working on a repu lsd kit
Old Oct 26, 2016 | 11:54 PM
xp882's Avatar
started working on a repu lsd kit since the one someone made in the past is no longer available i might be able to make more if there is alot of interest but i want test it first
Old Oct 27, 2016 | 06:09 AM
almoststockrepu's Avatar
More specific info about the kit please.
Old Oct 27, 2016 | 08:53 AM
xp882's Avatar
it would allow you to use an lsd torsen form a fd rx7 in a repu rear. you need a ring gear spacer and axle spacer also new bolts you will have to grind two notches in the alxe housing for the new bolts to clear like a fd rear end the pics are of the axle spacer first pic and ring gear spacer second pic
here is the info to the first kit that is nla
http://www.mazdarepu.com/board/viewthread.php3?FID=1&TID=1908
Old Oct 27, 2016 | 09:22 AM
Are the carrier bearings compatible? What are you doing about pinion depth when the crush sleeves are no longer available? How much shimming of the LSD is going to be required with your "ring gear spacer" ?
Old Oct 27, 2016 | 10:10 AM
xp882's Avatar
ring gear will be in the same place hope this helps.. bearing are the same
Old Oct 27, 2016 | 03:29 PM
turbo_dave's Avatar
#turbodavebuilt
#ballin
Old Oct 27, 2016 | 04:17 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Use the carrier bearings from the FD and the crush sleeve can be stretched out and then re-crushed. Been there done that. with the ring gear in the same spot the adjusters won't need to be moved.
Glad to see someone else doing a kit Al!
Old Oct 27, 2016 | 05:09 PM
xp882's Avatar
thanks brad its adam not al btw lol all good.. just following your lead someone had to remake this thanks for the tips!
Old Oct 27, 2016 | 08:00 PM
KansasCityREPU's Avatar
Out In the Barn
subbed
Old Oct 29, 2016 | 09:32 PM
Turbo8's Avatar
REPU Garage
I'm down
Old Nov 2, 2016 | 12:29 PM
DriveFast7's Avatar
Nice work Adam! I think you could sell some of these on eBay too to recoup development time.
Old Nov 2, 2016 | 01:44 PM
xp882's Avatar
thanks brad i might just do that alot time invested indeed... anyway got it installed today took it for a drive and a couple burnouts so far so good nice and quiet
Old Nov 2, 2016 | 07:35 PM
Turbo8's Avatar
REPU Garage
Just do it already!
Old Oct 22, 2017 | 09:30 PM
75REPU's Avatar
Are this still available?
Old Oct 24, 2017 | 10:13 AM
motormanalpha's Avatar
Over rev'd, under torqued
Still interested... any updates?
Old Oct 24, 2017 | 11:41 AM
xp882's Avatar
I have sold a few kits looks like 1975 repu is getting the last one i have currently.. i will work on getting more done up soon
Old Oct 25, 2017 | 10:07 AM
RA12124's Avatar
Banned
I'm interested in a kit. I must have missed the memo that you had them available. Send me a PM when you have kits to sell.
Old Oct 25, 2017 | 02:05 PM
xp882's Avatar
yeah sorry man i didnt know there would be so much interest i just made a few extras for friends and people keep sending request i will get on making some more i have the ring gear spacers done just working on using my friends lay to make the axle spacers
Old Oct 29, 2017 | 05:00 PM
spokanerxdude's Avatar
Less Cubes, More Balls
WA repu spacer
I'll take one!! How Much???
Old Nov 2, 2017 | 03:17 PM
SiRMarlon's Avatar
www.VJMU.org
I just recently installed this kit on my REPU and it's night and day difference. It also helps I put some really sticky tires on the truck as well! Rear grip for days now!
Old Nov 8, 2017 | 01:56 PM
xp882's Avatar
I have six spacers ready to go 220 shipped for the two spacers you will need to get your own bolts a few bucks at autozone i have part numbers email me awright84@verizon.net
Old Nov 8, 2017 | 11:46 PM
Narfle's Avatar
Rx7 Wagon
Now I just need a repu....
Old Nov 9, 2017 | 12:19 PM
xp882's Avatar
4 left going quick
Old Nov 10, 2017 | 10:23 AM
RA12124's Avatar
Banned
Originally Posted by xp882
4 left going quick
I just shared the thread with the Facebook Group for you.
Old Nov 10, 2017 | 10:12 PM
xp882's Avatar
thanks buddy
