ARP Wheel Studs Different Teeth WTF FML!
Old Mar 10, 2017 | 07:37 AM
F1blueRx7's Avatar
Couldn't stay away
They make a small lug nut installation tool, which isn't necessary. You did it the same way I did.
Speaking of which, I just (a few days ago) removed a set of ARP extended lug studs from an otherwise stock FC shell that I picked up and put stock length studs back in. I don't understand WTF they were installed for. The rears were still stock studs.
Old Mar 10, 2017 | 08:48 AM
FührerTüner's Avatar
Penis Healthy
In my case, Im trying to run Z32 wheels. The specs are:
Front: 16” x 7.5” 45mm Offset
Rear: 16” x 8.5” 35mm Offset
The rears fit but I need to run 10mm spacers in the front, hence the extended studs.
That and im hella jdm fatlace ricer.
Old Mar 10, 2017 | 12:17 PM
LargeOrangeFont's Avatar
Fistful of steel
I will be putting some ARP studs in tomorrow into a hub I just had modified for my brake rotors.
Old Mar 10, 2017 | 12:23 PM
Penis Healthy
Hella flush bruh
Old Mar 10, 2017 | 12:48 PM
Fistful of steel
We have gone beyond flush now.
Old Mar 10, 2017 | 04:41 PM
Penis Healthy
Noice m8!
