Havoc's - Aussie built wide body, 13B-RE powered by gtX3582
Old Sep 7, 2016 | 07:29 PM
  #101
Havoc's Avatar
Shainanic: yeah the TR6060 is like the magnum so is the better box regardless.
Input shaft is spot on, all I had to get was my clutch plates changes to suit the new input spline.
using the stock hydralulic clutch slave (so no more forks) - but ive not got that up and running yet.
(I alrteady had this clutch so just got the plates redone.
Rotary to Tremec T6060
Old Sep 23, 2016 | 02:45 AM
  #102
Havoc's Avatar
Well thanks for the haltech boys in the haltech thread but I got my drive by wire setup to work a treat.
So 90mm LS3 throttle body - Holden VF peddel. Looks so clean
Old Dec 10, 2016 | 03:56 PM
  #103
Darryl C's Avatar
What's does the box shift like at high revs, are you happy with the swap.
Cheers
Old Feb 17, 2017 | 08:34 AM
  #104
metalCORE's Avatar
How did the change the driveability, idling and so on? I think the GM DBW tb doesn't have that bypass and no adjustment screw...?
Old Feb 21, 2017 | 02:23 AM
  #105
Havoc's Avatar
Hi guys.
A few updates good and bad.
I killed the diff on the dyno so wasnt able to see the full potential of the E85.
I still got 401rwhp at 13.5 psi for the BP98 pump fuel.
Ive now changed the diff and fixed a few minor issued but havnt changed the fuel out yet to thrath it about.
Box: Feels great so far. Its so nice having a long first gear, doesnt feel useless like the old box. No need for 6th yet haven't tried that high rpm shifts yet but was fine on the dyno at 8000rpm.
DBW: Love it. doesn't need any screws or adjustments as the computer just opens it a little bit to do all the idle control. I live on a steep driveway and when the car was cold if I reverse out it would always stall when getting to the top when decelling off the pedal. Doesnt do it now, very happy.
Also the haltech 1500 does closed loop control on the throttle, so it will constantly change the % its open to keep the set rpm. Even with a 90mm single TB blade it will idle at 900rmp no problems.
The tuner didnt even know it had DBW as it feels so normal.
I need to fix my decel rates, getting some flames as next to no effort right now.
But - the down point is I still need to get the tune fixed. I did stuff one bit up.
https://www.youtube.com/watch?v=QDDl...ature=youtu.be
Old Feb 21, 2017 | 07:24 AM
  #106
KNONFS's Avatar
B O R I C U A
Originally Posted by Havoc
Hi guys.
How did that happen on the DYNO? Got power?
DBW is the future, but I am broke, and don't want to change my setup
Old Mar 7, 2017 | 07:53 PM
  #107
Havoc's Avatar
Well small update as had the car back for a bit now.
So looks like the tail shaft I had manufactured was slightly to long (3-4mm) and is the reason the diff died. I never picked it but lucky the workshop that did my repairs did. Ah well live and learn
No damage to the gear box. put in another diff and been cruising about.
Drained the E85 out as the tune wasn't complete and put the pump back in.
Shes' running great.
TR6060 - Love it! the long 1st gear is awesome! Haven't used 6th yet. Clutch feels really good but its still very short in the pedal throw. no issues with 8000 rpm. reverse lock out is working a treat. I do need to get a signal generator to make the dash spedo work.
DBW - Again love it. Flawless on the idle, even on the Decel where I use to have an issue is a prefect. no issues at all with low speeds and pottering about - people use to say having a large single would be **** to drive. I haven't noticed that at all.
Anyway will try to get some video's soon. Just bought another house so will be moving soon and short on cash for a bit...
Old Mar 13, 2017 | 08:02 AM
  #108
KNONFS's Avatar
B O R I C U A
NICE!
Which turbine housing are you running, 1.0? How much boost are you planning on running? Where you running a boost controller on that 13psi dyno pass?
Old Sep 21, 2017 | 05:17 AM
  #109
Havoc's Avatar
1:00 AR mate. just the haltech boost controller.
below just some pics
from the weekend.
Old Sep 25, 2017 | 10:11 AM
  #110
WondrousBread's Avatar
Tenured Member: 5 Years
Your build is very impressive. I'm not usually a fan of widebody or blue paint, but your car really pulls it off.
Also, that engine bay is second to none. Just a work of art.
Old Aug 1, 2018 | 12:20 AM
  #111
Havoc's Avatar
Well a bit of an update. Back in May while out driving, looks like a fuel line failed. Fuel got on the exhaust and I had an engine bay fire.
