Disconnect Air Pump???
Old 02-26-02, 05:29 PM
MontegoRX7's Avatar
I just put my midpipe on and am sick of listening the the airpump vent. Is there anyway I can just unplug the airpump, but leave it in the car so I can plug it in when I put the cat on for emmissions? Will disconnecting the Airpump hurt anyting? Where would I unplug it?
Old 02-26-02, 05:58 PM
Swamp RX-7's Avatar
The plug is right on top of the pump. However, this will cause you car to run VERY rich at idle and will foul your plugs, unless you have a stand-alone FMC like the Power FC, or a piggy back like the Super AFC to lean out the mixture at idle. Hope that answers your question.
Old 02-26-02, 07:43 PM
MontegoRX7's Avatar
I have the EFI PMS. I can lean out the idle that way. Will disconnecting it affect anything else?
Old 02-26-02, 11:26 PM
Swamp RX-7's Avatar
I've heard some people get a lumpy idle, but with your ECU I'm sure you'll have zero problems. You should also think about disconnecting or removing the EGR valve if you haven't already.
Old 02-27-02, 10:08 PM
MontegoRX7's Avatar
What is the EGR, whats it do and how do I disable it. I dont really want to pull stuff off the car and install blockoff plates. If its just another connector its not a problem.
Old 02-28-02, 04:02 AM
Still has an RX7.
Enthu's Avatar
The EGR is the Exhaust Gas Recirculation Valve. I've heard it is unnescasarry unless you are in CA (emissions). I also know it caused me some problems long ago, and made my check engine light keep turning on.
rotor_veux
09-03-15 07:10 PM
Quick Reply: Disconnect Air Pump???
