Mariah Cold Air Box, Before/After
Old Dec 28, 2008 | 07:29 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Today I found time to do the trimming, etc to install this little jewel. Below find before, during, and after pictures. Key exception, I didn't take a picture of the Air Box before I did my cut and trimming. Just know everywhere you see a hole there wasn't one when you receive yours.
Key install play, get some cardboard and cut a couple templates in the same shape as the Cold Air Box itself. There are trial and error compare-and-mark as well as eyeball-and-mark exercises in massaging to fit your particular set up. If you mess up, all you've messed up is some cardboard rather than a $150 part (fiberglass formed panel).
Picture #1 & 2 is what the Cone Filter area looked like before I started anything.
Picture #3 is what you'll get and need to install one with one exception. That being an adaptor I had made to replace the MAFS when I put in my computer.
Picture #4 & 5 is after cut and trimming has been completed and all installed.
Attached Thumbnails Mariah Cold Air Box, Before/After-002.jpg   Mariah Cold Air Box, Before/After-005.jpg   Mariah Cold Air Box, Before/After-004.jpg   Mariah Cold Air Box, Before/After-006.jpg   Mariah Cold Air Box, Before/After-007.jpg
Old Dec 28, 2008 | 07:34 PM
HOZZMANRX7's Avatar
More after pictures.
My conclusion from all this. it was a bit intimidating before I started, given the need to pretty much free hand cutting of holes for the FMIC Pipe and Intake Pipe. But taking my time and with the only evidence where I eyeballed/guessed wrong is the cardboard, wasn't so bad afterall.
I'd do it again with out hesitation. It really wasn't that difficult, and the idea of insulating my air intake as much as possible from hot engine air is obviously a good thing.
Attached Thumbnails Mariah Cold Air Box, Before/After-008.jpg   Mariah Cold Air Box, Before/After-009.jpg   Mariah Cold Air Box, Before/After-010.jpg
Old Dec 28, 2008 | 07:46 PM
fc3s91's Avatar
R.I.P Mark( Icemark )
Looks good.. But I wish the engine bay was washed
Old Dec 28, 2008 | 07:47 PM
need RX7's Avatar
Listen to King Diamond.
Nice.
Old Dec 28, 2008 | 11:28 PM
finishline's Avatar
Not Even Foo
looks awesome mr. hozzman.
Old Dec 29, 2008 | 12:58 AM
HOZZMANRX7's Avatar
Forgot to mention. If you get the (their) K&N cone filter set up and running stock otherwise, much easier install as the needed cut outs for the filter and Air Pump hose is marked out. That install would look just like what you see on their web site.
Old Dec 29, 2008 | 02:39 AM
JustJeff's Avatar
Apex Seal Treachery!!!!!!
Good stuff!! I'd love to see some air temps before and after.
Also curious, is that the Attain vented cover?
Old Dec 29, 2008 | 08:25 AM
RxFuel's Avatar
Ten cents gets ya nutz!
nice pics and set-up, I have been looking to get one of these for awhile
Old Dec 29, 2008 | 11:29 AM
HOZZMANRX7's Avatar
It's an RE-Amemiya vented replacement for the stock TII scoop. Hard to find.
Old Dec 29, 2008 | 03:30 PM
Rob XX 7's Avatar
FC guy
I wish there was more room to bring the air filter in front of the radiator support, but I just cant see a good clear run unless you did not have the stock headlights
Old Jan 4, 2009 | 04:31 PM
HOZZMANRX7's Avatar
Correction. I thought you were talking about the reverse vent on my hood which I just realized wasn't pictured.
I don't know who made the headlight covers. I bought them from another forum member (ALL IN<SCRIPT type=text/javascript> vbmenu_register("postmenu_8755675", true); </SCRIPT> ). Only needed minor tweaks to get them to fit right, and I like the size of the opening as well as the fact it's raised which would seem to capture more moving air than a recessed one.
Old Jan 5, 2009 | 02:37 PM
RxFuel's Avatar
did have to drill any holes to screw it in? or did it fit where others were located?
Old Jan 5, 2009 | 03:12 PM
HOZZMANRX7's Avatar
The mounting brackets that come with it make it a direct bolt in into existing body nuts. The only drilling/cutting is to deal with the intake pipe, smog pump pipe, and if applicable FMIC pipe.
Old Jan 5, 2009 | 03:58 PM
RxFuel's Avatar
cool cool thanks for the help, I feel more comfortable about making this purchase at least knowing what I need to do.
Wolf_
Aug 11, 2015 04:23 PM