Scared the **** out of me. Lots of damage even thought it didnt look that bad. Insurance and I after some discusssions we seattled on a payment and Ive been slowly pulling it all appart doing a rebuild.
Destroyed wiring loom.
Dead Engine
Potential damage to the turbo.
Damage to the paintwork.
Etc Etc.
So updates to come. Im logging this all on a facebook page now. But currently working on:
https://www.facebook.com/Mantrx7-152...posts_to_page/
Pulled the engine - Parts look ok no major damage
Pulled the interiour (had a burnt smell)
Rewiring the car and adding a PDM and doing the loom's as best I can.
Will rebuild the engine.
Hopefully a new Exhaust manifold.... I want Elliots from turbosource but it doesnt fix dual 44mm wastegates..
Repaint the engine bay - Im thinking a white now
Rapaint the car - Is cheaper to repain the full car then fix the air brushing
So updates to come
Old Aug 3, 2018 | 02:17 AM
  #112
Havoc's Avatar
new wiring design ongoing
https://www.facebook.com/pg/Mantrx7-152827368654152/posts/?ref=page_internal
Old Aug 3, 2018 | 05:19 AM
  #113
KNONFS's Avatar
B O R I C U A
Sorry to hear that, glad your are sticking to it!
Old Aug 6, 2018 | 06:51 PM
  #114
Havoc's Avatar
yeah I thought about calling it quits. it was a ok payout (could have bought another car for it) but I was bored while it was away.
Anyway started the new loom yesterday
https://www.facebook.com/152827368654152/photos/a.250952862174935.1073741834.152827368654152/260600771210144/?type=3&theater
Old Aug 18, 2018 | 05:13 AM
  #115
Darryl C's Avatar
Just going back to your TR6060 choice, was your donar the VE series GTS and not the VF GTS supercharged trans (do you know the" tuet "number) They have different length front shafts and with some issues around the QuickTime BH length it would be handy to know as your swap worked sweet.
Cheers
Old Aug 18, 2018 | 04:26 PM
  #116
RGHTBrainDesign's Avatar
I have a bunch of information on doing a proper Tremec Magnum (NOT TR6060) for a 13B on my build page.
I'll connect you to the right people if you're still on the fence. Still need to find the input shaft dimensions so I can properly Wire EDM my clutch center cam (ORC559D).
Given my 4.56 Final Drive Ratio and 25" to 26" tall rear tire configuration (haven't decided on final size yet), the TUET11009 is my transmission of choice with a longer 1st gear and 6th gear OD that's actually usable.
Old Aug 19, 2018 | 07:33 AM
  #117
Havoc's Avatar
Cheers
Darryl, ill check for ya.
I did a write up here of it all.
T56 TR6060 to FC3S conversion - AusRotary
I "think" it was the tuet11009. but let me check
-Anth
Old Aug 19, 2018 | 07:35 AM
  #118
Havoc's Avatar
feels like I havnt progressed but wireing is slowly progressing
Old Aug 19, 2018 | 07:32 PM
  #119
Darryl C's Avatar
-Anth
Cheers that would be great. I had read your write up on Aus Rotary but could only find your reference "HSV GTS". Seeing I'm down this end of the world I would like to use a local box as well. Your adaption went really well.
Big job ahead by the look of it with the wiring, good luck.
Darryl
Old Aug 23, 2018 | 05:11 AM
  #120
Havoc's Avatar
What I have
Old Aug 23, 2018 | 08:14 AM
  #121
Jager's Avatar
Tear you apart
Awesome build.
I also think that living in Perth driving an RX-7 sounds sorta like heaven!
Old Sep 28, 2018 | 07:32 AM
  #122
Havoc's Avatar
https://www.facebook.com/mantrx7/photos/pcb.288484908421730/288484515088436/?type=3&theater
Very happy how the LIM and UIM came back up after all the fire damage!
Old Sep 28, 2018 | 07:34 AM
  #123
Havoc's Avatar
progress on the loom is slow but getting there
https://www.facebook.com/mantrx7/photos/a.250952862174935/280557449214476/?type=3&theater
Old Oct 18, 2018 | 08:17 AM
  #124
Havoc's Avatar
plates came up well
https://www.facebook.com/mantrx7/photos/pcb.294063607863860/294063591197195/?type=3&theater
https://scontent.fper3-1.fna.fbcdn.net/v/t1.0-9/44031570_294063597863861_3867430256897949696_
Old Nov 9, 2018 | 12:06 AM
  #125
Havoc's Avatar
Well engine bay now al painted
https://www.facebook.com/mantrx7/videos/2172404562974440/?t=23
