Rotary Drag Racing The place to post your racing stories and info
New Personal Best with a 1.33 60' on stock green cups!
Old Oct 11, 2012 | 11:36 PM
Bacon's Avatar
IRS 4 Life
So track conditions were ideal, cool night negative altitude correction
dialed the boost down to 25psi (just the 1 stage) since it was a import bracket race night
first pass went 10.6 with a 1.357 60' spun the tires going into 3rrd
then I didn’t change a single thing and went 9.859 @139.49 with a 1.335 60'
third pass was first round so i dialed in @ 10.0 went 10.08@ 118 (lol can you tell i got on the brakes?)
with a 1.357 60'
next pass i got tree'd by some 16 sec stock Honda, and 1.5 60'd (I didn’t get on the 2 step long enough and data log shows i dumped the clutch @ 4psi, not the 10 like the other passes
SO although i know i shoulda turned the boost up and just had more fun, but i was having fun.
but the secret sauce for the 60'
tire MT et Street 26x10.5x16 on a factory rim
8.5 psi cold coming off the trailer (mine dont leak so i set it and forget it like ron popeil)
the are @ 9.5-10 psi when i get back after the pass
7,600 2 Step
.028 TFC
ram sintered disk, with act hd pp shimmed .030
Stock Tranny
stock driveshaft
stock pumpkin W a kazz and stock MT gears
PFS girdle
stock green cups
DSS axle bars
Ubotanium bushings
Rotary extreme trailing and toe
Tockio's with eibach prokit setting 1
2nd gear burnout @ 6800-7k till their smoking nice and i feel "marbles" under the tires, release line lock.. pin it to 9k till you get movment forward, then stage like normal
I think if i sat on the 2 step a bit more i could have cracked the 1.2 barrier.....
owell next week ill try again
[imghttps://www.rx7club.com/attachment.php?attachmentid=478249&stc=1&d=1350016 554[/img]
Attached Thumbnails New Personal Best with a 1.33 60' on stock green cups!-1.33.jpg
Old Oct 12, 2012 | 02:00 AM
sk8world's Avatar
Chasing numbers
with a 1.357 60'
7,600 2 Step
.028 TFC
Stock Tranny
stock driveshaft
PFS girdle
stock green cups
DSS axle bars
Ubotanium bushings
Sick 60 footers man!
Congrats on the new best!
Old Oct 12, 2012 | 03:32 AM
C. Ludwig's Avatar
www.lms-efi.com
Yes. Sick indeed!
Old Oct 12, 2012 | 06:29 AM
KNONFS's Avatar
B O R I C U A
Congrats, and thanks for the notes (recipe)
Old Oct 12, 2012 | 07:00 AM
bigpaparotor's Avatar
Great job.
Old Oct 12, 2012 | 08:35 AM
RXTASY57's Avatar
Viper Eater
OK...what are stock green cups?
Old Oct 12, 2012 | 08:58 AM
RENESISFD's Avatar
Wastegate John
^ Stock axles, on a FD the stock rear axle cups are green.
Old Oct 12, 2012 | 09:24 AM
sleeper7's Avatar
WOW! that's fast.
60 ft times are crazy!
Old Oct 12, 2012 | 10:51 AM
tom94RX-7's Avatar
Nice Great Job! If you sat on the 2 step longer would you maybe over power the tires though and spin too much? that is some really low tire psi, i always agreed lower is better than the others that say around 14 psi is best
Old Oct 12, 2012 | 11:39 AM
Bacon's Avatar
IRS 4 Life
Maybe, but the beauty of the PCS is i log speed at the Pinion, so i can see my launch, and based on the dip in wheel speed "if" it could handle more, and im thinking 100 rpm, or a bit more time on the step would make it Perfect, i like the 100 rpm more since i tree up prettymuch the same every time, easier to change that than my driving lol
ive heard the same thing from alot of people, and i use to run 14psi, but she LOVES LOVES loves the 9.5-10psi range, prob has to do with the TFC, and all the rest of my combo.. i forgot to check the markers on the tires to see if their walking, i moved them about 1" so far this season
cant wait for next week, time to turn up the boost
Old Oct 12, 2012 | 02:51 PM
sk8world's Avatar
Chasing numbers
This pass was done on 14psi area: 1993 Mazda RX-7 Timeslip Scan - DragTimes.com
But what does Ari know....
