3rd gen upper intake to FC?
Im just wondering how hard to do this conversion on my 87TII and the benefits of doing this mod. WHat things i will need for the conversion. I was told by HN (member) that i will need the 89+ lower intake manifold. I have a lower manifold off a JSPEC motor so its not a problem.
Anyone done or have a link to this mod??..i would appreciate it guys!
The process includes swapping the throttle body and TPS as well. I dont know if your stock ecu will work with the 3rd gen TPS, but I would guess that it would not.
Plus, your stock top mount intercooler will not bolt onto this manifold, so you will have to rig something or go with a front mount.
Also, you will have to port match the lower intake manifold to match the intake runners on the FD upper intake manifold.
One more thing, those FD upper intakes aren't too cheap. There is not need to go with one of these unless you are pushing a lot of horses...
my 2 cents
my 2 cents
I got the intercooler,TPS,&ECU taken' care of. For ECU and TPS i will be using HALTECH E6K. As for the intercooler, Im having my NPR FMIC customized as we speak. How hard is it to port match my lower intake manifold to match the 3rd gen upper manifold?..
It is not very hard to port match.. You also have to round out the holes on the 3rd gen intake.. it is the to middle ones. but not the very center..
The reason people do this is to help with the flow on the intercooler & make the pipes not so zig zag like..
-Zach
-Zach
I just bought a 3rd gen manifold
your saying it wont be possible to mount on a 88 lower manifold
only 89+ ????
How is soul assasin using the whole 3rd manifold on his FC
he said he had some custom work done??
but won't explain
only 89+ ????
but won't explain
The answer is that you need a 89-91 plus lower intake manifold and a 3rd gen upper manifold. One of the manifolds I am not sure if it is the lower or the upper needs to be slotted and the ports need to be matched and then it will work. You need to use a 3rd gen throttle cable. From what I understand the 87-88 oil metering system will not work with this because something gets in the way. You can either fix the oil metering system partially open or run pre-mix. I was one of the first to see this here in the states. About two years ago a buddy of mine pulled up with his second gen. He opened the hood and what did I see? A powder coated red 3rd gen intake with all the piping. If you would like to have someone do it for you contact Japtrix in South Florida. www.japtrix.com
They have a low ten second Turbo II with this mod done to it.
Hope this helps...one thing to remember is that it is recommended that you go with a bigger turbo because this mod flows alot more air. You will need a aftermarket ECU ala Haltech.
Later,
Dave
Later,
Dave
Trending Topics
hmmm I have an 89+ lower manifold off my old Jspec motor. Im going bigger turbo and im going to delete my METERING OIL PUMP. Haltech is hidden somewhere in my closet. SO i guess all i need is to look for all the 3rd gen stuff to do the mod. Can somebody list the things i have to look for such as 3rd gen upper intake manifold, throttle cable, throttle body???gaskets???
but won't explain
but won't explain
Re: 3rd gen upper intake to FC?
What's up Jeff! How ya been? Good to see you're still wanting to finish your TII sometime by next year :P
About the FD intake: Soul assasin did this conversion, so he should know all the specifics. PM him.
soul assassin uses a 13bt motor, fd/rew upper intake w/ panspeed elbow. he had garage vanna i think it was do the work to make it fit. and his motor is 89+ 13bt
the work the shop did is what zyounker did, bore out the fd's upper intake holes to fit the studs on the fc's lower, and port match the intake runners.
how the h*ll is he making 500+ HP on a 13bt, they should break around 400, he must have some crazy dowels and tension bolts.
he was also running a power FC which is only for 3rd gen...
3rd gen motors are weaker then 2nd gen (I don't mean HP weaK
reliability weak)
reliability weak)
Scott 89T2 ur wrong
his power fc is for an fc they make em in japan for second gens,
and second gens properly reinforced can make 600 hp my friend n brooklyn had one years ago then he sold the motor to sum guy in puerto rico
no, 3rd gens have stonger housings and dowels. 2nd gen ones will twist apart with high HP.
there are more 3rd gens with blown motors
most everyone that works on 7's will tell you 3rd gen motors ARE less reliable then 2nd gen
well elt me clear this up for ya! i am running a 13BT with FD upper and t.b. with a panspeed elbow. the manifold i bought was from garage vanna and you send them your stock lower intake mani and they send you a lower mani already set up to bolt in but you still have to do some custom fab stuff, you need to run a FD throttle cable so you need the bracket of the FD also but you will need to drill new holes in it to get it to mount right with the right amount of tension, also the big pain is the oil filler neck it is to tall to use with the FD mani if you put a rew and bt side by side you will see the neck is about 2-3 inches longer so that big tube that come to the front of the engine where yuo put oil will not fit you need to make a plate and new tube to bolt on the lower housing. you will also need to notch out the lower part of the upper manifold to clear the injector rails, and last but not least you can't use a FC or FD engine torque dampner they won't fit so you have to custom make one, i think that is about it for custom fab stuff, you need to splice the new tps in with the old tps wiring i doubt that you can do it with a stock computer. it is about of little things that add up to make it a pretty big project.
as for the hp issue
they DO make power FC's for FC'S here in japan, i no longer us one i went with HKS FCON V PRO (gold one) my moter is not doweled or have titanium apex seals, it all has to do with tuning all those things are tuning crutches because they don't know how to tune i am running low comp zenki rotors with FD housing and stock 3pc apex seals that have been WPC'D this motor is good for 600rwhp and 10 grand on the tach. also can handle 30 psi of boost haven't tuned that high yet since it is still inda new wanna get some passes on it with 25 psi and see how it does right now it is at 520 rwhp
hope this helps some i will kee an eye on this thread to ttry and answer anymore questions
as for the hp issue
well from posting's (forum) to several rx7 shops here
someone posted just a few weeks ago that their moded 13bt was leaking by the oil filter between the housings which ment that they were now broken.
