european 6 ports NA motor
Old Jun 28, 2002 | 05:13 AM
hIGGI's Avatar
ok, here we go...when we was not able to find 6 port acutators which we know from US 13B na motors, we tought we do have 86 NA FC with 13B 4 port motor
but its not true
yesterday, taking down both intakes, we found it is 6 port, ports are not with sleeves, but with butterflies
pictures here :
http://rx7cz.net/photos/works08/
Old Jun 28, 2002 | 05:36 AM
TonyTurboII's Avatar
Glock Lover
Butterflies? That **** is weird!
Old Jun 28, 2002 | 05:39 AM
hIGGI's Avatar
its european 13B 86 NA FC with distributor - our TII's are similar to US ones, but those NA's are kinda out of my knowledge and FSM's ;p
Old Jun 28, 2002 | 08:32 AM
FPrep2ndGenRX7's Avatar
If your engine doesn't have the sleeves then maybe the transition of the port into the engine is not the same as the one with the sleeve's. When you remove the sleeves your left with that wall. If you guys take an engine apart I would love to see what the ports look like on the front and rear plate. If its not like ours we have in the states you guys could make some money. That lower intake is pretty neat also. Much easier to port than the ones we have.
Old Jun 28, 2002 | 08:36 AM
rico05's Avatar
WTB S5 N/A FC
That is WEIRD.
Old Jun 28, 2002 | 08:37 AM
hIGGI's Avatar
i removed butterflies from that intake, as well actuators...going to try fit this intake on my US 88 NA block sometimes in next 2 weeks (once my stuff for 13BT will be here)
of course, i will take that euro engine apart and take pictures of intake ports...
i`m taking pictures of pretty much everything and have them on http://rx7cz.net/photos/ ;o)
Old Jun 28, 2002 | 09:06 AM
Thanks for the pictures. Definetly like to see the ports.
Old Jun 28, 2002 | 11:27 AM
SureShot's Avatar
Seduced by the DARK SIDE
Very interesting. Like throttle plates instead of rotating sleeves. Cool..
Old Sep 27, 2002 | 05:28 AM
hIGGI's Avatar
engine side is same, we bolted this intake manifold without any probs to my US NA motor, matching correctly....
Azevedo
26
Mar 1, 2019 09:19 PM
hotshot2014
Jul 18, 2017 02:30 PM
Skeese
65
Mar 28, 2017 03:30 PM
