Has anyone installed an aftermarket FPR with stock fuel lines all around including the rails? I will have a Rotary Performance aftermarket secondary Rail they have in store. That Rail is for the use of the stock banjo from the Primary Rail. But I want to ditch the stock FPR and install an aftermarket one since I am aiming at numbers that the stock FPR cannot take.
Someone lead me to the right direction and step by step process.
The easiest would be something like Earls Vapor Guard hose ends: https://www.holley.com/products/plum...ard_hose_ends/ These would allow you to clamp the 5/16 hose on the end of the stock feed/return like normal and use rails which accept AN fittings.
Not sure what you want to see as there isn't much to look at. You just remove the stock fpr, tap it to accept the fitting I mentioned above, then you run whatever -6 fitting off it you want to your new fpr. I will upload a few pictures but there really isn't anything to see. What is it you're not following along with?
