Differences between 20B versions A thru F
Old Mar 18, 2002 | 05:06 PM
Exit13B's Avatar
I was hoping the die-hard 20B experts could post their experiences with each version of the 20B (A thru F) for comparison? It would be interesting to track the changes to find out why a C, D, or E is best. Perhaps one guru has all the answers? I believe C and up has the improved Eccentric -- but what else? Anyone know what the limitation of an A or B eccentric is?
Old Mar 18, 2002 | 08:28 PM
RETed's Avatar
Uh, you tell us?
Where exactly are you getting this info from?
I am only aware of the "Series I" and "Series II" 20B's that can be differentiated be the color of the intake manifolds.&nbsp The Series II 20B is stronger internally.
-Ted
Old Mar 18, 2002 | 09:22 PM
now's Avatar
now
reted> how do you tell the two apart?
Old Mar 18, 2002 | 10:15 PM
Node's Avatar
One has a aluminum colored intake manifold (piece of tubing on top of the engine to be blunt) and one has a charcoalish grey colored manifold.
I believe the gray one is Series I, I'm not sure of the years though, I think Evil Aviator knows them.
http://www.autospeed.com/A_1319/page1.html
This is AJC13B's car in this. He uses a 13B-RE which is a Cosmo engine as well (the engine you got if you didnt have a 20b).
Anyways, take a look at the engine bay shot, you will see what I mean by charcoal gray colored intake manifold
And yes, I was only aware of these two types as well george.
Old Mar 19, 2002 | 10:00 PM
j9fd3s's Avatar
Community Builder
http://www.dmrh.com.au/jc_series2.htm
i thought there were two, too.
s1 with the natural intake manifold and
s2 with the black one
mike
Old Mar 19, 2002 | 11:41 PM
crispeed's Avatar
'Tuna'
I've seen some come with the thicker casting around the dowel area like the FD's and some with the normal casting like the FC's. This is the same for the 13B-RE Cosmo motor also. I've also seen some of the 13B-RE motors come with the standard stationary gears and some with the grooved gears like the FD's. Might be the same for the 20B too.
crispeed
87 Rx-7 TII
9.20@150mph
2600lbs
Old Mar 20, 2002 | 12:38 AM
Node's Avatar
did the difference go along w/ the series I, series II stuff, like the better had the different colored manifold?
Old Aug 10, 2004 | 01:17 PM
Black_91_GT's Avatar
bump
t-von
Sep 10, 2015 01:56 PM
chiefmg
Sep 10, 2015 07:46 AM
Ian_D
Sep 6, 2015 10:38 PM
