rx3 street/strip build
Old Aug 8, 2011 | 02:39 PM
gusfd3s's Avatar
E85 Addict
I bought this car back in 2006, i started doing a backhalf/4link conversion but the project was too big for me at that time since i had pretty weak fabrication experience, now a few years/cars later i feel im finally ready for this car (well, we'll see )
the car is a rust free -73 rx3, pretty rare here in sweden, only a handful that still is on the roads.. since i've already put the saw in it i thought i'd make a fun street/strip car out of it.. with the goal of having a street legal car, drive it to the events, run a 9 sec slip and then drive back home..
i have a a 13-rew engine and a fd tranny that i will use, engine management will be autronic sm4. 9inch rear, 4 link suspension.
im no expert what so ever so feel free to comment and help..
rx3 see the light for the first time in years.
time to take it to the garage!
first task was to determine ride height and put the chassis straight in all directions.
then i took alot of measures so i could put together a drawing for the rear suspension..
When i felt i was ready i finally could start fab the parts step by step.. here is the new crossmember
Old Aug 8, 2011 | 02:41 PM
gusfd3s's Avatar
E85 Addict
the frame rails for the shocks and front 4 link brackets
both frame rails welded
strange 9" housing
This is what i have done in the past few days, i will post updates when i get something done :-)
Old Aug 8, 2011 | 02:51 PM
Narfle's Avatar
Rx7 Wagon
Nice Welds!
Old Aug 8, 2011 | 03:55 PM
AuthoritySucks's Avatar
RollinRock
Sick **** bro!
Old Aug 8, 2011 | 04:53 PM
cfamilyfix's Avatar
I wish I could weld like that. I will get there one day. Nice work!
Old Aug 9, 2011 | 03:32 AM
gusfd3s's Avatar
E85 Addict
You will definately get there! Make sure you prep the pieces and make them fit 100%, it is easier to weld if you have good joints. The hardest part is not the weld but making the metal not distort/warp during welding, it is a time consuming work since you only can weld a few inches at the time and also need to think abou welding in the right sequence to make the shrinking forces pull against each other.
Im still learning these things, hopefully i can weld even better when this is done
Thanks for your comments.
Old Aug 9, 2011 | 10:55 AM
864angel112's Avatar
The build is nice, just like your fd.
Old Aug 14, 2011 | 06:12 AM
tegheim's Avatar
Subscribe'd :P
I will soon start my project again, and we shall put our brains together again
Old Aug 14, 2011 | 10:38 AM
Yellow Rx3's Avatar
yellow rx3
Awesome work and craftsmansip..
Old Aug 17, 2011 | 09:05 AM
sk8world's Avatar
Chasing numbers
make 2 of everything and ship the extra set to me! Thats the same reason mine is still sitting under a cover 2 years later
Looking geat man!
Old Aug 19, 2011 | 12:30 AM
RollinRock
She seems to be in good hands. Keep on keeping on
Old Aug 21, 2011 | 03:42 AM
gusfd3s's Avatar
E85 Addict
thanks guys,
I havn't had time to work on the car for some time but yesterday i welded the frame into the car and added some tubing.. also did some cutting to make room for bigger tires, the rear guards needs some work.. not in best shape.
I also bought an old CNC milling machine... my ambition is to make some fun custom car parts.. :-)
Old Aug 28, 2011 | 12:29 PM
gusfd3s's Avatar
E85 Addict
did some work today, this is very time consuming.. takes a lot of time to fit and weld since you dont want to warp the thin metal.
right side is done.
left side tacked ready for welding
when this is done i can center the tires and take measures for my 4 link bars.
Old Aug 28, 2011 | 05:53 PM
rotorholic's Avatar
DPG Burnout
Finally!!!! A nice build thread, Keep up the good work...
Old Aug 29, 2011 | 12:30 AM
13B-RX3's Avatar
7s before paint!!!
Looks great so far! That's the best way to learn, just jump in and give it a try!
Old Aug 29, 2011 | 12:20 PM
grn510uh8's Avatar
nice rx3 love the way you stretched rear qaurters
Old Aug 29, 2011 | 10:20 PM
freddyrx3's Avatar
Car looks awesome!!!!
Old Sep 7, 2011 | 11:46 AM
rx3gt's Avatar
Nice work
Old Sep 8, 2011 | 12:19 AM
NEthingJDM's Avatar
72' Rx2 Turbo
VERY IMPRESSIVE!!! Like what you've shared so far, can't wait to see how the project finishes up!
If you don't mind me asking, I was wondering what you used to make the sub frame out of :
1018 Steel? Gauge of material? and what you cut the material with? CNC, Waterjet, Laser, or Plasma cutter?
Oh yeah, one more thing. What type of welder are you using? Something like a Miller Aerowave / Dynasty Inverter?
Thanks in advance and look forward to seeing your next post!
Old Sep 8, 2011 | 02:10 AM
teddyrx2's Avatar
One Luv "Till The End"
looks nice bro, keep it up...
Old Sep 8, 2011 | 02:29 PM
ultimatejay's Avatar
Amen to that!
Everyone is tired of seeing Wacky put on new zip ties on his rx3 every other week.
Old Sep 9, 2011 | 02:23 AM
gusfd3s's Avatar
E85 Addict
thanks guys!!
the material of the frame is S355J2H, all the cutting is by hand with a small cutting machine and a band saw machine.
Im using a no-name china tig welder
havn't done much for the last 2 weeks, been working on my CNC milling machine.
my new 28" wheels
Old Sep 9, 2011 | 02:38 AM
1973rx3's Avatar
A.K.A. LuisGT
right side is done.
WOW you just don't know how many times i have dreamed about doing this to my 3. But it is definitively not as easy as it looks. Some day I'll get to it... my intentions are to increase wheel well, but not do a 1/4 chassis just an intergrated four link to a stock chasis. Very nice work keep it up!!!!!!!!!!!!!!
Old Nov 4, 2011 | 03:11 PM
gusfd3s's Avatar
E85 Addict
been doing some drawings on the new front suspension, i dont trust the stock one with some power behind it. I will try to make new struts, spindle, lower control arms and convert to steering rack.
http://www.youtube.com/watch?v=Fy6eq92dfcY
Old Nov 4, 2011 | 03:23 PM
13B-RX3's Avatar
7s before paint!!!
Very nice! I never was really happy with the way i modded mine and plan on switching it up next winter.
