RX-7 Audio/Visual Lounge Request/share all your sound/video clips here!!!
1987 Supercharged FC
Old Jun 7, 2008 | 02:27 PM
  #76
katorx7's Avatar
World 427ci 7.0 liters
Shock Dyno & New access panels to adjust shocks
Old Jan 25, 2010 | 02:29 PM
  #77
katorx7's Avatar
New Engine, shooting for end of February-All motor 9 sec street driven
Grant of Granny's Speed Shop making a custom engine cradle to clear deeper oil pan
World Motown with billet caps 4.125 x 4.00 (427 ci)
Forged crank, rods, pistons (12.5 to 1) rated to 1500hp but I'm not that optimistic, shooting for 600+ hp
AFR 227 comp (fine cut 329/237 cfm @ .750) with upgraded Manley 1.640 springs and titanium retainers, 2.10 int valve, 1.60 exh valve
Jesel Pro series shaft rocker arms (all needle bearings option) 1.75 int. 1.65 exh.
Cam .761/.728 lift (1.75/1.65 ratio) with 252/258 duration @ .050, Crower solid roller
New additions:
2003 Viper GTS, 1972 240Z 99% restored
Extra E88 240Z head, getting refreshed with racing valve job.
Old Jan 28, 2010 | 07:29 AM
  #78
katorx7's Avatar
Pics of Supercharger setup on Atkins Rotary and Camden Websites before going V8.
Atkins Rotary Website:
http://www.atkinsrotary.com/index.php?pag=2
Camden Superchargers too:
http://www.camdensuperchargers.com/index.php?pag=4
The Atkins family are just awesome folks. Boy did they help me with a ton of technical advice and support.
Just blew me away with their unparalled customer service.
Quote from past post:
"I put together the Camden Supercharger and ported 13B 6 port engine built by Nick Van Nugteren of Rotary Reliability and Racing back in 2005. I was taking this combination to 8500 + rpm (rotary engine rpm) which is close to the superchargers 13,000 rpm limit (with - 7 pulley). Eventually the supercharger lobes collided which each other and took out my rotary engine.
I was always happy with the rotary engine and Camden Supercharger setup. But to get the best results for drag racing I had to take the ported rotary engine to 8500+ rpm. Anything can fail when taken to its limits. That's the calculated risk I had to take to get the most from my setup. The Camden supercharger lived up to its intended purpose but by pushing the supercharger to its outer limits and beyond, failures can happen and rightfully so.
My experience with Andy and the Camden Supercharger has always been a very positive one. Andy went above and beyond to help me get my project finished and tuned with invaluable advice and tech support. He was always available when I needed the help. Which was a big bonus. I never felt I was alone on my own to figure everything out. I am very grateful for such great customer service.
Andy even rebuilt the supercharger with all new parts at no cost to me - now thats great customer service !!"
Setup is now on my friend Abel's FC. Gotta get some pics of his setup and send it to them. Abel cleaned up his enginebay way better than I had mine.
Old Jul 25, 2010 | 01:27 AM
  #79
katorx7's Avatar
Whooooo Doggy!!
Hopefully on the streets this week
Baby 389ci and big sister 427ci
Trans rebuilt for 850+hp, Torque Converter rebuilt for 750hp
Old Jul 29, 2010 | 01:37 PM
  #80
katorx7's Avatar
She's in!
Custom Ron Davis double pass radiator.
All -10 fuel setup, good for 750+ hp
Old Aug 10, 2010 | 01:40 PM
  #81
katorx7's Avatar
Up n running!
Custom made front drag struts. Based on Porsche specs (dimensions) tuned for application, custom Koni internals, 14" spring.
Old Aug 23, 2010 | 11:32 PM
  #82
SirCygnus's Avatar
whats going on?
im going to be the first to say that i demand more pictures of the lady.
