Black Magic Electrical Fan #150 Install. Can any body help me?
Old Apr 30, 2002 | 06:15 PM
silverrotor's Avatar
Just received my Flex -A- Lite #150 electrical fan!
I replaced all cooling sensors and don't want to flubber this up!
Does anybody know where to wire in the (+) terminal leading from the fan? It ask for an ignition switch source. Also, how do I go about in wiring the A/C connection, with the piggy back connector leading to the "C" terminal. I need to know the A'C's power wire? Can anyone help?
Old Apr 30, 2002 | 06:38 PM
Icemark's Avatar
You will want to use a 12Volt automotive 30/40 amp DPST or 30 amp SPST relay.
There are pins (terminals/connectors) on the relay and next to the pins will be numbers or there will be a legend on the side of the relay.
Wire as follows:
+ (positive) Lead to the fan: 30
+ Battery: 87
+ 2nd ignition (Black/red at the ignition switch): 86
- (ground or battery negitive):85
If useing a DPST you will not use 87A on the relay.
Wiring it this way will switch the fan on only when the key is in the on position, but not while cranking the starter.
The other options are if you are using a Thermo sensor to turn the fan on. Depending on its input/output polarity you can place it inline with either the 85 or 86 leads. For example, if the sensor is a two wire sensor and it makes continuity when hot, the ignition 2 wire would go to one side and the relay's 86 to the other.
Or if you wanted a switch, same wiring:
switch input: Black/red ignition two fron the ignition switch.
switch output: to 86 of the relay.
Old Apr 30, 2002 | 09:24 PM
NZConvertible's Avatar
I'm a boost creep...
Like this:
Old Apr 30, 2002 | 09:48 PM
But yes, but what would you tap into as far as an ignition switched source?
And what about the A/C connection?....
Old Apr 30, 2002 | 09:52 PM
Icemark, are you forgetting that the #150 has a built in thermo sensor?
Old Apr 30, 2002 | 11:26 PM
Icemark's Avatar
Actually I didn't know about the internal temp switch, but Jason's drawing is basically accurate (I swap the 87 and 30 leads so that 87A doesn't have voltage sitting on it), just jump the temp switch, if there is one built into the fan.
The ignition switch is very easy to get to and the FC is one of the easiest cars to run a wire out under hood from the dash.
as far as the air condition switch, does it require negative or positive for a trigger?
Old May 1, 2002 | 01:36 AM
The green 6-pin diagnostic plug by the leading coil. With the clip on top, the top left pin has 12V with the ignition on.
Sorry, missed that bit! On my diagram, if you move the temp switch into the "ignition" wire, and then run a wire from the compressor clutch wire to the same relay terminal as the "ignition" wire, it'll switch the relay when the temp switch closes OR the compressor runs. However if your fan does have an internal temp switch, I have no idea how you'd do it coz I don't know how the fan's wired. Of course it would be much easier just to use the stock ECU-controlled fan in front of the radiator for A/C duties! Don't you have one?
Old May 1, 2002 | 02:05 AM
That's not a silly idea, never though of that! Course if it's a SPST relay (87 and 87a are linked) it's the other way around!
Old May 1, 2002 | 04:15 PM
Am not sure about all these relays you guys are talking about. The Flex -A-Lite Black Magic Electrical Fan model #150 comes with a built in thermo sensor. Upon preset temp. the fan kicks In. My question Is what can I use as an Ignition source. And the A/C positive connection. What wire. Although I believe It's green. I haven't checked though....
Old May 1, 2002 | 04:22 PM
Acually, I'll vouch for the green 6 pin diagnostic plug as an Ignition switched source. I use It all the time to track down failed, if any, parts on my car. How would I connect the this source? Strip the insulator and solder?
Old May 1, 2002 | 04:27 PM
The relay we’re talking about is a common 30A automotive relay, available from any auto parts or electronics store for a few dollars. If you look at the bottom of one, the terminals will look just like the relay in my diagram above. Wire your fan up just like this (but without the temp sensor since yours is built in). I’m pretty sure that with that built-in temp switch, you won’t be able to wire it to operate with the A/C, but someone who knows this fan might know otherwise. Why do you need this? Don’t you have the stock electric fan?
Old May 1, 2002 | 04:46 PM
No I don't have the stock electrical fan. I have the Flex-A-Lite Balck Magic Fan model #150. This fan has a built in thermometer. At preset level the fan will kick in. The A/C con. is their for 2 reasons: When using A/C cooling system is being taxed. Also used as a assistance measure If you desire to have the fan kick in when desired, Just flick the A/C on and, you guessed It the fan turns ON.....
Old May 1, 2002 | 05:38 PM
Um, I know all this... I was trying to find out if you had the stock A/C electric fan. I thought all cars with A/C had this fan but I guess not.
Your "assistance" theory is wrong. The A/C rejects heat from the condensor, which is right in front of the radiator. Because of this, running the A/C adds an extra heat load to the cooling system and should never be run if you're having cooling problems.
Old May 1, 2002 | 05:54 PM
Ok, I just downloaded the instructions for your fan; it’s really easy and can be switched by the A/C. Here’s where to run the wires from each terminal:
+ - ignition signal, plug straight into the green diagnostic plug
G - ground, anywhere on the chassis will be fine
B - battery, take direct from the battery via a 20A fuse, don’t forget the fuse!
C - A/C, tap into the black wire going to the A/C compressor clutch, it’s the only one
Hope that clears everything up!
Old May 1, 2002 | 06:06 PM
Why yes that does. Thanks bro! Where exactly could I find the black wire leading to the A/C compressor clutch?
Old May 1, 2002 | 06:14 PM
It's the only wire going to the compressor, you can't miss it.
Old May 1, 2002 | 06:51 PM
Icemark's Avatar
The only problem with that ignition wire in the green plug is that it is hot while cranking which is a bad thing if the battery is run down a little or the alt was not charging it correctly.
The ignition wire I suggest drops while cranking so you can have the full available voltage for starting.
Old May 1, 2002 | 07:03 PM
That's true, but unless the radiator was still hot enough that the fan's temp switch was closed (the engine and the fan would have to have been running very recently), the fan wouldn't be run while cranking anyway.
Old May 1, 2002 | 07:19 PM
o.k than how do I go about and find the ignition switch wire? Also how can I hook it to the fan?
Old Dec 22, 2002 | 12:55 AM
johnkean's Avatar
I just got my black magic #150 from Kragen here in Riverside ca, i was suprised to find it there for $10 less than summit racing. I got it and hooked it up tonight, the fan comes with a breaker that goes inline between the batt and the B on the Fan's plug input. I did however connect the + on the input to the batt and not the ignition. The reason i did this is when i shut the car off to go into a store or what ever, the fan will continue to cool while i am away, then shut off when the temp goes down.
Skeese
65
Mar 28, 2017 03:30 PM
