this probably goes in the interior section but its a 3rd gen so I figure it will get most views here.
FlyRX7 center speaker 52mm quad pod
Gauges: AEM UEGO, Boost, EGT, Oil Temp
for the EGT I will install a O2 bung to 1/8 npt adapter to use the stock O2 sensor location. I know it's not the optimal location but I plan on installing it in the rear exhaust runner pre turbo some time later when I get around to pulling the twins.
for the oil temp I will use a Oil Pan drain plug to 1/8 npt adapter to get the temps. I'm used to this location since I was using a VDO that had the sender integrated in the oil pan drain plug.
So over 7 years later are you still using these gauges? I ask because I'm thinking about getting their premium series in Boost and Oil temp and keep my AEM A/F just like how you have yours.
I would like Defi Racer series but defi costs are ridiculous
Edit. I notice no one really uses VDO gauges even though they make gauges for Porsche etc.. .Why is that? Old technology?
I changed my setup and will be changing again.
Now I only have an Innovate AFR and Prosport Boost in a dual pod
New setup will likely go back to quad pod with oil temp and Aquamist water injection gauge.
Just to be clear, I think neit meant on/off, flow level and some adjustments. If I remember correctly, I believe the adjustments on the gauge are just for the gauge themselves.
Also, for people having issues with too many gauges, I recommend looking at the PLX multi-gauges.
