New Member RX-7 Technical Post your first technical questions here, in an easy flame free environment, before jumping into the main technical sections.
BBS LM not fitting. Minimum spacers needed
Old Mar 28, 2013 | 12:45 PM
stantontyler's Avatar
Hello all,
Just got a set of BBS LM 18x9 +40, 18x8 +40 only to find out that the bore is too small. Does anyone have any idea the minimum size of spacers needed negate the bore issue on the wheel all together?
Much thanks.
Old Mar 28, 2013 | 04:03 PM
Chuck Fricken Danger's Avatar
just measure the lip with a tape measure.
Old Mar 31, 2013 | 05:52 PM
DC5Daniel's Avatar
Silly question, but you're sure there's not a hub ring stuck or seized in the backs of the wheels....? Almost all aftermarket wheels have a bore of 73mm, more than adequate to be able to clear and adapt to nearly any bore hub.
Old Mar 31, 2013 | 06:51 PM
caredden's Avatar
Super Moderator
Veteran: Marine Corp
OP,
Google this situation and it seems like a 5MM spacer might work. I too bought some BBS LMs with the bore on the fronts was too small. I ended up spending about $70 to get them bored out to 67.1.
Good luck.
Old Apr 1, 2013 | 10:55 PM
Gumd02000's Avatar
most wheel center is too big so you need adaptor, I'm suprise that it's too small
rx7jocke
Aug 15, 2015 03:36 PM
