6-7 psi primary and no transition to secondary
Old 10-20-10, 04:35 AM
Yes it's twin turbo...
*RX007*'s Avatar
Unhappy 6-7 psi primary and no transition to secondary
Ok a little background info. I did a complete vac job in 08' after completing it and still having secondary boost issues I just dealt with it. Now 2 years later Ive dug back into the problem.
I pulled the rack out and tested each and every solenoid with only 4 of them passing the "pressure" testes as per Dave Geesman's testing procedure https://www.rx7club.com/3rd-generation-specific-1993-2002-16/how-test-your-solenoids-actuators-other-turbo-stuff-802060/. I reinstalled the rack with all new check valves from Dale Clark and she started up and idled perfectly which she wasn't doing before. So I feel confident I did something correct and take her for a spin. The boost is spotty only boosting after decelerating and then wot. So since I had brand new check valves I tested the pressure and vacuum chambers, both passed and had no leaking. After a day or two of reading now, I go back out determined that it is the check valves. So I test them and the two I tested, the pressure and vac chamber check valves, both are leaking... so I test my old ones and they are holding fine. Thinking I figured out the problem I take her for a spin once more. The only thing that changed is I am getting a consistent 6-7 psi on the primary. I switched the wastegate and pre control connectors and had the same result. after that run I pull a line off the pressure chamber and no "hissing" sound is heard, also I am not getting any boost during neutral revs... I tested my cca and it is working properley but after doing a wot run past 4500 rpms with no boost there is a strange "byew" sound just like Dale Clark explains in this post https://www.rx7club.com/showthread.p...ighlight=bheyw
So this is where Im at
-No Hissing noise from pressure tank
-only 6-7pis primary with no secondary and strange beyw noise
-no boost during neutral revving
-all solenoids tested and important boost solenoids passed all bench tests.
-check valves are tested and pointing in the correct direction
-Vac and pressure tanks hold 25+ inhg no leaking
-99 spec turbos so I believe they have the restrictor pills built in.
I tried to be as detailed as possible and yes I have been searching for the past week on different issues with no luck.
Any positive feedback is greatly appreciated!
Old 10-21-10, 05:20 PM
*RX007*'s Avatar
Calling all RX7 Veterans!
Old 10-21-10, 06:31 PM
needs more track time
gracer7-rx7's Avatar
Have you gone through the primary turbo troubleshooting procedure from the autosport site?
http://www.autosportracetech.com/RX-...erOverview.htm
What were the results?
Your secondary probably isn't spooling since the primary isn't generating enough boost.
Old 10-25-10, 01:54 AM
*RX007*'s Avatar
The only thing I haven't checked yet, only because I thought it would be too simple of a fix is the intercooler hoses... I'll check them tomorrow. but would that have anything to do with the pressure chamber not releasing any air once I pulled a hose off it? Thanks
Old 10-25-10, 11:45 AM
No. That is probably more related to check valves or the chamber not being pressurized to begin with. At least that is what I understand from reading the autosport site.
Old 10-25-10, 12:31 PM
*RX007*'s Avatar
Agreed, And when I tested my brand new check valves they failed and my stock valves passed...
Old 10-25-10, 05:25 PM
LOL. Talk about luck...
I got the Viton check valves from Dale Clark. They don't leak at all.
Old 10-25-10, 07:59 PM
*RX007*'s Avatar
Ya no kidding! It would be who of any one to double check the new ones before installing them... Im going out now to check the hoses, I'll report back later.
Old 10-25-10, 10:08 PM
*RX007*'s Avatar
OK so I found a leak in one of the couplers
-Primary is perfect
-No Secondary transition
-Check valves have been re checked
-Pressure chamber does not hiss when unplugged
-charge control actuator is functioning properly at idle (ie the rod is pushed in)
-Vacuum at idle is 14 inhg
Old 10-25-10, 10:48 PM
T/Y Jesus! Re-employed!
