I want clean the engine manifold any ideas?
Old May 30, 2002 | 05:54 PM
My car is completley cold and I am planning on cleaning the engine. Can I just spray water on the intake manifold and wipe it clean with a cloth? and spray the engine with a little water and wipe the visable parts clean with a cloth? to do or not to do?
Old May 30, 2002 | 06:26 PM
martini's Avatar
it might work. I would suggest some meguiars all purpose cleaner.
Old May 30, 2002 | 06:38 PM
nocab72's Avatar
03 Cobra Killer
Before I had my Apexi intakes (still could do it now if I covered them), I warmed up the car, sprayed the entire engine bay real good with Simple Green (Gunk works well too), then powerwashed it, being a little careful spraying some parts. Then wiped it down with clean cloths and let the rest heat-dry.
Didn't seem to do any damage. Other might disagree, but when I got my car, the engine bay was really really dirty and it needed a REAL good cleaning!
it looked like this when I was done...wish I had a BEFORE picture, you would be amazed!
http://flathat.woodstream.net/RX7/Cl...y/P2120092.JPG
It looks like this now, plus the Cusco Strut bar which wasn't put back on before I took this pic.
http://flathat.woodstream.net/RX7/Gr...l/P5110091.JPG
K
Old May 30, 2002 | 07:13 PM
Thats one ****** clean engine bay man, what is that stuff called again? and did you pressure wash the motor when it was at operating temp with the car off?
Old May 30, 2002 | 11:33 PM
den-man's Avatar
that's insanly clean man- so let me get this straight, you just spray the gunk **** over everything pictured, and powerwash it all? that wont mess up anything? please confirm. thanks!
Old May 31, 2002 | 12:25 AM
potatobbq's Avatar
be careful with the simple green... i've read that it corrodes aluminum parts so if you use it, make sure to clean it all off when you're done.
Old May 31, 2002 | 10:17 AM
maxpesce's Avatar
Ex fd *****
Yes - The FAA issued a bulletin to all Airframe & Powerplant mechanics about the corrosive effects of Simple Green on Aluminum.
Old May 31, 2002 | 11:09 AM
jdhuegel1's Avatar
Glug Glug Glug Burp
Simple Green has an automotive cleaner too... Prolly the same stuff... But it works great! Don't get it on the paint. Eats wax right off leaving streaks galore!
Old May 31, 2002 | 11:20 AM
Mahjik's Avatar
Mr. Links
Smile
Yes, I didn't use Simple Green on mine, I used a different engine cleaner but here's what i did:
The cleaner I used said the engine should be cold, so I took that time to install my BOV. I was also working on some other things, so I had the battery out of the car at the time:
1. Covered air intakes with plastic
2. Covered battery cables with plastic (battery was removed)
3. Spray engine cleaner
The cleaner I used said it needed to sit for about 20 minutes, so I also grabbed a scrub brush and did some scrubbing as well.
4. After the alotted time, hosed down the engine.
I let the car sit outside with the hood up for about 2 hours and then went back to put the battery back in the car and the other things I had removed. I let the car sit for about another hour.
After that, I fired the car up. Some of the engine cleaner was still left around so it smoked for about 5 minutes or so. I took a nice 20 minute leisure drive to help burn off any excess of the cleaner left in the car and that was it.
Some people cover the alternator, some people don't. I didn't, but it's up to you.
Old May 31, 2002 | 11:41 AM
nocab72's Avatar
03 Cobra Killer
To clarify, I warmed up the car, and LEFT IT RUNNING.
I then sprayed <insert your favorite engine bay cleaner>, (I had to ask the guys who's cleaner I used), he said it was a "citrus based engine cleaner", smelled like oranges. Very similiar to the Simple Green Automotive Cleaner. I've also used stuff called "Gunk" which can be purchased from AutoZone, etc on other cars...
Left the car running, Spayed the engine bay with the citrus cleaner, let it soak for a few minutes, then powerwashed everything. Continued to leave the car running, wiped off any remaining dirt w/towel, put the hood down (1/2 latched) to let the engine bay bake the the rest of the water away. Opened the hood 10 minutes later and admired the sparkling engine bay posted previously in this thread!!!
K
Old May 31, 2002 | 02:18 PM
RotorMonkey's Avatar
Also.....
If you decide to wash the bay with the engine off, make sure that you cover the alternator and the area where the spark plug wires are located. I usually just lay a piece of plastic on top of those areas.
I washed my dads engine bay one time and soaked the spark plug wires. Then....it had problems starting over. Water got in it.
Old Aug 1, 2002 | 03:23 PM
Dragueur's Avatar
DAMN!!!
nice engine bay...
as for the LAST reply.......so do we NEED to cover the wires and alternator or NO?
Old Aug 1, 2002 | 04:47 PM
Mahjik's Avatar
Mr. Links
Re: DAMN!!!
Originally posted by Dragueur
nice engine bay...
I didn't cover mine. Some people do, some people don't.
Old Aug 1, 2002 | 04:57 PM
RX7Elmo's Avatar
what i would do is use the gunk foamy engine cleaner.
cover altenator, cover almsot anything electrical. Spray the cleaner on, let sit for 5-10 min, then i would start the engine, and spray the water to clean off whie the motor is on. The reason i like the motor to be on is if i get something wet that shouldn't, i should be able to tell
Danny
Old Aug 1, 2002 | 05:22 PM
From: Minnesota, now in FL and I dont think I'm goin back
NOCAB, what PSI pressure washer do you have, is it gas or electric. Or what setting did you have it on. My pressure washer is 2400PSI, I think that would be a little too much for my engine, so maybe I should turn it down before I do that.
Mike
Old Aug 1, 2002 | 05:26 PM
nocab72's Avatar
03 Cobra Killer
I just used a pressure washer that connects to the good'ol garden hose. Nothing with massive pressure...
Ya, I think you would tear some **** up with 2400psi!
K
Old Sep 25, 2003 | 09:14 PM
NorthwindHost's Avatar
Are there anything side effects of watering down the engine with the engine on?
Old Sep 25, 2003 | 09:16 PM
Mahjik's Avatar
Mr. Links
Read the directions on whatever cleaner you have. Some of them say to use when the engine is off and cold (because some of that stuff is flamable).
Old Sep 25, 2003 | 10:29 PM
911GT2's Avatar
The Power of 1.3
Here's what I did. https://www.rx7club.com/forum/showth...hreadid=205104
Old Sep 25, 2003 | 11:27 PM
turbojeff's Avatar
Do it right, do it once
I've cleaned 40+ RX7 motors, never covered the alternator. You do not need to cover it period.
Jeff
Old Sep 26, 2003 | 03:52 AM
Roar 629's Avatar
for some area..it's better to use brush..
Old Sep 26, 2003 | 03:43 PM
ZeroBanger's Avatar
I had a FB and have an FD now, I would spray GUNK engine cleaner when the car was cold weight 10 minutes and hose it down. I have done this many times and had no problems
I never cover any of that stuff
Old Sep 26, 2003 | 10:40 PM
heh I just took everthing out of my engine bay,
polished anything that was metal, and armorall anything plastic. and had the whole engine bay repainted.
a lot of work, but well worth it . will post pics later.
Old Dec 12, 2003 | 01:11 PM
fastcarfreak's Avatar
3rd motors a charm I hope
nice looking engine nocab. I should try that, my engine could use a cleaning im sure.
