Media blasting a 13b rotor
Old Mar 17, 2017 | 06:28 AM
Banzai-Racing's Avatar
Rotary Specialists
Purple Power Degreaser, soak over night and rinse. Biodegradable, non-abrasive, non-flammable and phosphate-free
Zep is petroleum based and flammable.
Old Mar 22, 2017 | 09:03 PM
Moe Greene's Avatar
Dang wish I tried Purple Power Degreaser, I have a bucket filled with old engine degreaser and no one can properly dispose of it...
Old Mar 22, 2017 | 09:19 PM
peejay's Avatar
Old [Sch|F]ool
I glass-bead rotors all the time.
If you thoroughly degrease them (like, they flash rust from humidity BARE METAL) it is not difficult to blow all the blasting media out.
Never media blast "wet" parts. Thorough degreasing in hot/boiling chemical solution, rinse with similarly hot water, a quick blow dry to blow the majority of the water out and let the heat of 9 pounds of iron heated to 200+ degrees dry it the rest of the way, and it's ready to be blasted.
Or you can spend $130 or so for a bucket of Berryman's, which will remove the carbon from the rotors overnight. Anything remaining will fall off with gentle scrubbing with kerosene.
I have access to a well equipped machine shop, so I throw engine parts in the washer and bead blast them as necessary.
Old Mar 23, 2017 | 07:08 AM
Rotary Specialists
We actually have an ultrasonic parts washer which cleans the parts inside and out in about 6 minutes. We still have a soak tank full of Purple Power for the heavy hard carbon.
Old Mar 23, 2017 | 11:23 AM
Gilgamesh's Avatar
This!
I was looking into ultrasonic cleaners when I was just building 1 motor... I cant imagine building tens or hundreds of motors per year and scrubbing everything by hand.
Old Mar 23, 2017 | 12:12 PM
peejay's Avatar
Old [Sch|F]ool
The aluminum is okay with that?
I've used Purple Power on castings before but never for very long, or with heat, so I'm curious.
Old Mar 23, 2017 | 12:28 PM
Rotary Specialists
We do not use Purple Power on aluminum, just the rotors in a 20ga soak & scrub tank. Our Ultrasonic Washer is just hot water and aluminum safe soap.
Old Mar 23, 2017 | 01:02 PM
Monsterbox's Avatar
Mazzei Formula
Originally Posted by IRPerformance
I don't recommend any blasting of engine parts. Not only can you damage them, but you may not be able to get all the blasting media out. For rotors I use Zep industrial strength degreaser. Put it in a bucket full strength and let the rotor soak overnight. Takes everything off. Just don't use it on aluminum and always replace the bearings afterwards.
have you ever tried soaking spark plugs in this? Wonder if thats an easy spark plug clean over night
Old Mar 23, 2017 | 01:22 PM
FührerTüner's Avatar
Penis Healthy
Wish i had 10k to spend on a parts cleaner....
Old Mar 24, 2017 | 08:50 AM
Gilgamesh's Avatar
Considering the amount of time it saves on a rebuild... I would think it has paid for itself by now.
Old Mar 24, 2017 | 09:14 AM
Rotary Specialists
Here is a Renesis rotor I put in our Purple Power bath last night before I left the shop and how it came out at 10am this morning.
Old Mar 24, 2017 | 09:23 AM
RotaryEvolution's Avatar
Sharp Claws
Originally Posted by Gilgamesh
This!
i did it for 14 years, hundreds and hundreds of engines, pussies.
not exactly because of choice though, i'd rather have a $10k sonic parts washer too but when you try to compete for the cheapest builds, you usually wind up with the cheapest builds which also means less income and less fancy equipment to work with.
i just cleaned my 36 spare rotors by hand without all that BS, media blasting or sonic parts blah blah. sure it took a couple of days but if your arms work, doing it for 1 engine seems less work than setting up a bunch of equipment to save a couple of hours of scrubbing.
arguing about the easiest way is counterproductive to just doing the damn job and being done with it.
