getting exhaust upgrade, opinions?
Old Apr 23, 2002 | 02:45 PM
go to atr.com they have a full 3' system that will be a little cheaper, gives better horsepower, sounds better. Really easy to install all instructions included, all stainless steel, mandrel bent. and if you want quietter get a bolt on silencer w/ system.
Old Apr 23, 2002 | 02:48 PM
Mahjik's Avatar
Mr. Links
There are few people, like myself, using that setup. I like it a lot. I'm sure there are higher flowing cats that are available, but what I wanted was durability. I didn't want to be replacing the cat again in another 12 months.
It's a good kit. I didn't do the installation myself, but I hear it's a direct bolt on.
Old Apr 23, 2002 | 03:48 PM
rynberg's Avatar
Be careful, downpipe+hi-flow cat+exhaust = three mods right there. You're going to have to restrict your boost to be safe with the stock ecu.
BTW, lucky you. The recent home purchase has set back my upgrade schedule for quite a while. On the other hand, my FD will be garaged from now on.
Old Apr 23, 2002 | 03:53 PM
neo_omega's Avatar
***Moderator***
Re: getting exhaust upgrade, opinions?
Originally posted by OneKrazyGuy
I am getting an intake and exhaust I need some opinions on these. the first is listed below and can be found at http://www.rx7.com/cgi-local/3catalog.cgi?cat=4&part=1
Bönez 3' Perf. Full Cat Replacement Kit (Stainless
Steel)
The other is a HKS cat back system. What do you guys recommend? my car is a 1994 FD. I want something that will allow it to breath more but will not sound or like a rice burner.
Any experiences with these products are appreciated.
How much are you willing to spend?
Old Apr 23, 2002 | 04:56 PM
nocab72's Avatar
03 Cobra Killer
I replaced my stock cat with the bonez hi-flow. That lasted about 3 days before I ripped the bonez hi-flow out and just dropped in a SS MidPipe. I see you are in CA, so you're probably stuck with the hi-flow cat.
I'm guessing it made about a 20hp difference, hi-flow cat v/s midpipe.
I picked up 30hp going from the hi-flow cat to a midpipe (same boost). I also added the HKS twinpower the same day I swapped the hi-flow for midpipe though, the HKS should have been good for 10hp so I figure the hi-flow to midpipe accounted for the remaining 20hp.
K
Old Apr 23, 2002 | 05:48 PM
Qball's Avatar
Comp Yellow Mica
i live in cali.. just get a resonated MP (more expensive than a non-res one) and the Gmedallion from Tanabe.. when smog comes along its easy enough to switch the cat section back in.
quieter still use a racing beat dual tip.
hks canister + mp is pretty freak'n loud
Skeese
65
Mar 28, 2017 03:30 PM
thecody59
40
Aug 23, 2015 06:41 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
