A turbo question...
Old Nov 29, 2016 | 10:43 PM
cfamilyfix's Avatar
A turbo question...
I'm piecing together a 12a dellorto low boost (5-8lbs) for my 1980 626. I have a rotary works 12a exhaust manifold and tial 44mm external wastegate. I need to make a decision on a turbo. Here is what I'm looking at:
Goals are a fun car. No drag racing or competition. 12a is stock port and I won't be running an intercooler. Thoughts?
Old Nov 29, 2016 | 10:46 PM
cfamilyfix's Avatar
Something like this. Waiting on turbo hat for the dellorto
Old Nov 29, 2016 | 10:50 PM
cfamilyfix's Avatar
The car
Old Nov 30, 2016 | 01:02 AM
mattallac's Avatar
I would say your best bet is to go with a turbo the same as a turbo II fc or the same as a race tech kit from the 80s if you want a fun ,fast and street friendly car . I would also not be afraid to throw 15lb at the 12a .
Old Nov 30, 2016 | 02:30 AM
cfamilyfix's Avatar
Thanks Matt. Problem is I already ponied up for the fancy manifold. I have an fc t2 turbo and manifold but would have to modify heavy to work on the 12a
Old Nov 30, 2016 | 03:15 AM
WANKfactor's Avatar
Instrument Of G0D.
What about one of these?? Cheaper, current aero, good turbine options... 57mm Enhanced S200SX-E 7670 Turbo ? Full Race
Old Nov 30, 2016 | 09:02 AM
13BT_RX3's Avatar
The General RE
You'll need to start by plotting your engine's operating points on the compressor map you intend to use to see if it's a close enough match.
Info on how to do that:
https://turbobygarrett.com/turbobyga...Tech%20103.pdf
T04E "57 trim" map:
COMPRESSOR MAPS
S200SX-E map:
http://www.jegs.com/images/photos/10...19turbomap.jpg
P.S.-What do you have planned for ignition timing control?
Old Nov 30, 2016 | 09:35 AM
cfamilyfix's Avatar
Locked dizzy with leading timing at 10-12 degrees adv. trailing at 0
Old Nov 30, 2016 | 10:40 AM
cfamilyfix's Avatar
Originally Posted by 13BT_RX3
You'll need to start my plotting your engine's operating points on the compressor map you intend to use to see if it's a close enough match.
T04E "57 trim" map:
COMPRESSOR MAPS
S200SX-E map:
thanks for this info...
Old Nov 30, 2016 | 10:43 AM
mattallac's Avatar
there are adapters for t3 to t4 mounting on e bay and i think ace race stainless has them
Old Nov 30, 2016 | 12:00 PM
13BT_RX3's Avatar
The General RE
Taking the centrifugal advance springs out should work fine, that's what I did for my blow through setup a while back. You may want to see if you can find a JDM 12A turbo dizzy. It's all setup by Mazda to work with boost.
Old Nov 30, 2016 | 11:53 PM
cfamilyfix's Avatar
those things are rarer than hens teeth!!
Old Dec 4, 2016 | 01:40 AM
Jeff20B's Avatar
Lapping = Fapping
Semi-locked is the way to go. Or in other words, just limit the advance to 10 degrees.
Old Dec 4, 2016 | 09:08 PM
cfamilyfix's Avatar
Redirection was necessary and steps have been taken
I figured timing was critical and since oem pulleys are notoriously variable I got this
Found some rot to be dealt with so this had to happen
Got an rx2 manifold and a s4 turbo with 12a fitment
Some time with a grinder and some high temp paint will go a long way toward making this look presentable
Turbo that came with the manifold is seized but I have another.
Jeff20b might have had something to do with recent decisions lol 😂
Old Dec 5, 2016 | 03:37 AM
WANKfactor's Avatar
Instrument Of G0D.
Much better solution!
Old Dec 5, 2016 | 07:36 AM
lastphaseofthis's Avatar
My job is to blow **** up
cutting the stock fc turbo manifold only involes enlongating the holes like 5mm, its really easy... but looks like you found a solution.
Old Dec 6, 2016 | 01:37 PM
Jeff20B's Avatar
Lapping = Fapping
Do you know if that RB pulley has 100% accurate marks? It should as they base it on the woodruf key. Might want to double check it though.
Old Dec 7, 2016 | 05:23 AM
13BT_RX3's Avatar
The General RE
https://www.rx7club.com/1st-generati...-boost-1077251
Looks like an effective solution.
