26B PP Eunos Cosmo
Old Feb 10, 2017 | 01:37 PM
  #51
stickmantijuana's Avatar
lol why so thick on everything? they do add up
Old Feb 10, 2017 | 03:08 PM
  #52
7rotater's Avatar
Because i have a hate for lightly built stuff. I realize that its going to add some weight but i dont really care, its not a full on race car. 500hp will make up the difference.
Old Feb 15, 2017 | 06:57 PM
  #53
lol very fair point
hey I had a question... how do you line up the bell housing adapter center hole to the rear housing and the transmission? I was thinking of doing that but learned that getting it off by 1mm trashes the transmission and the pilot bearing.
Old Feb 15, 2017 | 11:38 PM
  #54
7rotater's Avatar
lol very fair point
Hi, its fairly simple. So you have 2 known centers, the bore in the bellhousing and the shaft that the throw-out bearing rides on. First step was to bore a hole in the adapter so its a snug fit on the shaft. Next step was to bore out the bellhousing center to accept a bush ( this bush is also a snug fit on the shaft ). Once all the parts are together the mounting holes can be marked and drilled. Hopefully this makes sense, i have included some photos to give you a better idea.
Photo doesn't show it very well, but the adapter is bored out to fit snugly on this shaft.
Bush, this is a press fit into the bellhousing.
I machined a few mm out of the bore on the bellhousing to get a bit more material thickness on the bush.
Old Feb 16, 2017 | 09:25 AM
  #55
thanks for the reply. Which bellhousing is that? our fd housings don't have a round hole for the input shaft as you know. it just has the big gaping hole for the fork assembly, etc. I still don't quite understand how you knew where to center the input shaft with respect to the mounting bolt holes with our bellhousing.. or do you need to source a bellhousing with a round hole in the center? I guess I can disassemble my second transmission and take off the front cover off to get that hole.
even the mounting bolt holes.. I realize I may be asking a very basic machining question.. how do you make them perfectly in alignment? I don't know any other way other than sharpie to make the mark and going from smallest drill bit to the correct size bit. My way is always off by little bit because I'm eye balling it and the drill bits do wander little despite my best efforts.. I made my oil pan this way and I had to make more than a few bolt holes larger in size to clear the studs..
Old Feb 16, 2017 | 09:37 PM
  #56
7rotater's Avatar
Yeah its an FC bellhousing im using. Im not familiar with the FD style so i cant help you there sorry. For marking out the holes there is a proper tool called transfer punches which will mark the hole centers ( google images will give you an idea ) . But i dont have a set of these so i just used a drill the right size and twisted it by hand, this will make a small mark in the center of the hole.
Old Feb 17, 2017 | 02:50 AM
  #57
stokrx's Avatar
Chur!
Awesome work and thanks for detailing the build up!!
Loving your work mate!!
Keep the updates coming!!
Quads are really gaining popularity over in OZ now!!!
-dave
Old Feb 17, 2017 | 11:20 PM
  #58
7rotater's Avatar
Originally Posted by stokrx
Chur!
-dave
Thanks Dave. Your first gen 20b sure looks like fun, are you building a 26b now?
Made a pushrod for the alternator belt tension adjustment.
Old Feb 18, 2017 | 12:32 PM
  #59
stokrx's Avatar
Hey bud, cheers. She's a handful.
Yep, got the plates for a side port. The shaft and bearing carriers/iron mods are getting done ATM by Jeff Bruce.
I'll be keeping an eye on this insane build, I'll drop you a pm soon mate.
-Dave
Old Feb 18, 2017 | 09:04 PM
  #60
7rotater's Avatar
Cool, looking forward to seeing the build.
Made some progress on the sump today. Machined out some pockets for the oil to be picked up from.
Old Feb 19, 2017 | 07:45 AM
  #61
nice thanks man.
man your pictures really make me want a nice milling machine. God knows I need one! love to see some detailed photos for your dry sump setup.
Old Feb 19, 2017 | 06:31 PM
  #62
7rotater's Avatar
Test fitted the engine today. Everything seems to fit, plenty of room up front for the radiator. probably enough room for another 2 rotors.
Too low for the engine crane.
Old Feb 19, 2017 | 09:29 PM
  #63
roTAR needz fundZ
Room for another 2 rotors?
Doooooooo iiiiitttttttt
Old Feb 21, 2017 | 07:43 AM
  #64
just out of curiosity, why do all 4 rotor guys go with PP? is this due to some technical issue? ease of UIM fabrication? If I did a 4 rotor, it would be street port so I can drive it around town...?
nice to see a few 4r builds nowadays. It used to be once in every 2 or 3 years.
Old Feb 21, 2017 | 08:18 AM
  #65
Brilliant7-LFC's Avatar
I would go one step further and say to maybe even leave the stock ports. A 4 rotor could be a silky smooth torque monster, if the tune is right, I would imagine. Especially in a car like the Cosmo, I'd be after the luxurious, calm power. But, that's just me.
This is to take absolutely nothing away from the build, which to me is absolutely awesome! Keep it up man!
Nick
Old Feb 21, 2017 | 09:06 AM
  #66
Johnny Kommavongsa's Avatar
dang that looks good.
Old Feb 21, 2017 | 05:48 PM
  #67
fritts's Avatar
Mad Man
Motor length, e shaft length. Thick plates are expensive on a 20b and almost unobtanium. I don't know that I have seen anyone advertise a non pp 4 rotor. Easiest way would be to run a combo port primary side port and PP.
Old Feb 21, 2017 | 05:49 PM
  #68
7rotater's Avatar
The reason i chose a pp is because i want the noise and hp. It does also make the intake fabrication easier. This thing is still going to be driven around town, its just going to upset a few people
Nick
Thanks Nick. A stock port 4 rotor would be a cool project, it would be super smooth. Also it would make a great sleeper.
Old Feb 21, 2017 | 07:30 PM
  #69
Narfle's Avatar
Rx7 Wagon
Nick
Scoot made one with side ports, but it's easier to make with peripheral ports because of the primary/secondary port size difference for side ports. That's one reason why a side-port-20b needs a thick plate, it's got a primary and secondary port on the thick plate.
Old Feb 22, 2017 | 07:40 AM
  #70
ah that makes sense. Thank guys!
Old Feb 22, 2017 | 06:54 PM
  #71
7rotater's Avatar
Drilled and threaded some holes in the sump for the pick up points. Im using these cool looking, low profile banjo fittings ( -12AN ) from Radium Engineering.
Old Mar 10, 2017 | 10:55 PM
  #72
7rotater's Avatar
Got the drive belts sorted and finally installed the sump today. Added 16, m12x1.75 threaded holes to the sump for attaching the engine mounts. Also made up the scavenge hoses which contain an inner support spring to stop the hoses collapsing under vacuum. The hoses will be secured to the sump with some p clamps.
Old Mar 11, 2017 | 04:44 PM
  #73
Narfle's Avatar
Rx7 Wagon
Looks great. What's next?
Old Mar 18, 2017 | 10:12 PM
  #74
7rotater's Avatar
Next step is to sort out the engine and transmission mounts, then start building the intake manifold
I haven't acheived much on the car the past few weeks. My time has been taken up making a powdercoating oven. The oven is made out of an old freezer, it uses 2x 2kw heater elements. Managed to melt an extension cord the first run, so i guess it draws a few amps. All up its probably cost about $300 nzd. Finished it today and the first thing i painted was the bellhousing.
Old Mar 19, 2017 | 07:50 AM
  #75
That looks great dude. Can you do me a favor and make two of everything? I'll swing by and pick it all up when you're done. K? Thanks.
Nick
