Gas Door Wont Open
Old Sep 5, 2014 | 10:22 AM
Cyris426's Avatar
Gas Door Wont Open
Hey guys,
So after the dash swap and some other random stuff my gas tank door wont open. I need to to open to paint inside it. It looks like there is an electronic control module right beside it underneath the cars outer body. What can i do to get this door open?
Thanks
Old Sep 5, 2014 | 10:51 AM
dougingraham's Avatar
GSL-EV
I think you can just put 12 volts across the terminal and it will pull in the pin and let the spring pop it open. All the switch does is energize the wire that runs back there. You are going to want to figure out what you didn't get reconnected in the dash swap and fix that.
Old Sep 5, 2014 | 12:36 PM
Jeff20B's Avatar
Lapping = Fapping
You're just needing to open the door to paint inside it, right? The most obvious is to reach in from the hatch and pull on a small metal tab. Look for it. Remove the panel if necessary. This manually pulls the solenoid so the gas door opens. Every RX-7 owner should know about this.
As for fixing the electronics, good luck.
Old Sep 5, 2014 | 01:04 PM
rwatson5651's Avatar
79 w 13B4port
My memory is vague, but I was thinking the manual pull was accessed by removing the left rear tail light.
Old Sep 5, 2014 | 01:39 PM
mazdaverx713b's Avatar
Have RX-7, will restore
No need to remove the left tail light. Just reach in behind the carpet and behind the wheel well cover you will feel the release tab for the gas door release actuator. Pull it and the gas door will open.
If you have an 84 or 85, check to make sure you didn't swap the gas door and hatch release connectors. If you plug them in backwards I would think that your fuel door will not open, nor would the hatch. Give that a try and let us know what happens.
Old Sep 6, 2014 | 02:07 AM
Cyris426's Avatar
They prolly are connected backwards. I looked at them earlier and they are both connected but they are the same looking. I will swap them around and post the result.
thanks
Old Sep 7, 2014 | 02:29 AM
Cyris426's Avatar
So what it ended up being was they were connected backwards! Every other connector under the dash does not allow this. This one does however.
Thanks.
Old Jan 12, 2018 | 05:14 PM
hoang5659's Avatar
does anyone know where i can get a direct replacement actuator solenoid for the fuel door? mine is seized and will not work. i had to manually open the door and now the solenoid is stuck in the open position.
Old Jan 26, 2018 | 09:51 AM
DreamInRotary's Avatar
Always Wanting to Learn
Just buy a used one from a part out in the 1st Gen Classifieds section.
Old Jan 26, 2018 | 10:47 AM
rxtasy3's Avatar
WD=40 is your friend.
Old Jan 26, 2018 | 10:53 AM
Freeskier7791's Avatar
+1 you can pry the tabs holding the actuator together apart, and clean everything up. I lightly sanded mine and put some grease on it, works great!
