Rising RPM Intake Adapter Kit
Old 07-05-12, 11:43 AM
RX7Racer46
RX7Racer46's Avatar
Hey everyone. I thought this was a pretty cool product and thought I would share it with everyone. I'm glad to see people like Mike are still thinking of ways to make new products for our cars. This adapter kit makes it possible to attach a third gen upper intake manifold to our S4 or S5 Turbo II's.
Don't really know what gains you could see from this product, but I like the concept.
Rising RPM
Attached Thumbnails Rising RPM Intake Adapter Kit-800_rrpm_2012b_intake_adapter_fd_to_fc_mounted_to_lower_and_upper_s4_1.jpg   Rising RPM Intake Adapter Kit-800_rrpm_2012b_intake_adapter_fd_to_fc_mounted_to_lower_and_upper_s4_2.jpg
Old 07-05-12, 02:32 PM
Trunk Ornament
AGreen's Avatar
There are all kinds of reasons to do it, but I'm going to be going down that path because the FD throttle body has a full range throttle position sensor. I hate having to rely on MAP rate of change to tune the accelerator pump on my ECU. It's just not fast enough for me.
Old 07-05-12, 04:27 PM
Boosted. I got BLOWN!!!
beefhole's Avatar
^which ECU do you use that you can't run a TPS? Any map sensor is probably not fast enough for accelerator pumps.
Old 07-05-12, 07:27 PM
Trunk Ornament
AGreen's Avatar
Since the S4 TPS is only a narrow range, it makes it hard to use the TPS to run the accelerator pump. With a megasquirt, the accelerator pump can be based on either TPS or MAP rate of change. I have it set to 100% MAP right now, and there is a quick lean spot any time I stomp on the gas, so that's got to be fixed
Old 07-05-12, 08:42 PM
beefhole's Avatar
^OHHHHHH You don't know about me sir. I made the S4 TPS work, with my standalone. This of course was after EVERYONE said it wouldn't work. On top of all that, I kept the stock OMP.
Old 07-05-12, 08:50 PM
Retired Moderator, RIP
misterstyx69's Avatar
I ordered that kit the first day it came out.I am just waiting arrival on it.
when the car had an fd upper(before on an old setup) it went like Stink!..when it was working!
Trunk Ornament
AGreen's Avatar
Yeah, I know about that. Unfortunately, you can't guarantee that your cam is going to make the plunger extend from completely shut to completely open in a completely linear way.
Old 07-06-12, 05:59 AM
beefhole's Avatar
Actually, I can guarantee that. It works fine. With a standalone, you can calibrate the TPS as necessary.
Old 07-06-12, 11:49 AM
Trunk Ornament
AGreen's Avatar
My EMS plots a linear graph between full open and full closed. The TPS calibrator is a window that pops up and has you take the current reading closed, then take the reading open, and it does the rest. It doesn't let you plot anything in between unfortunately.
I'm going to give it a shot anyways. I enjoy throwing caution to the wind and seeing what turns out. How far off can it be anyways?
Old 07-06-12, 07:05 PM
n.taluckder's Avatar
i have a haltech e6k can i calibrate the fd tps to work with my s4?
Old 07-06-12, 08:23 PM
beefhole's Avatar
^Yup.
Old 07-14-14, 12:39 PM
fc323's Avatar
Is there anywhere else I can get these adapters?
website isn't working
Old 07-14-14, 01:18 PM
Ban Peak
Molotovman's Avatar
Website is under construction, no current sales.
Rising RPM - Home
Old 07-14-14, 05:35 PM
barkz's Avatar
just under construction, gonna have to wait it out dude. no biggie.
Old 07-14-14, 11:00 PM
This sh*t burns oil!
SpikeDerailed's Avatar
Being patient is hard I want to buy some fuel rails.
Old 07-15-14, 12:46 PM
lowjack7's Avatar
im also waiting for the site.. please hurry
Old 07-16-14, 03:27 PM
T2 Duo!
tuscanidream's Avatar
It's been under construction for a long time, and he hasn't responded to anyone's questions since. Simply disappeared.
Order these fuel rails from ffe. They are a similar product, but come in an instead of the stupid npt like risingrpm.
FC3S 13B-T Rail Set | Full Function Engineering
Old 07-16-14, 04:04 PM
fc323's Avatar
So is there anywhere else?
seems like it isn't coming back..
Old 07-16-14, 04:20 PM
Auto-Ex Noob
fast87t2's Avatar
If someone can provide me with a sketch of the bolt pattern and Port locations on the FD manifold I can make some for cheap. I have made many parts for my rx7.
Old 07-16-14, 05:55 PM
FC guy
Rob XX 7's Avatar
one area you may want to weld and add material and some port matching- done.
No need for an adapter
Old 07-16-14, 08:24 PM
Red Pill Dealer
TonyD89's Avatar
Received 3,757 Likes on 2,573 Posts
If you are really ambitious, you could do some tracings of the two different manifolds and apply them to a simple flat plate aluminum, drill the biggest hole you can to get the stock out, and then go at it with a dremel. The screw holes could easily be done by transferring and using a drill press. You would probably want at least a couple screw holes first to align the tracings.
I bet the end result would be the same performance wise.
Old 07-16-14, 09:17 PM
fc323's Avatar
Or I could go with this alternative solution
I'll be getting it in about a week, I can provide the measurements when it arrives
Old 07-16-14, 10:13 PM
barkz's Avatar
and youre in NH!? why do i not know you lol
Old 07-17-14, 05:59 AM
Auto-Ex Noob
fast87t2's Avatar
Sounds like a plan. I look forward to it. Seems like it will be pretty easy to machine.
Old 07-17-14, 06:12 AM
lostFC's Avatar
I have this adapter. You would need to machine offset studs too... Not so easy.
Quick Reply: Rising RPM Intake Adapter Kit
