my s4 build! nz styles
Old Oct 28, 2011 | 10:52 PM
nvmarx's Avatar
hey guys figured i may as well show you guys my build since i have been getting hints of all of you for ages so hear it is just click this link an have a look i do not have much photos as car is on blocks and my shead is tiny.
keep in mind in new zealand almost evry fc3s was turbo in the very rear ocasion a non turbo one will pop up but geting hard to find now. i got mine for 4000 nzd witch is about 6000usd that actuly very cheep for a running 13bturbo s4 with wheels coilovers and other goodies. now i have put my race engine in it it is the ony s4 in new zealand wit a pport!!!! the others have gone to turbo set ups!!
so i havent done any work to get it looking how i want except the non turbo bonet witch i payed what would be about 600usd for but im going to style it like you us guys to its un hurd of over hear!! plans are TII side s4 mouldings and a pignose front lip us spec mirrors and s5 tail lights all of these things are very hard to find in nz but good things take time
so hears the link while your at it have a look at the other rx7s on trademe what is basicly like ebay to you guys im sure youl figure it out
http://www.trademe.co.nz/Browse/List...400907&ed=true
Old Oct 29, 2011 | 03:20 AM
Panda86's Avatar
Hey mate, looks like alot of work, but it's got alot of goodies there ready to be installed.
Are you running CAS or dizzy? there's a bright orange fc runnin a pport over there, putting down 222rwkw
Take some decent pics and post them up
Old Oct 29, 2011 | 07:26 PM
nvmarx's Avatar
yea man got a 12aturbo electric dizzy for it most of part are allredy in just money is holding me back haha
yea the guy with the orange one ended up takeing the pport out and selling the fc or some thing like that
im yet to upgrade the steering aswell there is a guy in nz that modifys the knuckles so i might get them dun soon!!
Old Nov 15, 2011 | 10:43 PM
nvmarx's Avatar
hey guys here is a list of what i have and what is in/on the car now just working on the rear coil overs to roll it out of the shed for the 1st time in over a year!!!!
new un started s5 13b n/a 51mm pport lightened balanced
new seals, springs etc
new s5 highest comp n/a 6port rotors from usa
new 10lb flywheel
new five puk racing clutch
new gilmore drive
new bocsh coils race plugs 11mm leads
new holley blue fuel pump, reg and 10mm fuel lines
new extractors new gasket
new water pump and thermostat
new high rise alloy pp manifold
new short shift kit
new battery in back
new oil catch can
new overflow
new massive alloy radiator with 16inch fan
new solid front and rear sway bar mounts
new solid front and rear sway bar end link bushings
new racing beat anti sway bars
new rear adjustable camber correction arm
new rear racing beat steering eliminators bushings
new mazda stiffer engine, gbox and diff mounts
new solid front diff mount
new solid front and rear control arm bushings
new strut braces
new 2way height and camber pillow ball adjustable suspension modified for more - camber
new 17x9 18p drift wheels
new super low seat rails
new oil pressure and water temp gauges boss kit
rebuilt strengthened and lightened rear sub frame
rebuilt s5 gbox, s5 lsd new oil, starter motor, electric dizzy and steering rack
used cusco full bolt in roll cage
used cusco solid alloy sub frame mounts
used dulock in car floor brace
used atw rear camber adjusters
used racepro black fixed bucket seats
used momo wheel
used n/a s5 bonnet
fue other things i plan to get soon are
s5 turboII side skirts
180sx pig nose lip
and may up grade the brakes and steering at some stage
army tank flat green paint!
what i need to get it finished before next summer is a i.d.a carb exhaust rewire and tune! it
i will get pictures up as soon as i can!!
Old Dec 4, 2011 | 11:42 PM
nvmarx's Avatar
not a update but found these two pics i will get around to taking photos of every thing so far one day this week!
progress is slow just doing little odd jobs on it when i can
Attached Thumbnails my s4 build! nz styles-sl371137.jpg   my s4 build! nz styles-sl371138.jpg
Old Dec 7, 2011 | 09:48 PM
nvmarx's Avatar
photos as it sits now
hey guys here are a few photos of how far i have got after all most 3 years just chipping away at it when i can and when i can afford it most things are just mocked/dummied up and will be fitted properly starting next week end i have 5 weeks off work!!! how ever things like the rear sub frame is complete and up and in all bushings are done except the tie rod end covers (cant seem to get the tie rod ends off lol) the cusco cage is in only half cage for now as dash dodging front bars don't pass certification over here and obviously the engine gbox drive shaft and diff are in everything else needs work or a bit of touching up or more parts :S if you see some thing really f#*$@%d up please tell me as i have just gone off what i know its my 1st project
here is a list of what i'm doing in my 5 weeks off
New coil over springs for rear
bottom rear coil over bases cut down 10mm
make a seat mount made
make 5mm spacers made for rear coil over's
Make a proper bracket for coils
Get the radiator necks to suit the water pump necks and filler tube cut off re-welded weld all holes up
Paint water pump black
Paint rear coil over's
Make a gear ****
Put new bushing caps on tie rod ends and get new locking nuts
Have the rear axle nuts tightened up to spec
Find a Honda Accord lip and paint satin black
Silicone the sun roof/waterproof it then finish welds
Tidy up grounds and connect positive to starter
de-power the steering rack
Attached Thumbnails my s4 build! nz styles-sl370985.jpg   my s4 build! nz styles-sl371148.jpg   my s4 build! nz styles-sl371149.jpg   my s4 build! nz styles-sl371150.jpg   my s4 build! nz styles-sl371151.jpg
Old Dec 7, 2011 | 09:53 PM
nvmarx's Avatar
more
Attached Thumbnails my s4 build! nz styles-sl371152.jpg   my s4 build! nz styles-sl371153.jpg   my s4 build! nz styles-sl371154.jpg   my s4 build! nz styles-sl371155.jpg   my s4 build! nz styles-sl371156.jpg
Old Dec 7, 2011 | 09:59 PM
nvmarx's Avatar
more...
