Need some help identifying a couple connectors by the ECU
Old Nov 27, 2016 | 07:22 PM
DankestKush's Avatar
So I just got ahold of this car and I'm haveing a few issues. The body is 86 GXL and the drivetrain is that of an 88 TII. Long story short, I aquired this in the middle of the swap so I'm trying by best pick up where the PO left off. As I pulled back the carpet I noticed that these 2 black connectors aren't hooked up to anything.
Old Nov 27, 2016 | 08:08 PM
satch's Avatar
In the first pic if the visible plug on the left side has the following colors Black/Red,Green/Red,Black/Yellow,Orange/White, Orange, Brown, Black and a Black/Blue wire then it is for the automatic transmission.
The 2nd plug pic is not as clear so you'll have to list each wire for help.
Old Nov 27, 2016 | 08:33 PM
Thanks for the identitying the trans one. The second one has 6 terminals on the connector, but only 5 leads. Those colors are: black,red/ green,orange/ black,white/ black,white/ black, yellow, black,blue
Old Nov 27, 2016 | 09:07 PM
satch's Avatar
You say there are only 5 wires but you listed 8 wires?
And mostly Black wire with a thin White stripe is B/W and not W/B.
I can see 4 wires which are B/W, B/Y, G/R and B/L
Old Nov 27, 2016 | 09:10 PM
user 893453465346's Avatar
Red Pill Dealer
I see six listed...
Old Nov 27, 2016 | 09:14 PM
satch's Avatar
Originally Posted by TonyD89
I see six listed...
He typed B, R/G, O/B, W/B, W/B, Y, B, L
Old Nov 27, 2016 | 09:20 PM
satch's Avatar
If the 5th wire is Black/Red then the plug is for the electric cooling fan unit.
Old Nov 27, 2016 | 09:40 PM
My mistake guys. I'm using my phone and I may have typed black,white twice. Colors are B/R, G/O, B/W, B/Y, and B/Blue
Old Nov 27, 2016 | 09:48 PM
satch's Avatar
That's Green/Red and not Green/Orange. But anyway it's still for the electric fan control unit.
Old Nov 27, 2016 | 09:59 PM
Red Pill Dealer
My bad too satch, you are the man!
Old Nov 27, 2016 | 10:14 PM
👍🏻 Am I missing a harness then? This connector is a female so what male plugs into it?
Old Nov 27, 2016 | 10:25 PM
satch's Avatar
Only autos and some turbos have the auxiliary electric fan and your car does not, so there is nothing to plug it into since you do not have the control unit.