Speeder165's Avatar
Now THAT is UGLY! Fix that sucker & see what happens. Should be interesting.
Old 10-26-10, 12:15 AM
*RX007*'s Avatar
I did, My observations are under the picture, My primary boost is perfect, but no secondary still...
Old 10-26-10, 07:10 PM
*RX007*'s Avatar
Ok update, just found that my vacuum chamber and pressure chamber hoses were switched, tricky bastards lol.
with that said my boost pattern as of 5 min ago is 11-7-14-8.... if that makes sense, spikes during the transition for a sec and drops to 8psi. my only Idea is that I used the silicone coupler that connected my secondary turbo to my intake to fix my cracked coupler from a few posts up. Im thinking that the turbo has no air restriction on the inlet side so it spikes. but like I said it drops down to 8 psi so Im not sure if thats the whole story... any insight?
Old 10-29-10, 01:00 PM
*RX007*'s Avatar
I ordered some hallmans, hopefully I can set it up like Damian, and control this spike...
Old 10-29-10, 04:24 PM
tnn
Spirit-R Fanatic
tnn's Avatar
hi
I have exactly the problem. I did a lot of search and replace a few things like duty valve among other stuff but still no luck. secondary never come on.
and my problem is after I upgrade to 99spec turbo.
so you're saying these 2 lines were switched? (please see pictures)
is it safe to switch them. I want to try my luck if it is the case for me too.
thanks
Attached Thumbnails 6-7 psi primary and no transition to secondary-img_1495.jpg
Old 10-30-10, 04:56 AM
*RX007*'s Avatar
No not those two lines, please refer to my picture, I circled the two lines I switched in RED
Attached Thumbnails 6-7 psi primary and no transition to secondary-vacuum_hose_diagram-switched.jpg
Old 10-30-10, 10:42 AM
tnn
Spirit-R Fanatic
tnn's Avatar
thank you. it's pretty small to see but I think I got the idea. but if you have high res please send me. Im PMing you...
Old 10-30-10, 02:20 PM
*RX007*'s Avatar
If your lucky, you will have the same problem, since its an easy fix. the tale tell sign is that when you turn your car off, and pull a line coming off the pressure chamber, it should hiss, if it doesnt you either have bad check valves or the two lines I circled are switched
Old 10-31-10, 12:02 AM
*RX007*'s Avatar
Its done! totally fixed now!!!!!!!!!!!!!!!! Im so stoked, I bought two hallmans, and set it up like damian, but I had to drill out my restrictor pills because they are built into the 99 turbos. I feel like rebuilding the engine would be an easier task haha
Old 10-31-10, 12:14 AM
tnn
Spirit-R Fanatic
tnn's Avatar
ah man... congrats.
the 2 lines that you said were switched, did you switch place them at the charge relief valve ? (H in the diagram) ?
thx.
Old 10-31-10, 12:20 AM
*RX007*'s Avatar
No H has nothing to do with it, the two lines I circled are the two lines were switched
Old 10-31-10, 12:28 PM
tnn
Spirit-R Fanatic
tnn's Avatar
yeah I understand. I just want to know where the 2 lines possibly got switched place in my case.
Old 10-31-10, 03:29 PM
*RX007*'s Avatar
Ya I couldnt tell you, all I can say is check and double check each line
Old 11-07-10, 11:46 AM
tnn
Spirit-R Fanatic
tnn's Avatar
I don't think I have the same problem then. I pulled the pressure chamber line and it hissed very shortly (less then 1s)
my problem is on 1st & 2nd gear I don't have secondary boost. after reach 4500rpm, boost drops and goes flat until redline. but I test and test on 3rd, 4th gear again and again, I do have boost after 4500rpm. eh... too scary to test on 5th gear but I assume it should be fine.
09-16-18 07:16 PM
ZacMan
09-19-15 09:20 PM
zxrazorxz
09-14-15 07:21 PM
Quick Reply: 6-7 psi primary and no transition to secondary
