you can run MSD without direct fire right. How?
Old Apr 3, 2002 | 10:32 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
I want to keep my engine simple and so I dont want the three coils and weird wiring of a direct fire ignition.
Cant I just hook up the msd through the distributor.
Heavy Black to NEG
Heavy Red to POS
Black to neg on coil
orange to pos on coil
small red to the original +coil wire
white to the original - coil wire.
Who has this setup. How is the direct fire better.
This seems a hell of a lot easier to hook up. An it would look cleaner.
Old Apr 3, 2002 | 10:59 AM
Northern 7's Avatar
This article may help you understand the direct fire approach:
http://personal.riverusers.com/~yawpower/ignition.html
Old Apr 3, 2002 | 11:17 AM
Don't worry about how hard it is to hook up, or how it looks, just look at the end results of it. Hell, im probably going to do a direct fire on my 7 as soon as my *** finds a job.
Old Apr 3, 2002 | 11:25 AM
V8kilr's Avatar
Re: you can run MSD without direct fire right. How?
i just had that setup,
i switched over cause it sucks,
you will burn up your dizzy cap fast,
my went in less then 30 days,
its too hot of a spark to try to push through the dizzy cap.
i had a msd 6a with dual blaster 2 coils,
just get another coil and go direct fire.
it will be well worth it.
Old Apr 3, 2002 | 11:30 AM
OtakuRX's Avatar
The Rotorheaded Geek
What kinda power gain is there? or is it all just initial pick-up. Both are good of course.
Old Apr 3, 2002 | 11:41 AM
V8kilr's Avatar
go here anyone that has any questions,
old thread
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
zuesskroph
Aug 13, 2015 06:05 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
Wolf_
Aug 11, 2015 04:23 PM