Old Aug 26, 2010 | 03:10 PM
  #83
katorx7's Avatar
2005,2006,2007 Los Angeles Bikini Calendar Girl Winner
Old Feb 3, 2011 | 12:43 PM
  #84
katorx7's Avatar
Alston Swing out side bars. Certified Aircraft Chro-moly Miltary Spec. Chassis not finished yet, lots of innovative work done by the chassis fabricator of the Terrible Herbst Trophy Truck Race Vehicles.
Custom BRASWELL Carb. Designed for Engine/Drivetrain/Chassis/Vehicle. 30 to 50+ hp over current carb. Huge difference over former old school Holley 750 DP.
Old Feb 12, 2011 | 05:45 PM
  #85
katorx7's Avatar
Custom made front drag struts. Certified aircraft chro-moly, based on Porsche front strut to provide more shock extension, 14" spring, Koni internals tuned for application. Hopefully faster rate of lift and more front body lift before topping out to transfer weight better and faster than previous setup.
New and Previous (Drag Launch kit from Ground Control)
Previous Drag Launch kit from Ground Control
New
Adjustable Camber and Caster Plate
Old May 21, 2011 | 01:31 AM
  #86
katorx7's Avatar
All Motor, always street driven. (DA 4227 elevation)
Baseline runs: conservative tune, 2300 rpm footbrake launch
Next time out a little more tuning. Will try to get as much out with 2500+rpm street converter. Then replace with a higher stall and trans brake.
RT 60 ft. ET MPH
#1 .004 1.554 10.287 136.68
#2 .258 1.603 10.288 136.87 (solo run)
#3 .007 1.567 10.233 136.54 (solo run)
#4 .205 1.628 10.276 136.94
#5 .001 1.531 10.214 136.63 (New Personal Best)
Old May 21, 2011 | 08:19 AM
  #87
RXTASY57's Avatar
Viper Eater
VERY nice!
You are doing what I want to do with a rotary!
I know it can be done. Just a liitle harder to do with the wankel.
Old May 21, 2011 | 11:29 AM
  #88
katorx7's Avatar
Originally Posted by RXTASY57
VERY nice!
Thanks.
I agree, Way Way More Challenging with a Rotary. Props to all who do and amazing, more impressive of the fact too.
Good luck on your build, take care
Old May 21, 2011 | 08:28 PM
  #89
katorx7's Avatar
VIDS:
http://s65.photobucket.com/albums/h2...nt=1st_run.mp4
http://s65.photobucket.com/albums/h2...nt=2nd_run.mp4
http://s65.photobucket.com/albums/h2...nt=3rd_run.mp4
http://s65.photobucket.com/albums/h2...nt=4th_run.mp4
http://s65.photobucket.com/albums/h2...nt=5th_run.mp4
Old May 23, 2011 | 01:16 PM
  #90
red_ricer's Avatar
Spending too much $$$
This car is purpose built and badass. I like it!
Old Jun 11, 2011 | 05:54 PM
  #91
katorx7's Avatar
Thanks, Sorry for the late reply
Old Jun 11, 2011 | 05:59 PM
  #92
katorx7's Avatar
New Converter!!
Built by Les Figueroa, head of B&M's Custom Converter Division for over 10 years, now owner/operator of this division, all of B&M's custom converters are designed/made at his shop, part of his Dragster Speed Shop FigSpeed.
Old May 25, 2012 | 01:53 PM
  #93
katorx7's Avatar
18 years 300+ track runs
Retiring FC, putting back old 389 (10.9 @ 124) engine, giving complete FC to good friend.
Current FC engine going in to new chassis:
Street Legal CA Regisitered.
Alston Chro-moly tube chassis AC Cobra replica with lengthened wheelbase, cert to 7.50
1800 lbs with SBF V8
Built by Ryland Racing
Former Worlds Fastest Street Cobra
Old Jun 3, 2012 | 09:56 PM
  #94
RXTASY57's Avatar
Viper Eater
That Cobra is one mean lookin machine!
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
R|©haźd
Sep 24, 2015 11:39 AM
