Does your wastegate have a noticeable gap around the plunger?
Old Jun 20, 2016 | 09:54 PM
stickmantijuana's Avatar
hey I just took my car apart to do some upgrades... I noticed one weird thing.
I have Turbosmart 60mm Power Gate WG60 wastegate. Like every other wastegate, it has the sprung plunger that closes the wastegate opening. I noticed that there is a significant gap (2mm or so) around the plunger. This would make exhaust constantly leak into the dump tube from the uppipe. Is this supposed to be closed completely? or is a small gap normal? Thank you.
Old Jun 21, 2016 | 04:28 AM
RuffRx7's Avatar
Can you post of pic?
Old Jun 21, 2016 | 10:20 AM
Banzai-Racing's Avatar
Rotary Specialists
You should have a valve seat that slides in
Old Jun 21, 2016 | 07:05 PM
nice. thanks man. yes you're right! the valve seat was stuck on the other side of the v-band when I took the WG off. now everything looks normal. thanks again.
DaleClark
Interior / Exterior / Audio
30
Jul 15, 2021 01:58 PM
HEVNSNT
Apr 18, 2016 08:22 AM
wcr2k11
SE RX-7 Forum
Apr 16, 2016 03:46 AM
