What the hell!
Old Mar 2, 2002 | 03:16 PM
4ohfour's Avatar
What the hell!
OKay, so I bought what I thought was a 1984 Rx-7 GSL-SE
they ONLY come with the 13B motors true, and if so do the 13b's come with FI or are they carbed.
Under the hood of my car today rooting around looking for the reason that it won't start and I stumble accross the 12A Engine tag.
WTF!
help me out here guys, do i or do i not have a 84 GSL-SE
cheers'
Old Mar 2, 2002 | 03:19 PM
riffraff's Avatar
smog nazi destroyer
gslse are all 13b fi.
Old Mar 2, 2002 | 03:21 PM
4ohfour's Avatar
*you see 4ohfour dissapearing down the street with a torque wrench on one hand and a screwdriver in the other*
i'm gonna get that son of a bitch
cheers'
Old Mar 2, 2002 | 03:55 PM
REVHED's Avatar
Hunting Skylines
Two options. Either it's not a GSL-SE or someones dropped in a 12A. You got screwed regardless.
Old Mar 2, 2002 | 03:57 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
DUDE, Id be pissed...
But it says on the title what it is
Unless someone dropped a 12A in there...
Old Mar 2, 2002 | 04:03 PM
Max7's Avatar
Admitted Sevenaholic
easy to check the motor, it can be a carbed conversion.
on sparkplug side, there should be 13B on the rotor housings on top.
to see if its a true GSL-SE chassis, look at the VIN,
It should start with JM1FB332 and not 331
also check inside on the dash, left hand side next to steering wheel, there should be NO choke.
Old Mar 2, 2002 | 04:06 PM
4ohfour's Avatar
engine says 12a
there is a choke
a man shall die tonight, and it ain't gonna be me
cheers'
p.s.
if anyone has a carfax account, I would greatly appreciate you running this VIN, the quickcheck thingy found 1 record of something on it but it won't tell me what it is.
JM1FB3313E0814953
thanks in advance
Old Mar 3, 2002 | 12:39 AM
Directfreak's Avatar
I am a Jeeper Now.
Originally posted by 4ohfour
p.s.
JM1FB3313E0814953
thanks in advance
It's a 12A GSL - with a GSL-SE badge. Do you have the SE Rims? or the regular ones? That's another tell-tale sign.
By the way, here's your Carfax info..
VIN: JM1FB3313E0814953
Year/Make/Model: 1984 MAZDA RX7 12A
Body Style: COUPE
Engine: 1.2L ROTARY FI
Fuel: GASOLINE
Driveline: REAR WHEEL DRIVE
Carburetion: 4 BARREL CARBURETOR
Cylinders: R
Manufactured in: JAPAN
GOOD NEWS! CARFAX search results confirm this 1984 MAZDA RX7 12A (JM1FB3313E0814953) qualifies for the CARFAX $5,000 Clean Title History Guarantee.
CARFAX analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problem Titles Checked: Results:
Salvage/Junk Checked - No Salvage/Junk Title Found
Rebuilt/Reconstructed Checked - No Rebuilt/Reconstructed Title Found
Flood Damage Checked - No Flood Damage Title Found
Damage Disclosure Checked - No Damage Disclosure Found
Manufacturer Buyback (LEMON) Checked - No Manufacturer Buyback Found
Exceeds Mechanical Limits (EML) Checked - No EML Found
Not Actual Mileage (NAM) Checked - No NAM Found
NOTE: Click here for a complete CARFAX Glossary.
GOOD NEWS! CARFAX search results on this 1984 MAZDA RX7 12A (JM1FB3313E0814953) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
No Reported Odometer Readings
GOOD NEWS! CARFAX search results on this 1984 MAZDA RX7 12A (JM1FB3313E0814953) did not uncover any of the following problems:
Problems Checked: Results:
Accident Checked - No Accident Record Found
Salvage Auction Checked - No Salvage Auction Record Found
Failed Emissions Inspection Checked - No Failed Emissions Record Found
Fire Damage Checked - No Fire Damage Record Found
Crash Test Vehicle Checked - No Crash Test Vehicle Record Found
Grey Market Vehicle Checked - No Grey Market Vehicle Record Found
CARFAX search results on this 1984 MAZDA RX7 12A (JM1FB3313E0814953) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - No Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
The CARFAX database contains the following vehicle history record on this 1984 MAZDA RX7 12A (JM1FB3313E0814953):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
06/20/1994 Alberta
Motor Vehicle Dept.
