rev limiting fun.. kinda?
Old May 25, 2012 | 09:32 PM
beachFC's Avatar
Bridge Burner.
what is your guy's take on the high RPM carbon burn off ****? does that **** really make a difference? I'd hit the redline on my car whether it was good for the car or not.. just wondering if it actually has any benefits?
i just hit the rev-limiter in first gear today and it started popping, crackling, and making fireworks. and i kinda started wondering whether it was fuel cut or ignition cut??? i'm pretty sure it is fuel cut, and was wondering if maybe that can be dangerous?
and if so, then where would the "redline it to keep it healthy" **** help, after detonating my motor?
Old May 25, 2012 | 11:24 PM
slowgxl's Avatar
if its fuel cut it can be very dangerous....it will make your car run really lean and pop the engine if you keep it up. now if its ignition cut its not.
Old May 26, 2012 | 02:06 AM
beachFC's Avatar
Bridge Burner.
Yeah thas exactly what I meant.. **** it haha I'll let up a little?
Old May 26, 2012 | 08:34 PM
CS13B's Avatar
From the Roots Up!
a redline a day keeps the carbon away?
Old May 26, 2012 | 09:11 PM
RotaryEvolution's Avatar
Sharp Claws
if your car is crackling and popping at redline with the stock ECU then your car is having issues.
stock the car has a soft limiter.
and yes, IMO redlining these engines does dislodge larger chunks of carbon and even some of the smaller stuff. but this is nowhere near as healthy as premixing, auxiliary injection or decarbonizing treatments is. premix usually keeps at least 50% of the carbon off the rotors, AI will keep the internals spotless and decarb treatments trump redlining to dislodge carbon because you do not have to test your motor to do it.
Old May 26, 2012 | 09:14 PM
beefhole's Avatar
Boosted. I got BLOWN!!!
Fuel cut doesn't mean a lean condition... it means no combustion happens at all. You will not pop the engine with ZERO fuel. You will "pop" the engine when it physically over revs.
Old May 27, 2012 | 02:58 AM
Derekcat's Avatar
Rotary Zealot!
Fuel cut seems to be around 7700RPM on S4 NA.. Though that's from a dynosheet where the tech. hit it..
It does certainly dislodge carbon [I did a a bit of high RPM WOT pulls in 2nd gear a couple years ago which seemed to help the engine with something else... But I've forgotten exactly what ^_^"]
Doing the water decarbonizing is also fairly helpful for determining the condition of your engine [you'll have trouble keeping the RPMs steady if it's not doing well]
Old May 28, 2012 | 04:17 AM
beachFC's Avatar
Bridge Burner.
why do you say this?
Prediict
32
Nov 18, 2015 08:41 AM
LongDuck
12
Oct 7, 2015 08:12 PM
Rotafuzz
Sep 30, 2015 09:55 AM
dexter snoek
Sep 29, 2015 09:18 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
