Wiring and strut bar help
Old May 23, 2002 | 12:05 PM
takerwolf's Avatar
I would like info on where to put grounds to reground the ecu, engine, battery, and chassis. I have plenty of 8 guage ground wire to do as much as possible (35ft). Also, what about rewiring the fuel pump? The car sat most of its life so I would like to do this stuff just to be sure. Also, I have an OBX strut bar (which I may sell if I change color, the one I wanted was backordered) but it rubs on the hood in 2 spots, any idea what to do to fix that?
Old May 23, 2002 | 04:06 PM
NZConvertible's Avatar
I'm a boost creep...
I added earths from the manifold to the firewall, the bell housing to the firewall, the pressure sensor earth wire to the thermostat housing, the ECU (see below) and the battery negative to the chassis. Here's the links you need.
Adding earths to the ECU
Rewiring the fuel pump
If the strut bar just rubs on the underhood insulation, don't worry about it. If it rubs on the metal, may just "massage" the hood with a hammer...
Old May 24, 2002 | 12:44 AM
takerwolf's Avatar
Thanks for the help and sites, I appreciate it. You wouldn't know anything about a Pivot RHU-M would you?
Old May 24, 2002 | 08:05 AM
FPrep2ndGenRX7's Avatar
NZ - I never heard it called an earth wire before. Thats interesting.
Old May 24, 2002 | 09:26 AM
My 'Trust ' bar rubs aswell [ two spots] its very tight across the top
just enough to clear the alt. then rubs the bonet instead. Ive also cleaned my NEGATIVE BONDING as
well!
TII-PF
Old May 24, 2002 | 10:55 AM
HAILERS's Avatar
HAILERS
BONNET, EARTH! Next thing you'll be saying is WINDSCREEN! or SPANNER or BOOT.
Old May 24, 2002 | 10:26 PM
Oops, slipped that one in without thinking! It's more common than "ground" over here.
Old May 26, 2002 | 12:01 AM
downwinddave's Avatar
Just ordered Trust front strut barn from ebay. Where on the hood does it rub? I do not want to do the "If it rubs on the metal, may just "massage" the hood with a hammer"... fix!
91 vert
Old May 26, 2002 | 03:30 AM
Just been looking again ,the Alt. is nearly on the end
of its belt tension slide, (had trouble matching two
belts to length when I changed the pulley)
Im sure with shorter belts the alt. will come down
enough so as to readjust the strutbrace down a bit!
Old May 26, 2002 | 03:48 AM
RETed's Avatar
Yeah, the Japanese call it "earth" also...
-Ted
