In need of Help!!
Old Apr 2, 2018 | 10:52 AM
Medevack1's Avatar
In need of Help!!
Hi Guys Im in need of wisdom and HELP!!, I'm located in Winston Salem NC , I don't know much about Rotaries but willing to learn. If there are some Rotor Heads that would like to come over to my house and help me tune this 12a I'll have a case of BEER waiting.... Im dying to take it out on the road!!!!!
The car will start on the 1st crank even when its snowing, after the electric choke goes off the car idles but is not smooth is jumpy, I did noticed that the rear rotor exhaust was glowing red I have a 1984 12a, Racing Beat Intake with Holley 600 (New), Racing beat full exhaust and MSD coils.
Old Apr 2, 2018 | 01:39 PM
Medevack1's Avatar
56 people viewed and no one knows......
Old Apr 2, 2018 | 01:49 PM
Molotovman's Avatar
Ban Peak
Have you checked timing and verified both ignition coils are good? Most of the time a cherry red header is because you're running too lean, too much air or too little fuel, sometimes timing related too. Check the ignition components and timing, if they're good you're probably not getting enough fuel through that carb to the rear rotor.
Old Apr 2, 2018 | 02:03 PM
Medevack1's Avatar
Thank you.
Old Apr 6, 2018 | 01:41 AM
rotorholic's Avatar
DPG Burnout
What he said ^^^ I was going to say timing, also check the fuel bowl level on the rear rotor, If its too low, It will run lean
MulletsRX7
Apr 3, 2004 01:39 PM
tonyttt
Jan 12, 2004 11:44 PM
ejmack1
Jun 18, 2002 01:31 PM
79+80_rx-7
40
Apr 10, 2002 12:33 PM
