What Is This Thing For?? *Pic*
Old Dec 1, 2004 | 02:30 PM
Glazedham42's Avatar
Resurrecting Gus
Hey guys,
The purpose of this thread is pretty self explanatory. What is this little silver thing for? I am running an emissionless setup on my car, so can I remove this thing? What is its purpose? Waiting with much anticipation.....
Old Dec 1, 2004 | 02:38 PM
riofrio's Avatar
This IS a tasty burger!
What are we looking at here... is this the back of the engine?
Old Dec 1, 2004 | 02:46 PM
Alex-7's Avatar
That little silver thing on top of that inspection plate with the wire coming off it? I don't know what the hell that is either. I never installed it on my new motor and havent missed it.............
--Alex
Old Dec 1, 2004 | 02:47 PM
Feds's Avatar
More Mazdas than Sense
that's a condenser. It cleans up the electrical signal to your tach.
Old Dec 1, 2004 | 02:48 PM
DAVID GRIMES's Avatar
How About A Cup Of STFU
It might be one of those things that pop out when it's done.
Has that engine been used as a boat anchor in salt water before ? It might be a barnacle or zebra mussel or bearded clam. Be careful removing it.
Why do you want to remove it ? I can't tell the position of your picture either.
Old Dec 1, 2004 | 02:51 PM
Hades12's Avatar
Burning Oil-Grinding 3rd
Correct.
Old Dec 1, 2004 | 02:59 PM
IanS's Avatar
Ricer
Mine is also off and I havent noticed a difference in any function whatsoever. UNLESS it keeps your tach from sticking when its cold but I doubt it.
Old Dec 1, 2004 | 03:04 PM
Alex-7's Avatar
A small price to pay for such significant weight reduction, I bet you'll be able to scratch third without that thing...............
Or you could keep it and fill it with NAAWWZZZZZ
--Alex
Old Dec 1, 2004 | 03:09 PM
IanS's Avatar
Ricer
Oh man why didnt I think of that. CRAP
Old Dec 1, 2004 | 03:12 PM
CarlRx7's Avatar
i got one too. its not hooked up. just layes there. hmm tach works fine.
carl.
Old Dec 1, 2004 | 03:35 PM
builder7's Avatar
The purpose is to mellow out the make-and-break of the points, cutting down on the spark arcing and making the points last longer.
Old Dec 1, 2004 | 04:43 PM
--Alex
If you remove it, you will gain horses from lightening the load on your alternator. I think JCWhitney makes a mechanical replacement that piggybacks along for the ride on your OMP and makes your tach needle WANT to be somewhere else (for unbelievably fantastic throttle response).
It also somehow ( patent-applied-for proprietary info ) reduces the parasitic loss from your Speedo cable... inversely adding measurable torque to your wheels.
HORSES AND TORQUE AND RESPONSE... OH MY !!!
Old Dec 1, 2004 | 07:19 PM
Resurrecting Gus
Ok, so we've had quite a bit of input, but after all the jokes and suggestions I am still at square one. Do I need this thing? What is going to happen if I take it off? Is my tach gonna jump around like crazy?
I want to take every single thing out of the engine bay possible. Not so much for weight, but just to keep things clean and simple. To all you jokesters, I realize that removing this isn't going to make my car any faster. I just hate having everything look clutttered in there. Nothing's better than a clean engine bay.
Old Dec 1, 2004 | 08:02 PM
Rx7carl's Avatar
Airflow is my life
It is what they say. I dont have mine in either car IIRC and no problems. You could always save it and put it back on later if you need to. It might be for RFI suppression so you dont get static on your radio. I dont have a radio in either car so not sure if that affects the function or not.
Old Dec 1, 2004 | 08:05 PM
IanS's Avatar
Ricer
I have an amp running my highs and my bass and I havent heard any extra alt whine so it should be ok to remove.
Old Dec 1, 2004 | 09:45 PM
Seriously, mine is long gone. No jumping tach and no radio interference ( use good plug wires, though ). Like Carl and Ian say, just take it off and save it. I bet you'll never put it back on, though.
Old Dec 1, 2004 | 09:48 PM
Sterling's Avatar
Nikki-Modder Rex-Rodder
From: Trying to convince some clown not to put a Holley 600 on his 12a.
I thought that sucked in the residual electric charge from the the ignition. Seems to me this would better help the coils to charge when they were s'possta, etc.
"Oh Jeffy..."
Old Dec 1, 2004 | 09:50 PM
Resurrecting Gus
Yeah, where's Jeff20B when you need him
Old Dec 1, 2004 | 09:57 PM
I am anxiously awaiting this "residual electric charge" from the ignition explanation. So it's like a little lightning rod to ground ?
Skeptical but uncertain , here.
Oh, Jeeeeeffff !?
Old Dec 1, 2004 | 11:08 PM
Alex-7's Avatar
NO!
Old Dec 1, 2004 | 11:37 PM
gsl-se addict's Avatar
Super Moderator
There are two separate condensors in the engine bay. One is on the distributor and it is for the ignition system. The one that you guys are refering to is actually connected to the oil pressure gauge. Mine is no longer connected either because the wire to the condensor broke. I have not noticed any ill effects from having it disconnected.
Kent
Old Dec 2, 2004 | 03:00 AM
Jeff20B's Avatar
Lapping = Fapping
You didn't need my help in this thread afterall.
Old Dec 2, 2004 | 06:36 AM
Resurrecting Gus
NO!
Haha. Now that's what I'm talking about. Thanks!
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