Old Mar 24, 2017 | 09:53 AM
Rotary Specialists
Yes indeed, we have had the Omegasonics for about 5 years and considering we rebuild around 100 engines each year, it only makes sense to have equipment/procedures that reduce the time it takes. After all I still have to work on actual cars and dyno tune.
The ultrasonic falls into the same category as lifts, paint booth, dyno, etc
We still have our old Aaladin washer, which was a step up from hand scrubbing, but not as efficient as the ultrasonic. We have not used it in years, if someone is looking for a parts washer.
Old Mar 24, 2017 | 12:00 PM
peejay's Avatar
Old [Sch|F]ool
The solution for that is to not compete for the cheapest builds That's neither here nor there of course.
Old Mar 24, 2017 | 12:25 PM
Sharp Claws
true, but all this talk of using soda blasters and sonic parts washers is a little out there too. specialized equipment that isn't really necessary to do the simple job required.
Old Mar 24, 2017 | 12:34 PM
Gilgamesh's Avatar
This "specialized" equipment is to clean "stuff."
As shown above, a sonic cleaner has many other uses that internal engine parts.
The sand blast cabinet in my shop gets more use than a 10mm socket.
Old Mar 24, 2017 | 03:08 PM
Rotary Specialists
^ Exactly
I can't stand putting greasy parts back on a fresh rebuild. The parts come out of the cleaner ready to paint. As far as the short block parts, the ultrasonic cleans the insides of all the coolant channels in the irons and other very difficult areas to get to. I feel it increased the quality of our rebuilds.
I even run my tools through it when they get too dirty, literally 1 minute and they are clean.
A lift is a specialized piece of equipment, it serves one purpose...lift a car. It is not completely necessary but it sure does make a clutch job easier. I still have creepers just to remind me of the old days.
Old Mar 24, 2017 | 06:54 PM
peejay's Avatar
Old [Sch|F]ool
How do you lose a sand blast cabinet, though?
It's like any other tool... once you have it, you tend to use it, and then you wonder how you ever did without it. Probably half of an engine "build" is wasted on cleaning, if those are billable hours, you can instead charge $200-400 or whatever for "parts cleaning" instead of hourly rate for doing it the hard way. The customer doesn't see a different price and that sonic tank will pay for itself pretty quick. And after that, you're only in it for the cost of chemicals and electricity.
Old Mar 24, 2017 | 07:15 PM
Sharp Claws
exactly how many people in the third gen section, asking about how to clean a rotor need a full machine shop of equipment to build 1 engine?
someone who has more money than sense, or floppy little twig arms and would rather pay someone to install machines instead of pay a specialty shop to build their engine, perhaps just to say they did it?
i don't know why we are now arguing about how long it takes to clean parts for a single rebuild. or has this turned into an industrial business productivity thread?
i mean really, a person could buy BRAND NEW ROTORS and still be at 1/10th the cost of some of the equipment that has surfaced in this discussion.
Old Mar 24, 2017 | 08:11 PM
  #45
Rotary Specialists
At no point did anyone say to run out and buy a multi thousand dollar machine for cleaning a set of rotors for a DIY build. As I said initially, buy a gallon of Purple Power and soak the rotors over night.
Old Mar 24, 2017 | 09:14 PM
  #46
peejay's Avatar
Old [Sch|F]ool
Yeah, I can't always take our stuff in to work, since our wash tank has 250 gallons of cleaning solution and it is expensive to heat up 250 gallons of anything from ambient to 200 degrees so we "Batch" cleaning jobs as much as possible (and I throw my junk in at the end of the day after all of the payin' work is done), so if I need parts cleaned on "My Schedule"...
I will sit there over a stationary basin full of the hottest water I can stand, and Sears laundry detergent (cheap!), scrubbing parts manually with brushes. Rotors get carb cleaner and wire brushes, if necessary, but to be honest a lot of the time I'll just leave the carbon that survives the hot laundry treatment. It's like free thermal coating.
It works, it's more labor intensive, and if/when I have better means available, I take them!
This thread reminds me, we have a "Batch" of washing to do next week. The warmer weather will make that nicer on the electricity bill. There's a 220v, 50 amp circuit dedicated just to the wash tank's heater.
