Anyone have a spare Air Flow Meter?!?!
Old Jun 16, 2002 | 07:02 PM
Node's Avatar
I broke mine, and it is filled w/ tar (long story ill explain later)
But I need a S4 (86-88) N/A AFM (air flow meter) quick!
please e-mail me at meanrex@yahoo.com
thanks, toss me an offer please!!@!$!@$
Old Jun 16, 2002 | 07:12 PM
NZConvertible's Avatar
I'm a boost creep...
Re: Anyone have a spare Air Flow Meter?!?!
Can't wait to hear this one...
Old Jun 16, 2002 | 07:25 PM
Scott 89t2's Avatar
SOLD THE RX-7!
geeze even with 5500 posts he still screws up his first job working on it
Old Jun 16, 2002 | 07:44 PM
banzaitoyota's Avatar
What Subscription?
Node, I sent you a Pm. BTW welcome to the real world of RX7 ownership!!!
Old Jun 16, 2002 | 08:47 PM
j9fd3s's Avatar
Community Builder
you can use an s5 one too
mike
Old Jun 16, 2002 | 09:31 PM
Node's Avatar
lmfao, a little bit my fault, a lotta bit not my fault
OK, so the reason my car is a total ******* before warmed up is because it has some sort of tar (I heard it was stock mazda airbox sealant which confuses me, but it is about 15 years old although the filter is new) and it was all up in my airbox, and seeped down into my AFM and clogged the hell out of it, when juts starting up.
Sometimes it wouldn't start without me holding in the gas pedal a little bit and then holding it for about 5 seconds.
Sometimes it would start but after the starter jump, it would stick at 3k RPM until i tapped the gas 2-3 times.
Sometimes after this, it would have severe hesitations, 2 or 3 real "hiccups" when just starting to move when in low RPMs and not warmed up fully.
That tar is a real mean ************
Now how I killed the AFM is that I didn't notice the pin clip and just removed the screws and pulled, and pulled off the two soldered joints too, and the rest where pluggable but the soldered where still fucked. I could scrape off all of the silicone sealant off of the screws and stuff, open up the airbox and resolder it and remove all of the tar. But that may fail some day so hell nah! I decided that I could hopefully find a used AFM and just get a K&N filter to replace my gummed up airbox.
I was trying to de-tar my AFM and airbox, but failed, heh. And it's worth the money if I can find a AFM that someone has lying around, than to take like 10 hours on some dumbass tar, and then just change to a K&N filter later on.
heres a picture for everyone
banzai, i'll read it and reply to you via PM, thanks
Old Jun 16, 2002 | 09:42 PM
Gene's Avatar
10 lb. boost, 5lb. bag
Woah I go away for a week and node gets a seven! And then he breaks it!
Congrats man!
Old Jun 16, 2002 | 09:55 PM
Node's Avatar
heres how nasty my AFM Flapper was looking
and grass sucks, i lost 2 screws (to the AFM plug) in it heh
good thing i didnt need em
Old Jun 16, 2002 | 10:16 PM
Node's Avatar
ick
Old Jun 16, 2002 | 10:18 PM
Node's Avatar
and I found a AFM locally in a junkyard for cheap
Wow I'm relieved!
Old Jun 16, 2002 | 10:26 PM
PlayinW/Wankel's Avatar
Node get a nice big tool box, and when you go to pull of the AFM just slip it in the tool box and tell the guys you didnt find what you wanted. A REALLY cheap AFM.
Old Jun 16, 2002 | 10:57 PM
Node's Avatar
playin w/ wankel, im confused?
anyways, crashunit insists on IMG tags...lazy lazy boy
there ya go crashypoo
Old Jun 16, 2002 | 11:10 PM
Node, get the hell off the grass and onto a workbench! That’s no place for working on a car!
And that junkyard AFM looks very broken, that's probably why it's cheap. Get one in one piece. Or did you do that...
Old Jun 16, 2002 | 11:11 PM
Node's Avatar
I learned my lesson with the grass :\
And I broke the connector on the AFM, but the tar inside it was the problem, and I got the car like that.
I found a AFM (in one piece tar free) and I'm going to get a K&N cone filter and make a cold air box out of aluminum. Or try to at least
She should be running very nicely on saturday. I wish I had a video camera so I could show you guys my STOCK RX-7, well, stock for a little bit
Old Jun 16, 2002 | 11:15 PM
Scott 89t2's Avatar
SOLD THE RX-7!
dude that black stuff is not good LOL... what the hell is it?
Old Jun 16, 2002 | 11:36 PM
j9fd3s's Avatar
Community Builder
rtfm
mike
Old Jun 16, 2002 | 11:55 PM
Node's Avatar
lmfao, and who where you referring to mike? I have the FSM and am reading parts of it
Old Jun 17, 2002 | 06:54 AM
FPrep2ndGenRX7's Avatar
I had the same problem with mine about 5 years ago.
Old Jun 17, 2002 | 10:06 AM
adamlewis's Avatar
Back from teh deadly!
I think hes saying to take a large tool box with you to a junkyard, and then just slip the thing in the toolbox and say that you didnt find what you needed.
Old Jun 17, 2002 | 12:42 PM
Node's Avatar
oh, lol, he confused the hell outta me, but the guy whos grabbing it for me and some other parts said it should only be $5-$10, although its not marked so it might be under miscellaneous ($3)
So its cheap no matter what
And I'm grabbing other goodies for my car too. Like strut tower speaker covers, and 2 "PUSH" pins that go on the radiator duct before the fan duct/guard, and a door handle if its not too hard to get off (because mines broken :-\
Old Jun 17, 2002 | 11:03 PM
opelbits's Avatar
That tar is the mysterious "black oil" from the X-Files!
Don't get it in your eyes! You'll never get it out!
Old Jun 17, 2002 | 11:33 PM
QC Motorsports
At least you didn't get that stuff in your engine right? I have had many a conversation on the cold air box out of aluminum and the best thing people have refered me to is a high impact plastic. They say it doesn't stay or get as hot as the metal. Just something to think about.
Good luck,
Charles
Old Jun 18, 2002 | 08:47 PM
Node's Avatar
thanks for the tip pacemaker, erm, peacekeeper.
It's caused by the foamrubber gasket/seal on the airfilter, it pretty much melts into this ****.
So I'll see what happens, for not its getting another stock AFM and airbox, ill get a cone filter goin sometime.
BLK 93
11
Sep 9, 2015 10:56 AM
rotor_veux
Sep 3, 2015 07:10 PM
