20B Carbon
Old Jun 29, 2017 | 09:08 PM
20b Carbon's Avatar
They have created special CNC spindles for the steering rack to compensate for bump steer and they supplied lengthened end links for the stabilizer bar.
We will show them once we do the install.
Old Jun 29, 2017 | 10:18 PM
LoU "hOw Ya Do"'s Avatar
never fear, I is here
what did they do that was custom?
Old Jul 1, 2017 | 01:11 AM
racingdriver's Avatar
The consensus on the forum is most people were disappointed with the bumpsteer on these units. From what I have researched Defined auto has the best solution , unless you do what I did and move the firewall 7 inches back.
Old Jul 1, 2017 | 11:44 AM
yeah there def isnt an easy way of doing this swap if you move the rack im also having some issues with the xcessive kit and the bumpsteer issue
Old Jul 1, 2017 | 01:49 PM
RCCAZ 1's Avatar
So, the 2-in-1 diff brace works with the oversized Greddy rear diff cover? I've been holding off ordering the cover since I thought there might be fitment issues. Would be interested to see a pic with the bolt holes lined up, when you get a chance. Thanks!
Old Jul 2, 2017 | 04:25 PM
20b Carbon's Avatar
Bump Steer
Can you describe what was causing your issue?
Old Jul 2, 2017 | 04:27 PM
20b Carbon's Avatar
Bump Steep
Originally Posted by gmonsen
Yep. That's what several of the earlier conversions did. Chris Carlisi used to work for me and did most of his build in my garage. I had a chance to see what went into cutting the firewall and moving the motor back behind the rack. I drove Phil Hamlin's 20b when Peter Farrell was tuning it and Peter did the same thing. Some people adjusted the transmission, because it does move the shifter back otherwise. I am very happy with the Defined Autoworks mount setup and don't think handling is effected at all, but I could be wrong. My NA setup lightens the front end considerably and that may be part of it.
Gmonsen can you describe what was causing your issue as well?
Old Jul 2, 2017 | 04:33 PM
20b Carbon's Avatar
2-in-1 Brace
We are currently working on polishing the lower front and upper rear control arms and then having the powder coated clear. Once they are completed we will be working on the Rear Diff and we will show this for you.
Old Jul 2, 2017 | 05:19 PM
20b Carbon's Avatar
93 RX7 polishing Control Arms
Here is what we have been working on for the past few weekends.
Dissembled the front driver and pass suspension.
Lower control arm removed from the knuckle.
Removed the bushing
Completely dissembled.
Stage 1 of the cleaning and sanding
Stage 3 sanding
Stage 4 polishing
Stage 1-2
Stage 3-4
Stage 4 polishing
Rear Knuckles bushings pressed out and cleaned
Prepped for painting
Old Jul 5, 2017 | 06:44 PM
20b Carbon's Avatar
Follow Up
Just a note. I used one of their subframes with the spindles you speak of and was not that happy. I ended up with motor mounts made by Defined Autoworks that have no bumpsteer. They could have changed something in the last few years, but it is not clear to me that this could ever be made to truly work without issues. It's very nice, but I was extremely focused on handling rather than power (an NA 20b) and so this was very important to me.
Ok, I spoke with Adam from Rotary Engine.com
He explained that they have made changes to their system to fix the issues you might have experienced in the past. Anytime the steering rack is relocated, moved or adjusted for the fitting of the 20B, they will need bump steer adapters. Now each company will have their own design to accomplish extending the spindles and relocating the tire rods, but we feel that ours is the best to do this and we stand behind our product and will work with you to get it right.
We have shops and people come back for these who used them before which tells us they are perfectly happy. We have clients that use the kit for street to race.
Now, I know that Adam stands behind his product and once we cross this bridge that you are talking about I will post what we did to make this work.
Old Jul 5, 2017 | 07:04 PM
20b Carbon's Avatar
Update 7-5-17
So we completed what we could this weekend and sent out the arms for powder coating.
The knuckles are painted and ready to go.
One last final cleaning and prepped for the powder coat.
Old Jul 5, 2017 | 09:03 PM
yeah its the same on my end and my rack isnt even dropped as much as that kit but it all comes down to the bumpsteer issue i wonder if the bumpsteer kit from them would work on mine if its better
Old Jul 6, 2017 | 10:55 PM
20b Carbon's Avatar
Hey LOU,
Once we complete the install we can give you more info on this. I understand and we spoke with so many different companies about this and each had their own way of doing it. Some we liked and some we didn't. We felt that any modification to the oil pan was not really the direction we wanted to go. We have pondered on do the dry sump but that would entail us losing the AC. We live in Texas and Hell No on that LOL. So we just felt that what Adam does works. There are a few things that we have to do to make it work correctly. Adam is sending us a list of instructions on what has to be done. We will post everything we do to help everyone we can. We are trying to create a car that is Street and Track worthy. Not Drag.
