Fuhnortoner's 88 FC "Quest for 400 Horsepower!"
Old Feb 27, 2017 | 08:42 AM
  #76
FührerTüner's Avatar
Penis Healthy
Old Feb 28, 2017 | 07:53 AM
  #77
Penis Healthy
Old Mar 1, 2017 | 01:08 PM
  #78
Nosferatu's Avatar
Originally Posted by Fuhnortoner
Picked up Stu Kelleys AN fuel tank cover. I drilled a hole in my stock one for the fuel pump wire when i didnt know any better. This one seals so tight, when i was tightening the 8 alan bolts provided, fuel siphoned up the return line and was leaking all over the top of my fuel tank. Very satisfied with this product.
how thick is that aluminum tank cover plate? I'm curious why it needs to be that thick? great build btw.
Old Mar 1, 2017 | 08:47 PM
  #79
Penis Healthy
Stu Kelly sells it on his web site. I love it. Comes with Alan head bolts instead of the OEM Phillips Head, so no more stripping. As far as the sealing I'll tell you this; it seals so well, as I was tightening it, fuel siphoned up the return hose and spilled all over the top of the tank. Only comes with two holes for wires in the top grommet, so I had to drill 2 more for the fuel sending unit. Not a big deal. Very satisfied as stated before.
Old Mar 1, 2017 | 09:36 PM
  #80
LargeOrangeFont's Avatar
Fistful of steel
It is that thick because those AN fittings need enough meat to seal properly.
Old Mar 3, 2017 | 11:25 AM
  #81
Penis Healthy
Steering knuckles ready for paint.
Old Mar 3, 2017 | 12:15 PM
  #82
Nosferatu's Avatar
thought those AN fittings were like a bulkhead fitting that sandwiches the plate? I'm guessing using a thick plate just makes it cheaper and easier to make...no welding the fuel pump carrier or machining required...and as mentioned plate seals real nice.
Old Mar 7, 2017 | 07:37 PM
  #83
Penis Healthy
Getting closer.
Old Mar 7, 2017 | 08:40 PM
  #84
87JDMturbo's Avatar
Rotary Head
Looks good!! but word to the wise make sure you use some high temp anti-seize on the edges of those front wheel hubs or they will weld them selves to the inside of the rotor!!!
Getting closer.
Old Mar 7, 2017 | 09:15 PM
  #85
Penis Healthy
Thanks, that's a good idea. I had to soak the rotors in wd40 over night initially to get them off the hub.
Old Mar 8, 2017 | 05:31 AM
  #86
user 893453465346's Avatar
Red Pill Dealer
I coat the whole bolt with anti-seize when I do suspension work. It keeps the metal sleeve in the bushing from rusting onto the bolt. If you've ever dealt with that, it's quite frustrating.
Old Mar 8, 2017 | 09:28 AM
  #87
Penis Healthy
Since I flipped my oil cooler, I didn't like how low the 90* AN fitting was hanging. Purchased a banjo and bolt.
My vicious pitbull Corbin Dallas. He was cold.
Old Mar 8, 2017 | 01:01 PM
  #88
Penis Healthy
Forgot to post this a while back. Have this in as well as 4 ID1000s
Old Mar 8, 2017 | 09:26 PM
  #89
Penis Healthy
Need more time.
Old Mar 11, 2017 | 06:39 PM
  #90
Penis Healthy
Got her back together with the Z32 wheels installed. Unfortunately, 10mm spacers on the front weren't enough and theyre rubbing. :'(
Old Mar 11, 2017 | 08:57 PM
  #91
Fistful of steel
Good thing you put those 3.25" front wheel studs in
I believe I have some 15mm spacers I don't need anymore. Let me know if you might want them.
Old Mar 11, 2017 | 10:25 PM
  #92
Penis Healthy
I was thinking 15mm. The tires are barely rubbing the springs, and I mean barley. I'm wondering 5mm will be enough. In gotta put more though into it whether I'll use 15 or 20, but if o decide 15 ill def get back to you.
Old Mar 12, 2017 | 10:06 AM
  #93
Fistful of steel
15mm should solve that. When I had that suspension setup I ran 17x9+25 wheels with 235/40/17 tires. No rub.
Old Mar 13, 2017 | 09:11 AM
  #94
Penis Healthy
Twin Power done
Old Mar 13, 2017 | 03:06 PM
  #95
Penis Healthy
Cars and Coffee Modesto. Photo credit Dennis Houth. Need to put my fascia back on.
Old Mar 13, 2017 | 10:55 PM
  #96
Penis Healthy
Aeromotive Stealth 340 and new fuel level sending unit going in tomorrow.
Old Mar 14, 2017 | 05:43 AM
  #97
misterstyx69's Avatar
Retired Moderator, RIP
If you open up that HKS twin power...you will find..a chocolate!...LOL!
(funny you expect when you buy one that the box should be bigger..huh?)
Old Mar 14, 2017 | 07:53 AM
  #98
Penis Healthy
I was expecting the size. What i wasnt expecting was the weight of the dang thing.
Old Mar 14, 2017 | 10:38 AM
  #99
Lavitzlegend's Avatar
Spin 2 Win
Did you end up doing anything water/meth injection wise?
Also, you might want to consider going a different route if you were going to use polyurethane throughout the rear subframe etc. I did that to my '86 gxl right after I bought it thinking I was making an improvement. I have since gone back through and removed all of it and replaced with adjustable heim joints and spherical bearings because the poly just binds and doesn't allow the suspension to move. Also it will inevitably start squeaking driving you crazy. Aluminum or delrin diff and subframe risers while replacing the front diff mount with the mazdaspeed competition piece finish things off nicely.
On the wheel topic, I am running some 17x9 +25 wheels with 245/40/17 tires with a 10mm spacer up front and rolled the fenders since I did have it grab the lip once. I had to space them out otherwise the inner lip of the wheel would rub on my old coilovers. Not sure where you are rubbing but I'm assuming it's against the springs? I just got some 17x9 +24 wheels and 235/40/17 Nitto NT01s over the winter to prepare for track days this year. Hoping this setup fits a bit better but shouldn't have any issues since my 245s are working right now. Just food for thought and it lines up almost exactly with what LOF mentioned earlier.
Cool build so far and I like how you are keeping it really simple and only replacing the parts you have to. Keep it goin'!
Last edited by Lavitzlegend; Mar 14, 2017 at 10:47 AM. Reason: added wheel fitment info
Old Mar 14, 2017 | 10:42 AM
  #100
Penis Healthy
yeah, after some research, i decided to leave the rear bushings alone. They werent that bad anyways. If i do end up changing them, ill go to solid bushings.
As for the water/meth, i decided its not necessary for my hp goal. Just gonna run the Twin Power with some 10.5 race plugs. Steve Kan will be doing my tune on the first, so i trust hell get rid of any hints of detonation with the timing maps.
