My R85 Dyno numbers
Originally Posted by rxrotary2_7
Yes the original sheet was using a street port and had a Jaytech intake.
We have a local guy with a streetport running at 22/23lbs of boost and trapping 133mph with the stock intake tuned by Dee. We have to get a video of the car running or on the dyno. Reason there is not any rush to make a video is because no matter what is posted, it is always questioned/picked apart.
My intake is really small, the exhaust has 2 mufflers, and the motor uses stock ports, that explains to me the length of time it takes to spool, yada, yada. Honestly I don't really care, it runs great, sounds awesome (turbo and exhaust) and has just the right amount of power for the traction.
Here's a vid of some in car sounds. (this is a computer generated video and no laws were broken making this video
http://onyxz32.sagemind.com/XanderRX7vsGSXZ06.wmv
X...
)http://onyxz32.sagemind.com/XanderRX7vsGSXZ06.wmv
X...
Your car spools up sooner than Max's car. That was the question, the only other thing I could think of is that maybe max has some restriction on the exhaust path.
X...
X...
http://www.teamfc3s.org/forum/member...hp?img_id=8937
heres my 18 psi PT67. Car made 480@20, and 506 @ 23 . (yes, I just cannot shut up about it, it was a very long time coming)Carl
Are you stalking me carl? j/k
None of the other R85 graphs drop it's torque as quickly as yours.
This implies restriction or turbine too small.
I don't think it's intake, as your low end power is superior...?
-Ted
nice vid, whats done to the z06 ???
I'll be in the R85 club sometime in the next week
anybody have the wastegate routed back into the DP instead of the dump ?
Originally Posted by pluto
I just noticed that apex's car made alot of torque for the boost level he's running.
-Max
No Max, that's not what I meant in comparison. I was actually comparing your R85 dyno chart vs. apex's dyno chart. Eventhough boost was different between both cars, it should have similar characteristics (which looks like two totally different turbo kit from the chart).
Unless I'm color blind, the purple lines are yours and the baige color lines are apex's...
Originally Posted by maxcooper
The boost control for my RX6 dyno was messed up. It would spool up to 15 psi and then drop off to 12-13 psi by 7000 RPM (the power peak).
-Max
-Max
Oh, do you mean aREX4X dyno versus my R85 dyno? I thought you meant my R85 dyno versus my (A'PEXi) RX6 dyno. I think you might be color blind, as I don't see any beige. aREX4X's dyno lines are cyan.
-Max
-Max
crap, i meant cyan and not beige. but his spool up is definately much faster. What are the differences between yours and his?
-Max
-Max
I did dump my wastegate back into my exhaust (that's why it's not that loud). maybe that's why the curves are different.
x...
