM
80-CU.IN.T's Avatar
I ran four prox. 3/4" beads on my aluminum 2-1/2" pipes and had sealing problems. I am going to sand one of my pipes smooth and try it. With a good hose clamp I can't see why a thick silicon hose will blow off even at 30+ psi.
Old Apr 3, 2003 | 06:12 PM
setzep's Avatar
Four beads? How do you mean? Did you weld 4 "circles" on the tube or just lay down 4 short beads with gaps inbetween?
Old Apr 3, 2003 | 09:49 PM
80-CU.IN.T's Avatar
Sorry for the confusion. Gaps in-between the 3/4" beads.
Old Sep 19, 2003 | 02:13 PM
Wankel7's Avatar
Haven't we ALL heard this
Why does that not work on AL piping?
James
Old Sep 19, 2003 | 02:51 PM
peejay's Avatar
Old [Sch|F]ool
Aluminum doesn't "work" the same way steel does.
Wicked93gs
44
Jan 12, 2022 10:08 AM
Project88Turbo
Aug 29, 2015 02:23 PM