Calgary
Registration issued
NOTES:
You have significantly reduced your risk of purchasing a vehicle with a hidden problem. However, CARFAX has not inspected this vehicle. There could be other potential problems with this vehicle that have not been reported to CARFAX.
Not all titles issued represent a change in vehicle ownership. For example, a title could be issued to reflect an address change or correction.
PRINT AND SAVE THIS GUARANTEE ALONG WITH THE FULL REPORT
A Three-Year, Transferable Protection Plan
CARFAX's $5,000 Guarantee confirms this 1984 MAZDA RX7 12A (JM1FB3313E0814953) has a Clean Title History. This certificate is valid for three years from date of issue, and is transferable!
CARFAX $5,000 Clean Title History Guarantee Terms:
Vehicle ID Number (VIN): JM1FB3313E0814953
Issue Date:
03/03/2002
Expiration Date: 03/03/2005
Activate your $5,000 Guarantee today!
Register at www.carfax.com/register
Three-year Protection Plan:
During the next three years, should you discover a problem title in this vehicle's history which was not included in this CARFAX Report, CARFAX will pay you 10% of the vehicle's wholesale value - up to $5,000!
Transferable Protection:
This Guarantee is transferable should you sell this vehicle prior to the Guarantee expiration date. The new owner receives the same protection plan coverage for the balance of the Guarantee's term.
*CARFAX agrees to pay to the holder of this report 10% of the wholesale value of the car, up to $5,000 if Section 2 of this report indicates a Clean Title History and a Problem Title actually exists for this vehicle. A Problem Title is defined as a passenger motor vehicle ownership document issued by the state that bears the word or symbol signifying that the vehicle was salvaged or junked; rebuilt or reconstructed; flood damaged; disclosed as damaged; bought back by the manufacturer; odometer exceeds mechanical limits; odometer was not the actual mileage; or any other symbol or word of like kind. Guarantee Certificate along with corresponding full report must be presented in order to be eligible for payment.
View complete Terms and Conditions.
In appreciation for your business, we offer our valued customers additional useful services and auto-related savings opportunities. Here are several special offers provided by CARFAX and our selected partners to further assist you in the car buying process.
Thanks for using CARFAX!
CARFAX screened and selected the following warranty provider as one of the leaders in the industry, in terms of quality, service and price. Shop this provider with confidence thanks to CARFAX.
CARFAX Disclaimer:
CARFAX DEPENDS ON ITS SOURCES FOR THE ACCURACY AND RELIABILITY OF ITS INFORMATION. THEREFORE, NO RESPONSIBILITY IS ASSUMED BY CARFAX OR ITS AGENTS FOR ERRORS OR OMISSIONS IN THIS REPORT. CARFAX FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. CARFAX®
Contact Customer Service
www.carfax.com
© 2002 CARFAX, Inc., an R.L. Polk & Co. All rights reserved.
03.Mar.2002 00:32:04
Old Mar 3, 2002 | 02:49 AM
smnc's Avatar
EliteHardcoreCannuckSquad
SE VINS all start with JM1FB332
If it starts with JM1FB331 than it's a non-SE
Also, -SE's have the 14" 12 spoke allow wheels instead of the 4 spoke 13" steel or alloy rims on the other models. Plus the -SE has bigger brakes.
Old Mar 4, 2002 | 01:45 AM
4ohfour's Avatar
GSL 12A
yep thats what it is.
cheers'
R.O.D
34
Jan 6, 2016 12:09 AM
R.O.D
Rtek Forum
Sep 23, 2015 01:15 AM