Attached Thumbnails my s4 build! nz styles-sl371158.jpg   my s4 build! nz styles-sl371159.jpg   my s4 build! nz styles-sl371160.jpg   my s4 build! nz styles-sl371161.jpg   my s4 build! nz styles-sl371162.jpg
Old Dec 7, 2011 | 10:03 PM
nvmarx's Avatar
and more i cant figure out how to up load them not as thumbnails lol
Attached Thumbnails my s4 build! nz styles-sl371163.jpg   my s4 build! nz styles-sl371164.jpg   my s4 build! nz styles-sl371165.jpg   my s4 build! nz styles-sl371166.jpg   my s4 build! nz styles-sl371168.jpg
Old Dec 7, 2011 | 10:22 PM
REAmemiya_fan's Avatar
Passion for Racing
Wow, I am loving this so far! Also, bet way to link images into posts is to use BBCode
Old Dec 7, 2011 | 10:26 PM
stevensimon's Avatar
Cool build but 4k nzd is about 3100 usd.
I'll follow its progress. Looks neat
Old Dec 7, 2011 | 10:32 PM
nvmarx's Avatar
cheers
ekk how did i get 6000 must have been away with the fairys lol sorry!!
Old Dec 7, 2011 | 10:34 PM
nvmarx's Avatar
cheers bud, you can tell im not much of a interior guy lol
what is this bbcode you speak of?
Old Dec 7, 2011 | 11:32 PM
sign up for a photobucket account photobucket.com
upload all of your pictures to that site.
then they give you a bunch of links that you can select depending on what you want to do. just click on the [i*mg]tag[/img] link and post it here and voila you have posted pictures
Old Dec 8, 2011 | 12:41 AM
Panda86's Avatar
Coming along nicely
Old Dec 8, 2011 | 12:43 AM
nvmarx's Avatar
cheers mate how is yours going, are you going injected or carby?
Old Dec 8, 2011 | 05:36 AM
Panda86's Avatar
carby if i stick with the 13b
Old Dec 8, 2011 | 08:50 PM
nvmarx's Avatar
what carby just a ida?
Old Dec 8, 2011 | 08:52 PM
Panda86's Avatar
Yep
Old Dec 23, 2011 | 07:11 PM
nvmarx's Avatar
i guess you can see my ghetto mods for the week lol i have bunged some of the holes in the floor and fire wall, spot welded my sun roof in place, rattle gunned my rear axles up tight, made a gear ****, started making a brake master stopper, took the radiator out to get it different necks welded on, cleaned and painted the block with heat proof saturn black for the stealth look... depowered my steering rack welded hole shut and painted
1 week down 4 to go next week i will be mounting the fpr and oil catch can most likely they will get painted black lol, make a seat mount because for some reason seats i bought second hand only came with 3 seat mounts, need to bung three more holes, get new tie rod ends and extra angle spacers put all the steering back together
o and that wooden thing in the photos was a trolley a made to try and wheel the car in and out of my tiny garage so i had some room in there but it failed the wheels cant support the weight and dont turn around lol so i will be making steel wheels for it soon
enjoy and laugh haha
Old Dec 23, 2011 | 07:17 PM
nvmarx's Avatar
Old Dec 23, 2011 | 07:44 PM
nvmarx's Avatar
and the older ones blowen up
Old Dec 23, 2011 | 07:54 PM
toyo kogyo's Avatar
Yip not many non turbo FC in NZ.seem to be prevalent in the US .I have gilmer gears on my FC but I'm running a standard donk/turbo apart from that.
I do miss my aircon though i must admit,kept the PS.
For my FC replacing the original factory 1990 exhaust for a twin stainless system made the biggest difference, teins all 4 corners made the difference on the track.
nice ride.what colour you thinking??
judging by the wheels in the front guards this is going to be either a pure racecar or are you fitting flares??
Old Dec 23, 2011 | 08:41 PM
nvmarx's Avatar
hey bro i want to get it cert and a wof one day so i have built it so it can fly through the day i end up getting there haha that pic the wheel was just sitting there i was trying to put the car up on the trolly with only one jack lol i just took a photo because it looked good, so it will be a weekend car and for the paint im going standard black s4 side trims with 10% gloss army tank grean paint black lip and black spoiler
Old Dec 24, 2011 | 11:40 PM
pontiackid's Avatar
Devil in the Details
Looking fantastic, any reason you didn't dreesup and refinish the engine compartment/firewall prior? Having that bueatifully done motor in their and then the upcoming(?) exterior paint job... seems out of place, keep it up!