Turn the boost up BACON!
Old Oct 12, 2012 | 03:07 PM
Bacon's Avatar
IRS 4 Life
interistingly enough
my 25psi pass
@ 330' i'm .109 slower
1/8 .198 slower
1000' is where he walks me .435
1/4 .58
Guess turning up to 32Psi should yeild some interisting results
Old Oct 12, 2012 | 03:38 PM
just startn's Avatar
Turbo vert
Damn, Not fcking around! Fantastic.
Old Oct 12, 2012 | 09:31 PM
ultimatejay's Avatar
Nice runs congrats. My MT's like 9.5 psi as well
Old Oct 13, 2012 | 07:04 AM
justturbo2's Avatar
Registered User
congrats!!! that's some real nice 60ft
Old Oct 13, 2012 | 11:36 PM
sk8world's Avatar
Chasing numbers
my 25psi pass
1/8 .198 slower
1/4 .58
Almost looks like those light weight honda's or Maybe his car is lighter than I think. That's when it really shows or maybe that's when they spray makes a difference. I always wondered why his car trapped s well on the back half.
What Ari did tell me was he could dial in all the 60 foot they wanted but right in that area was less likely to break parts and yielded the best for his combo.
Old Oct 14, 2012 | 10:47 AM
sleeper7's Avatar
Ding Ding! 75 shot on a turbo car may show as a 75hp increase on paper or the dyno but in the real world it could make a 150hp difference.
short story, I was running a 9.8 car, mine was a 10.4 car. He launch good, mine was ok. I had a slight mishap shifting in to second. when I shifted in to 3rd gear he was way ahead of me. I started to spay once I was in 3rd gear. I was catching him fast. Ran 117mph in the 1/8. Normally run 112/113. on that pass with out nitrous i thing 110mph would have been my 1/8 mile mph. Everyone one at the starting line thought I was going to win the race but the bad shifter made me miss 4th gear. Really think if I had made and good pass 120mph 1/8 was possible that day. Nitrous is no joke on a turbo car.
Old Oct 14, 2012 | 11:02 AM
sk8world's Avatar
Chasing numbers
I have wanted to spray my car for years. Only thing holding me back is I dont like the idea of running it on a PFC.
Did you go wet or dry shot? I would feel safer going wet and not trying to tune the INJ. to add fuel .
Old Oct 14, 2012 | 11:48 AM
sleeper7's Avatar
Sorry to the OP for changing the subject.
Wet shot. Full throttle switch and a momentary switch on the steering wheel. Run 3deg less timing for 75shot. Thing to remember is what is the hp limit of the back half of the turbo. Small back half equals less power potential because back pressure comes into play. I run a T6 1.32 back half so a 75 shot makes a huge power gain.
If one wants to run nitrous on a turbo that is limited to say 600hp, turn the boost down 75 hp and spray a 75 shot. That 75shot will make more power sooner in the power band so your over all average power is greater then just running boost. If that makes sense. When I do make a nitrous test pass the boost response is crazy. The map trace shows it goes straight to max boost no gradual increase to max boost.
Still testing things. And I have cracked a few plates because of nitrous. Getting the jets correct for my fuel is crazy.
Old Oct 15, 2012 | 06:27 AM
blitzboy's Avatar
awesome 60fts , and congrats on the 9 second pass!!!
Sleeper, in what gear do you hit the nitrous, 3rd?
Do many Turbo Rotaries use Nitrous? always thought it was the NA boys that sprayed
Old Oct 15, 2012 | 07:14 AM
MR.45's Avatar
Great Stuff!! Congrats!!
Old Oct 15, 2012 | 10:23 AM
bigdv519's Avatar
IFO Forced Induction Slo
Congrats Bacon!! Thanks for the slip and the recipe for the secret sauce.
Old Oct 15, 2012 | 08:33 PM
indio84's Avatar
Keep it up bacon.
Old Oct 15, 2012 | 10:06 PM
SPEED_NYC's Avatar
RX-Parts
BAD *** Len!! that's some sick 60 foots on any rear/axle combo, and to do it with green cups and a Kazz is very impressive!. I can't wait to see what she does at 32 psi. Very Impressive man! keep up the good work
Old Aug 7, 2013 | 07:43 PM
papsmagu's Avatar
Congrats and thanks for the inspiration
