Newbie with boost issue. Please read
Old Dec 6, 2010 | 01:58 AM
RX7_FD3S_JDM's Avatar
Hi guys im new to the forum and have a couple questions regarding boost problems.
First heres a little about my RX:
Interior:
Momo pedals
Momo gearnob/handbrake cover
Momo Steering wheel
Stock bucket seats
Alpine Headunit
Alpine 6disc changer
BOSE full aucostic sound system
Exterior:
17 inch Enkei alloys
Brand new Front discs/pads (needed for MOT pass)
Aftermarket Exhaust system (CAT present)
TEIN SuperStreet Coilovers
Aftermarket Spoiler
Red Calipers
Rear Diffuser
MODS:
Apexi ECU with commander
Apexi Full induction system
BLITZ Boost guage
Air-Fuel ration gauge
HKS turbo timer
Re-Amemiya Intercooler elbow pipe
Fully Samco hosed
All Heat rapped
Sequential BOV
Strut brace
VIPER Alarm system with Satalite Killswitch
Remapped By Hayward Rotary to approx 300 BHP
Now the trouble im having is the car limitts or feels like limits at around 4000-5000rpm. The second turbo wont kick in.
My first question before i start the investigation is......
is the ?air bypass valve? supposed to have a hose missing? Could this cause my boost issue?
See pic below. Thanks
Old Dec 8, 2010 | 02:17 AM
Been told on another forum that this doesnt really need a hose connected to it and wouldnt effect boost?
Old Dec 8, 2010 | 06:24 AM
dgeesaman's Avatar
The reason that's usually connected to something is to contain the noise it makes when it vents.
I suggest you keep looking for things that are out of kilter. Remove each of your intercooler / y-pipe couplers and inspect them for hidden tears or cracks.
How close are you to Berkshire? I was there last spring.
Old Jan 30, 2011 | 09:23 AM
Fd3s - power fc - video included
Right guys, ever simce i bought my twin turbo FD3S ive had the problem that it only revs up to 4-5000 rpm. Ive always put it down to the second turbo not kicking in because of dodgy hoses/solenoids.
Now after browsing through the commander im thinking that the ecu hasnt even been mapped and is just running on a base map
heres a quick video of my browsing through the settings menu. Sorry but you may have to pause it as i had very little memory left
http://www.youtube.com/watch?v=ra4d3WHohSg
if you cant see, everything seems to be set on zero
Old Jan 30, 2011 | 10:00 AM
Right guys, im now thinking that my Apexi power fc hasnt even been mapped and it running on the base map?
heres a quick video i did of me scrolling through the commander
http://www.youtube.com/user/nick4thg.../0/ra4d3WHohSg
Old Jan 30, 2011 | 10:07 AM
if you cant see it very clearly the first bit is on channel 8 on idle.
the igl map and igt map are all set on -25
inj map is all on 050
PIM volt - normal, all rpm is set at 50.0%
injector - everything set on 0
boost - everythings on 0
accelerator injector settings all 0
water temp correction all on 0
and everything lse on 0 or -25
surely this isnt right?
Old Jan 30, 2011 | 10:08 AM
Aaron Cake's Avatar
Engine, Not Motor
You have enough posts that I'd suggest posting this to the PowerFC forum instead of New User.
Old Jan 30, 2011 | 11:48 AM
Sgtblue's Avatar
Urban Combat Vet
It's been a while, but I think DaleClark has an excellent installation how-to in the PFC sticky section, including backing out on the air-bleed screw and setting proper idle with and without electric load etc.
Old Jan 30, 2011 | 07:23 PM
HokieRX7's Avatar
when I first installed my apexi power fc, I had the same issue until I had it mapped. i had a rotary guy locally take the car for a day and tune it. Problem gone.
Old Jan 31, 2011 | 05:40 AM
I have the (fd3s) power fc manual and there are settings on the setup pages, are these ok to put in as a standard map or are demo only?
Old Jan 31, 2011 | 04:24 PM
tom94RX-7's Avatar
everything is not right in all the settings and maps, I'm surprised the car even runs. you need to reinitialize it to reset everything.
Old Jan 31, 2011 | 09:56 PM
gracer7-rx7's Avatar
needs more track time
Start by going to the 3rd gen FAQ thread:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
Scroll down to the T section (for Turbo). You will find a bunch of threads on the turbos and troubleshooting. You will want to read them. Start with this one which will give you procedures for diagnosing the turbo operation:
http://www.autosportracetech.com/RX-...leshooting.htm
The original Apexi map is reasonably good out of the box and will not cause boost issues. Do you know what map is loaded into your Apexi Power FC?
Old Jan 31, 2011 | 10:08 PM
I just merged the two similar threads you have on this topic. Don't open new threads on a similar topic or people will just repeat the same questions as before.
Queppa
Nov 18, 2024 03:47 AM
Skeese
Adaptronic Engine Mgmt - AUS
65
Mar 28, 2017 03:30 PM
stickmantijuana
Microtech
30
Apr 23, 2016 06:37 PM
sen2two
AEM EMS
9
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