Thank you for you concerns and following us on the journey.
Old Jul 7, 2017 | 05:52 AM
that would be awesome thank you
Old Jul 7, 2017 | 11:48 AM
THE TECH's Avatar
RedSuns Unite!
Are the Carbon Creations parts still available?
Old Jul 9, 2017 | 09:41 PM
20b Carbon's Avatar
Update 7-9-2017 Rear Diff
So this weekend we worked on the rear diff. We disassembled the axles and check all aspects of the diff. Once we confirmed everything met spec we reassembled them and repacked the CV Joints, place new boots, added the Greddy large capacity diff cover and attached the 2-in-1 diff brace. We are still waiting on our arms to arrive back from powder coating. Once in we will start the the reassemble of the suspension.
Step 1 Chemical wash rear diff to remove all the oil and built up dirt
Step 2 Power washed rear diff
Axle removed from pumpkin
Axle cleaned and ready for reassembly.
Pumpkin painted
CV bearings cleaned
Repacking the CV joint and bearings
Rear diff reassembled
Factory diff cover removed and inspected
2-in-1 brace installed (now this is not as easy as it looks it is a very tight fit, but it works great, i do not recommend doing this with the diff attached to the car because you have to put the cover and brace on at the same time.)
Greddy high capacity cover
Fully assembled and ready to go.
Old Jul 9, 2017 | 09:43 PM
20b Carbon's Avatar
Additional Pics
Old Jul 10, 2017 | 07:36 PM
20b Carbon's Avatar
Carbon Creations
When we contacted them to purchase what we have they stated to us that they were discontinuing all of them. So we bought what they had at the time. If you can find a vendor that still has them in stock you should get them.
Old Jul 14, 2017 | 09:46 PM
20b Carbon's Avatar
Update 7-14-2017
Hope all is good,
We apologize for no real update, but we are hard at work getting our 13B TT ready for a car show next weekend. We will be attending Heatwave here in Austin TX. Don't worry we will post pics of the show.
Old Sep 10, 2017 | 09:08 PM
  #45
20b Carbon's Avatar
Back in the swing of things
We want to apologize for our delay but lets get everyone caught up. We left off that we were going to a car show and we won first place for our 93 RX7 13B TT.
But, Lets talk about what we have done lately on the 20B Carbon Car. Starting with reassembly of the rear end and rear suspension.
New bushings Powerflex
Rear sub-frame and diff installed driver side view
Rear diff cradle brace
Rear sub-frame and diff installed pass side view
Driver side traction and toe bars
Driver side rear axle installed
Rear knuckles reassembled
Driver side rear knuckled installed
Driver side rear end and suspension installed
Old Sep 10, 2017 | 09:22 PM
  #46
20b Carbon's Avatar
Additional pics
additional pics of the rear end reassembly.
Rear pass axle installed
Rear pass upper, lower, traction, and toe bares.
Rear pass knuckle
Rear pass suspension front view
Rear pass suspension rear view
Old Dec 6, 2017 | 10:46 AM
  #47
20b Carbon's Avatar
Updates from 9-2017 to Curent 12-2017
We have not posted in a while, but today is the day to catch you up. We have been posting on Instagram under the 20B Carbon.
We welcome our new sponsors Stance #ssusa #stancesuspension
Stance rear coilsovers installed
Old Dec 6, 2017 | 11:05 AM
  #48
20b Carbon's Avatar
Continue update Sept-Dec 2017
Pics of the rear and side bracing being added.
Rear lift brace/protection diff plate
custom tabs for rear lower brace right
custom tabs for rear lower brace left
Close view of the rear lower brace
Side floor braces inside connection points
Side floor brace
side floor brace
View of the lower bracing
Old Dec 6, 2017 | 11:26 AM
  #49
20b Carbon's Avatar
Continue 2 Update Sept to Dec
Before and After pics spraying of the Lizzard Skin thermal protection.
Before driver side
After driver side
Tunnel after
Pass before
Pass after
Rear before
Rear after
Underside tunnel before
Tunnel before
Pass front engine bay strut tower
Firewall after
Close up of firewall
Old Dec 6, 2017 | 11:31 AM
  #50
20b Carbon's Avatar
Continue 3 Sept to Dec
Here is a better pics of the engine bay after the Lizard Skin has been applied.
